New desktop PC based on Xeon e3-1231v3
Hallo!
Ik vrag op advis over deze configuratie. Mag ik iets goedkoper maken uitgezonderd de processor en de videokaart? Ik liever deze processor hebben over andere en ik mag deze videokaart voor 150 euros kopen. Ik weet dat deze videokaart is goed maar stuk oud. Ik mag ook een neuwe kaart kopen voor ongeveer 150 euros. Wat zal ik doen?
Ik wil Engels verder schriven om beter te uitleggen.
#ProductPrijsSubtotaal
1Intel Xeon E3-1231 V3 Boxed€ 256,50€ 256,50
1Gigabyte GA-H97M-D3H€ 87,95€ 87,95
1Gigabyte GV-R797OC-3GD€ 0,-€ 0,-
1Seagate Desktop HDD ST1000DM003, 1TB€ 48,50€ 48,50
1Corsair Carbide 200R Closed€ 59,80€ 59,80
1Microsoft Windows 8.1 NL OEM 64-bit€ 79,-€ 79,-
1Cooler Master Hyper 212 EVO€ 25,95€ 25,95
1Corsair Vengeance CML8GX3M2A1866C9B€ 59,-€ 59,-
1Samsung SH-224DB Zwart€ 12,20€ 12,20
1Corsair Builder CX600 Bronze€ 67,51€ 67,51
1Kingston SSDNow V300 120GB€ 52,95€ 52,95
Bekijk collectie
Importeer producten
Totaal€ 749,36
Most of the time I do programming, which itself does not require much resources. But I always have several applications open and two monitors, which together takes a lot, and then I have problems with my current laptop. Sometimes I have Image Processing topics and that likes more memory and better graphics. I also watch videos and sometimes play 3D mmo games. I am going to have a double boot system with one of the Linux distributions. On Windows I will be probably running Virtual Machines.
I can see now that it will cost me around 900 euros excluding monitor, since I have one 24 inch already. I prefer to have it cheaper. So, if you have a good solution, please share.
• pricewatch: Gigabyte GV-R797OC-3GD
• A monitor
• A keyboard
• A mouse
I have chosen for Xeon e3-1231v3 for a couple of reasons: it does not have an integrated graphics card (I am going to buy an external one), it supports multithreading, it does not have an overclocking option, it was issued in Q2 of 2014 and I expect to use it fine for a few years.
So, I made a list on http://pcpartpicker.com/p/mmktYJ and it has a nice compatibility check. I would still like to know your opinion, also about the cheaper options.
• Price is important for me, so I would like to hear cheaper options.
• The case should not be fancy - a good cooling is more important.
Ga je overklokken?
Nee
ENGLISH
I am looking for a new desktop PC but I am not very much familiar with hardware and I ask for an advise about the configuration. I have chosen for the Intel Xeon E3-1231v3 processor. I also can get two video cards Gigabyte pricewatch: Gigabyte GV-R797OC-3GD for 150 euros each. The rest is somewhat difficult for me.
Could you please advise me on the rest of the components. Also it would be interesting for me to know if it is a good idea to use one of those video cards, or buy a new one. My budget for this is around 150-200 euros.
Another question is how do I do the assembly? I can buy everything online for cheaper and assemble it myself, but I am not sure if this is an easy task. I can also go to some shop and order everything there together with assembly, which will cost more. How much more will it cost? Does it worth to do the assembly myself? Which shop would you recommend in case of the assembly?
Any advises are welcome.
Thank you.
[ Voor 49% gewijzigd door Verwijderd op 23-06-2015 14:42 ]
  • br00ky
  • Laatst online: 00:09
br00ky
Although your opening post is very thourough, we expect you to collect all the components, not just a CPU + cooler.
Numerous examples can be found within this subforum, no exception for you here :). For that I'm temporarily closing your topic. I'll reopen it, when your complete list is ready. You can contact me via DM. Click on my username and subsequently, "stuur bericht"
Secondly, the language on this forum is Dutch, so even though your Dutch is not very well, we expect you to write in Dutch, maybe with a little help of Google translate.
I have changed some things in the list.
  • sjettepetJR.
  • Laatst online: 14-09 22:48
I prefer English over the crappy Google translate Dutch...
sjettepetJR. schreef op dinsdag 23 juni 2015 @ 15:39:
Sorry for that. It was the requirement of the moderator. Otherwise he would not accept the topic. Just skip first paragraph and read further.
  • Arunia
  • Laatst online: 22:58
Dat kun jij dan wel preferren, maar het blijft gewoon een eis op dit forum.
Overigens lees ik net zo makkelijk Engels als Nederlands. Maar regels blijven gewoon regels. Hoe tenenkrommend het uiteindelijke resultaat ook wordt. :P
En om even ontopic te gaan.
Er is weinig te verminderen als het duurste component al degene is die niet gewijzigd mag worden.
Voor 150 kun je prima die 7970 kopen. De 7970's zijn wel verbruikers. Dus dat is dan de enige reden om het wellicht niet te doen.
Als je niet zou gamen zou ik gaan voor een i7 met geintegreerde graphics.
Overigens zou je nog kunnen vermelden wat je wilt gamen aan MMO's.
Wellicht dat dit prima op de iGP te doen is? Wellicht niet alles op max settings.
[ Voor 37% gewijzigd door Arunia op 23-06-2015 16:51 ]
  • sjettepetJR.
Arunia schreef op dinsdag 23 juni 2015 @ 16:43:
ik ben het daar ook totaal mee eens, maar dan kan je beter het topic gewoon helemaal sluiten, dan proberen gebrabbel te lezen.
ik vind het ook gek dat de TS op dit forum komt.
  • Arunia
sjettepetJR. schreef op dinsdag 23 juni 2015 @ 16:46:
Amen.
Er zijn zat Engelse fora waar de vragen geplaatst kunnen worden of de TS moet in NL wonen en hier een pc willen kopen. Dat zou dan nog de enige reden zijn om hier te komen voor advies, maar dan heeft hij vast wel iemand die wel Nederlands als taal heeft om te helpen met dit topic.
  • CH4OS
CH4OS
It's a kind of magic
TS, als je niet gaat overclocken, kun je overwegen de boxed koeler te gebruiken, die maakt weliswaar wat meer geluid dan goede - stille - koelers, maar je bespaart er wel de aanschaf van een dergelijke koeler mee en de stock koeler koelt goed genoeg op stock snelheden, zeker als je niet gaat overclocken. Of je moet stilte als eis hebben.
[ Voor 5% gewijzigd door CH4OS op 23-06-2015 16:51 ]
CptChaos schreef op dinsdag 23 juni 2015 @ 16:50:
Ik ga niet overclocken. Ik heb het ook gelezen dat de stock cooler is redelijke goed. Ik ga de stock cooler proberen. Dank je.
Here is the new list:
1Corsair Carbide SPEC-01 Red Led€ 51,80€ 51,80
Bekijk collectie
Importeer producten
Totaal€ 715,41
Still not sure if it is a good idea to use the used video card.
  • CH4OS
CH4OS
Of de GPU mee kan hangt natuurlijk ook af van wat je doet en wat je wil gaan doen.
  • sjettepetJR.
je kan een goedkoper moederbord nemen.
je kan de optical drive ook weg laten.
CptChaos schreef op dinsdag 23 juni 2015 @ 17:09:
Sorry, now in English - it is too difficult to explain in Dutch.
What I do I described in the first message, and I assume that both, the used GPU and another new one of the same price (around 150 euros) will perform more or less equally for my tasks. My concern is more about if I can rely on the older one for a few years from now, such as on the newer one?
sjettepetJR. schreef op dinsdag 23 juni 2015 @ 17:15:
I was looking at the cheaper motherboards, and I can save there around 10-15 euros. But how does it influence the total performance of the system?
I would like to exclude the optical drive but the CD's and DVD's are still in use a lot. I myself have many, which I may want to load some day in the drive. I can probably skip it for the moment, but I believe, I will get one later anyway.
Dank je voor de optie. Ik ga deze proberen.
Ik begrijp dat er is niet veel te verbeteren. Hoe moet ik deze componenten kopen? Apart en dan zelf monteren of laat iemand deze doen?
de neuwe lijst gebaseerd op i7-4790:
1Intel Core i7-4790 Boxed€ 310,50€ 310,50
1Cooler Master N300 (KKN1, closed)€ 32,-€ 32,-
1Microsoft Windows 8.1 NL OEM 64-bit€ 94,95€ 94,95
1Corsair Vengeance LP CML8GX3M2A1600C9€ 52,95€ 52,95
1Samsung SH-224DB Zwart€ 12,60€ 12,60
1Seasonic S12II-Bronze 520W€ 56,95€ 56,95
Bekijk collectie
Importeer producten
Totaal€ 775,30
Rond 100 euros goedkoper, maar de iGPU is slechter - 350MHz vs 1000MHz snelheid.
