C++ DNS Checker
  • Roel911
  • Laatst online: 18-08-2025
Ik ben een DNS checker aan het maken, die brute-force combinaties (bijv. aa.nl - 99.nl) probed. Echter zodra ik het programma compileer en uitvoer wordt alle output grotendeels vervangen door het laatste resultaat (behalve de regelnummers).
De code:
C++: adbfc.cpp
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
//compile: g++ adbfc.cpp -lanl -std=c++11 -fpermissive
#define _GNU_SOURCE
#include <netdb.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <iostream>
static struct gaicb **reqs = NULL;
static int nreqs = 0;
const std::string validurlchar ="abcdefghijklmnopqrstuvwxyz0123456789-_";
const std::string tld=".nl";
/* Add requests for specified hostnames */
static void add_requests(void)
    int nreqs_base = nreqs;
    char *host;
    int ret;
    //std::cout << validurlchar.length() << std::endl;
    for(int a=0;a<validurlchar.length();a++)
   for(int b=0;b<validurlchar.length();b++)
          std::string url;
     url=validurlchar[a];
     url+=validurlchar[b];
     url+=tld;
     nreqs++;
     reqs = realloc(reqs, nreqs * sizeof(reqs[0]));
     reqs[nreqs - 1] = calloc(1, sizeof(*reqs[0]));
     reqs[nreqs - 1]->ar_name = url.c_str();
     //std::cout << url.c_str() << std::endl;
     //std::cout << reqs[nreqs-1]->ar_name << std::endl;
   ret = getaddrinfo_a(GAI_WAIT, &reqs[nreqs_base], nreqs - nreqs_base, NULL);
       if (ret) {
        fprintf(stderr, "getaddrinfo_a() failed: %s\n",
                gai_strerror(ret));
        exit(EXIT_FAILURE);
/* List all requests */
static void
list_requests(void)
    int i, ret;
    char host[NI_MAXHOST];
    struct addrinfo *res;
   for (i = 0; i < nreqs; i++) {
        printf("[%02d] %s: ", i, reqs[i]->ar_name);
        ret = gai_error(reqs[i]);
       if (!ret) {
            res = reqs[i]->ar_result;
           ret = getnameinfo(res->ai_addr, res->ai_addrlen,
                              host, sizeof(host),
                              NULL, 0, NI_NUMERICHOST);
            if (ret) {
                fprintf(stderr, "getnameinfo() failed: %s\n",
                        gai_strerror(ret));
                exit(EXIT_FAILURE);
            puts(host);
        } else {
            puts(gai_strerror(ret));
int main()
 add_requests();
 list_requests();
De output:
[00] __.nl: Name or service not known
[1443] __.nl: Name or service not known
Ik ben me er van bewust dat "_" en "-" niet in alle gevallen zomaar geldig zijn. Zelfs als ik "9" het laatst laat checken worden alle regels vervangen met bijv. "99.nl". Wat ik zelf geprobeerd heb: google, man page van getaddrinfo_a doorgelezen, gezocht op stackoverflow. Tevens als test het voorbeeld genoemd op de manpage gecompileerd en 2 domeinen doorgegeven als parameters, dat werkt goed. Wat doe ik fout?
  • Feanathiel
Feanathiel
Cup<Coffee>
Ik ken c++ niet zo goed om hier een definitief antwoord op te kunnen geven. Wat mij wel opvalt:
C++:
for(...)
    std::string url;
    ... = url.c_str();
Is de pointer nog wel geldig die uit c_str() komt nadat een iteratie van de loop voorbij is? Volgens mij wordt url namelijk bij iedere iteratie opnieuw gealloceerd (op dezelfde locatie?) en weer opgeruimt bij het einde van de loop-scope.
[ Voor 6% gewijzigd door Feanathiel op 16-06-2015 08:32 ]
  • Roel911
Feanathiel schreef op dinsdag 16 juni 2015 @ 08:32:
C++:
for(...)
    std::string url;
    ... = url.c_str();
Je hebt gelijk! Ik heb een array van strings gemaakt en daarmee is de output wel zoals ik verwacht. Bedankt voor je reactie_/-\o_
  • MSalters
  • Laatst online: 22-10 15:29
realloc, calloc, fprintf, puts. Je maakt het jezelf niet makkelijk door in C te programmeren.
Man hopes. Genius creates. Ralph Waldo Emerson
Never worry about theory as long as the machinery does what it's supposed to do. R. A. Heinlein
