[Debian] rm: cannot remove keyboard: Operation not permitt
  • Olaf van der Spek
# rm /etc/default/keyboard
rm: cannot remove ‘/etc/default/keyboard’: Operation not permitted
drwxr-xr-x 85 root root 4096 Jun 18 12:01 /etc
drwxr-xr-x  2 root root 4096 Jun 18 14:27 /etc/default
-rw-r--r--  1 root root   70 Dec 11  2014 /etc/default/keyboard
Setting up keyboard-configuration (1.123) ...
/var/lib/dpkg/info/keyboard-configuration.postinst: 102: /var/lib/dpkg/info/keyboard-configuration.postinst: cannot create /etc/default/keyboard: Permission denied
Linux h 3.8.13-xxxx-grs-ipv6-64-vps #2 SMP Fri May 17 05:56:23 CEST 2013 x86_64 GNU/Linux (OVH VPS)
# df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        23G  3.4G   19G  16% /
devtmpfs        3.9G     0  3.9G   0% /dev
tmpfs           798M  220K  798M   1% /run
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           2.0G     0  2.0G   0% /dev/shm
Niks bijzonders in dmesg, syslog.. ik weet het niet meer. Heeft iemand een idee?
  • Olaf van der Spek
Toch weer opgelost, geen idee waarom het immutable attribute was gezet.
# lsattr keyboard
----i----------- keyboard
# chattr -i keyboard
  • 0xDEADBEEF
GNU's ls is kreupel :) wat je mist is -o
-o Include the file flags in a long (-l) output. See chflags(1) for
a list of file flags and their meanings.
"Religion is an insult to human dignity. With or without it you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg
  • Kees
  • Laatst online: 10:00
Kees
Serveradmin / BOFH / DoC
Olaf van der Spek schreef op vrijdag 19 juni 2015 @ 14:14:
# lsattr keyboard
Dat was mijn allereerste gedachte, te vaak tegenaan gelopen (meestal mijn eigen schuld omdat ik dan in het verleden een stom programma wilde beletten die file aan te passen ;))
