KB3022345 / KB3068708: Windows Diagnostic Tracking Service
  • ReTechNL
  • Laatst online: 08-10 10:20
DiagTrack - The Diagnostics Tracking Service
When you acquire, install and use the Program, Microsoft collects information about you, your devices, applications and networks, and your use of those devices, applications and networks. Examples of data we collect include your name, email address, preferences and interests; browsing, search and file history; phone call and SMS data; device configuration and sensor data; and application usage. For example, when you:
  • Install the Program, we may collect information about your device and applications and use it for purposes such as determining or improving compatibility.
  • Use voice input features like speech-to-text, we may collect voice information and use it for purposes such as improving speech processing.
  • Open a file, we may collect information about the file, the application used to open the file, and how long it takes and use it for purposes such as improving performance.
  • Enter text, we may collect typed characters and use them for purposes such as improving auto complete and spell check features.
Bronnen:
http://en.community.dell....spyware/f/3522/t/19630596
Update for customer experience and diagnostic telemetry
http://community.norton.com/de/node/1176101
Nu heb ik misschien wel een redelijke alluminium hoedje op maar dit lijkt me gewoon op een ordinaire keylogger onder een diagnostics jasje....
  • furian88
  • Laatst online: 18:24
via de 2e link kom ik uit bij de microsoft website, die verwijzen dat deze KB3022345 is vervangen door:
The diagnostics tracking service collects diagnostics about functional issues on Windows systems that participate in the Customer Experience Improvement Program (CEIP)
CEIP reports do not contain contact information, such as your name, address, or telephone number. This means CEIP will not ask you to participate in surveys or to read junk email, and you will not be contacted in any other way.
server 2012: standaard uit..
Windows 8.1: standaard aan...
https://drive.google.com/...QRzJYYlU/view?usp=sharing
[ Voor 11% gewijzigd door furian88 op 15-06-2015 09:27 ]
https://pvoutput.org/list.jsp?userid=86006
  • Synthiman
  • Laatst online: 24-09-2018
Microsoft has also released updates for Windows 7 and Windows 8.1 users and turns out that the update has enhanced data collection even on these older operating system versions. So operating systems such as Windows 7 and Windows 8.1 are now able to collect data without the user's knowledge.
The updates released by Microsoft are kb3068708, kb3022345, kb3075249 and kb3080149, which basically "introduce the Diagnostics and Telemetry tracking service" for the older Windows versions. Moreover per Microsoft, these updates also "add telemetry points to the User Account Control (UAC) feature to collect information on elevations that come from low integrity levels."
So this basically means that once a user installs any of the above-mentioned updates, Microsoft will have the ability to collect data from your Windows 8.1 or Windows 7 PC just as it is able to on Windows 10.
Bron: http://www.techtimes.com/...ing-more-of-your-data.htm
Sinds vandaag kun je kb2976978 aan dit rijtje toevoegen.
Info: https://support.microsoft.com/en-us/kb/2976978
  • ELD
ELD
Zeer zorgelijk.
ik vind de oplossing van techtimes om in de host file de data collectie domeinen te blokkeren goed bedoeld, maar vraag mij af of het werkelijk effectief is. Hoe kun je er op vertrouwen dat deze domeinen überhaupt worden geblokkeerd in Windows ongeacht de configuratie in de host file.
  • Synthiman
Zoek op "Diagtrackrunner.exe", vindt je die, verwijder hem. Verder de hier opgenoemde updates verwijderen en verbergen (blokkeren). Voorts bij elke aangeboden update eerst goed kijken naar de informatie over de betreffende update.
En ja, ik vind dit schandalig van Microsoft.....
  • LocK_Out
  • Laatst online: 07-10 21:57
Synthiman schreef op maandag 19 oktober 2015 @ 17:16:
Thanks voor de extra tip.
Verwijderd krijg ik 'm niet. Zit gekoppeld aan svchost.exe.
Via services (via taakbeheer) en dan eigenschappen van Diagnostics Tracking Service kan je m wel uitschakelen.
  • Synthiman
Verwijderen van de update die hem geïnstalleerd heeft zou hem ook weer moeten verwijderen. Dit kan wel even duren.
Google search: https://www.google.com/se...moval+Diagtrackrunner.exe
Sorry dat ik geen betere link kan geven. Er blijken nogal wat verschillende situaties te bestaan, zodat er geen algemene oplossing is. Het is oa afhankelijk van welke update(s) je hebt..
Diagtrackrunner.exe kan trouwens meer dan eens op je systeem voorkomen. Verwijder alle updates die in verband staan met installeren van diagtrackrunner.exe.
Misschien helpt dit: https://www.reddit.com/r/...ry_from_windows_7_and_8x/
[ Voor 52% gewijzigd door Synthiman op 20-10-2015 12:51 ]
