[Ubuntu 14.04] TFTP not working
  • battler
  • Laatst online: 30-06-2025
Ik wil graag een TFTP server opzetten. Het werkt niet maar helaas krijg ik te weinig logs om door te krijgen wat er aan de hand is.
inetd.conf wat de service start
#:BOOT: TFTP service is provided primarily for booting.  Most sites
#       run this only on machines acting as "boot servers."
tftp        dgram   udp wait    root    /usr/sbin/tcpd  /usr/sbin/in.tftpd /tftpboot
De config file
cat /etc/xinetd.d/tftp
service tftp
protocol        = udp
port            = 69
socket_type     = dgram
wait            = yes
user            = nobody
server          = /usr/sbin/in.tftpd
server_args     = /tftpboot
disable         = no
netstat
udp        0      0 0.0.0.0:69              0.0.0.0:*                           26639/xinetd
Folder
ls -l /tftpboot/
total 4
-rwxrwxrwx 1 nobody domain^users 9 Jun 14 12:41 test2
xinetd.conf debug
15/6/14@12:47:34: DEBUG: 25294 {svc_resume} Resumed service tftp
15/6/14@12:47:34: DEBUG: 25294 {child_exit} waitpid returned = -1
15/6/14@12:47:34: DEBUG: 25294 {main_loop} active_services = 1
15/6/14@12:47:39: DEBUG: 25294 {main_loop} select returned 1
15/6/14@12:47:39: DEBUG: 25294 {svc_suspend} Suspended service tftp
15/6/14@12:47:39: DEBUG: 25294 {server_start} Starting service tftp
15/6/14@12:47:39: DEBUG: 25294 {main_loop} active_services = 0
15/6/14@12:47:39: DEBUG: 25386 {exec_server} duping 6
15/6/14@12:47:39: DEBUG: 25294 {check_pipe} Got signal 17 (Child exited)
15/6/14@12:47:39: DEBUG: 25294 {child_exit} waitpid returned = 25386
15/6/14@12:47:39: DEBUG: 25294 {server_end} tftp server 25386 exited
15/6/14@12:47:39: DEBUG: 25294 {drain} UDP socket should be empty
Syslog server kant
Jun 14 12:53:54 vbh-dtc-srv003 xinetd[26639]: xinetd Version 2.3.15 started with libwrap loadavg options compiled in.
Jun 14 12:53:54 vbh-dtc-srv003 xinetd[26639]: Started working: 2 available services
Jun 14 12:54:07 vbh-dtc-srv003 in.tftpd[26711]: connect from 31.201.23.20 (31.201.23.20)
Jun 14 12:54:07 vbh-dtc-srv003 tftpd[26712]: tftpd: trying to get file: test2
Jun 14 12:54:07 vbh-dtc-srv003 tftpd[26712]: tftpd: serving file from /tftpboot
Jun 14 12:54:12 vbh-dtc-srv003 in.tftpd[26716]: connect from 31.201.23.20 (31.201.23.20)
Jun 14 12:54:12 vbh-dtc-srv003 tftpd[26717]: tftpd: trying to get file: test2
Jun 14 12:54:12 vbh-dtc-srv003 tftpd[26717]: tftpd: serving file from /tftpboot
Wireshark client kant
348 50.474767000    192.168.1.15    5.200.20.54 TFTP    60  Read Request, File: test21, Transfer type: netascii
351 53.662456000    192.168.1.15    5.200.20.54 TFTP    59  Read Request, File: test2, Transfer type: netascii
Ik heb echt geen idee meer. De config files zijn er, de service draait, request komt binnnen. Wordt niets mee gedaan, geen error melding etc. time out, en weer een request. Iemand een idee om erachter te komen waar het fout gaat? ik kan ook geen log flags vinden mbt TFTP :(
Lux.Architectuur | Van Dromen tot Wonen | www.Lux-a.nl
  • Hero of Time
  • Laatst online: 10:34
Hero of Time
Moderator LNX
There is only one Legend
Welke handleiding heb je gevolgd om het via xinetd te doen? Welke tftp server heb je geïnstalleerd? Er zijn in iig Debian twee soorten die PXE boot ondersteunen en totaal 3 packages die tftpd geven.
Ik heb zelf een PXE boot server proberen te bouwen, is nog niet af, maar ik krijg iig wel een melding van de machine die via PXE wil starten. Jij geeft aan dat je dat al niet krijgt, wat dus betekend dat je geen PXE compatible tftpd gebruikt. Ook je config is niet zoals dat is beschreven in vele handleidingen voor PXE boot via tftp.
Commandline FTW
  • battler
Ik wil geen PXE boot server opzetten, echt alleen TFTP. Ik heb meerdere handleiding gevolgd maar onder andere;
https://linuxlink.timesys.com/docs/linux_tftp
http://askubuntu.com/ques...all-and-run-a-tftp-server
  • Hero of Time
Hero of Time
Moderator LNX
Het gebruik van xinetd is niet direct nodig, tftpd kan ook standalone draaien. Heb je al getest via 'tftp localhost', zoals in je eerste handleiding staat?
Commandline FTW
