[xbmc/kodi] Mysql DB krijg ik niet aan de praat
  • Simkin
  • Laatst online: 08:15
Ik probeer mijn OpenElec Kodi DB te hosten op mijn Debian Jessy NAS waarop ik MariaDB heb geinstalleerd maar Kodi geeft aan dat hij geen DB aan kan maken (see log hieronder):
root@nas:/var/log/mysql# mysql --version
mysql Ver 15.1 Distrib 10.0.16-MariaDB, for debian-linux-gnu (x86_64) using readline 5.2
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
19:10:25 T:140135811319680  NOTICE: Loaded settings file from special://profile/advancedsettings.xml
19:10:25 T:140135811319680  NOTICE: Contents of special://profile/advancedsettings.xml are...
                                            <advancedsettings>
                                              <videodatabase>
                                                <type>mysql</type>
                                                <host>192.168.0.240</host>
                                                <port>3306</port>
                                                <user>kodi</user>
                                                <pass>kodi</pass>
                                              </videodatabase>
                                              <musicdatabase>
                                                <type>mysql</type>
                                                <port>3306</port>
                                                <user>kodi</user>
                                                <pass>kodi</pass>
                                              </musicdatabase>
                                              <videolibrary>
                                                <importwatchedstate>true</importwatchedstate>
                                                <importresumepoint>true</importresumepoint>
                                              </videolibrary>
                                            </advancedsettings>
19:10:25 T:140135811319680 WARNING: VIDEO database configuration is experimental.
19:10:25 T:140135811319680  NOTICE: Default DVD Player: dvdplayer
19:10:25 T:140135811319680  NOTICE: Default Video Player: dvdplayer
19:10:25 T:140135811319680  NOTICE: Default Audio Player: paplayer
19:10:25 T:140135811319680  NOTICE: Disabled debug logging due to GUI setting. Level 0.
19:10:25 T:140135811319680  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
19:10:25 T:140135811319680  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
19:10:25 T:140135811319680  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
19:10:25 T:140135811319680  NOTICE: Loaded playercorefactory configuration
19:10:25 T:140135811319680  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
19:10:25 T:140135811319680  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
19:10:25 T:140135800764160  NOTICE: Thread ActiveAE start, auto delete: false
19:10:25 T:140135723169536  NOTICE: Thread AESink start, auto delete: false
19:10:25 T:140135811319680  NOTICE: Running database version Addons16
19:10:25 T:140135811319680  NOTICE: ADDONS: Using repository repository.xbmc.org
19:10:25 T:140135811319680  NOTICE: ADDONS: Using repository repository.openelec.tv
19:10:25 T:140135714776832  NOTICE: Thread PeripBusCEC start, auto delete: false
19:10:25 T:140135706384128  NOTICE: Thread PeripBusUSBUdev start, auto delete: false
19:10:25 T:140135811319680  NOTICE: Setup SDL
19:10:25 T:140135811319680  NOTICE: Checking resolution 16
19:10:25 T:140135811319680  NOTICE: Using visual 0x20
19:10:25 T:140135811319680  NOTICE: GL_VENDOR = Intel Open Source Technology Center
19:10:25 T:140135811319680  NOTICE: GL_RENDERER = Mesa DRI Intel(R) Ivybridge Mobile
19:10:25 T:140135811319680  NOTICE: GL_VERSION = 3.0 Mesa 10.3.7
19:10:25 T:140135811319680  NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
19:10:25 T:140135811319680  NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_AMD_performance_monitor GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_conservative_depth GL_AMD_draw_buffers_blend GL_AMD_seamless_cubemap_per_texture GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_cube_map_array GL_ARB_texture_gather GL_ARB_texture_multisample GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_texture_compression_bptc GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shader_atomic_counters GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_ARB_transform_feedback_instanced GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_shader_trinary_minmax GL_ARB_ES3_compatibility GL_ARB_clear_buffer_object GL_ARB_copy_image GL_ARB_explicit_uniform_location GL_ARB_invalidate_subdata GL_ARB_texture_query_levels GL_ARB_texture_storage_multisample GL_ARB_texture_view GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_buffer_storage GL_ARB_clear_texture GL_ARB_multi_bind GL_ARB_seamless_cubemap_per_texture GL_ARB_texture_mirror_clamp_to_edge GL_ARB_vertex_type_10f_11f_11f_rev GL_EXT_shader_integer_mix GL_INTEL_performance_query GL_ARB_conditional_render_inverted GL_ARB_derivative_control
19:10:25 T:140135811319680  NOTICE: Running database version ViewModes6
19:10:25 T:140135811319680  NOTICE: Running database version Textures13
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic48 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic47 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic46 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic45 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic44 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic43 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic42 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic41 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic40 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic39 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic38 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic37 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic36 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic35 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic34 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic33 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic32 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic31 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic30 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic29 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic28 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic27 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic26 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic25 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic24 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic23 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic22 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic21 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic20 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic19 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyMusic18 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to create new database
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos90 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos89 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos88 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos87 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos86 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos85 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos84 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos83 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos82 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos81 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos80 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos79 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos78 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos77 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos76 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos75 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos74 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos73 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos72 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos71 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos70 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos69 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos68 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos67 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos66 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos65 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos64 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos63 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos62 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos61 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680   ERROR: Unable to open database: MyVideos60 [2003](Can't connect to MySQL server on '192.168.0.240' (101))
19:10:25 T:140135811319680  NOTICE: Running database version TV26
19:10:25 T:140135811319680  NOTICE: Running database version Epg8
Zodra ik vanaf mijn werkstation als kodi gebruiker een remote verbinding maak met de server en een DB
+ tabellen aan probeer te maken dat gaat het wel goed (zie testdatabase in lijstje onder de advancedsettings.xml hier onder)
Zoals je in de log kan zien localiseerd hij de advancedsettings.xml hij nmi naar behoren. De gehele content:
<advancedsettings>
  <videodatabase>
    <type>mysql</type>
    <port>3306</port>
    <user>kodi</user>
    <pass>kodi</pass>
  </videodatabase>
  <musicdatabase>
    <type>mysql</type>
    <port>3306</port>
    <user>kodi</user>
    <pass>kodi</pass>
  </musicdatabase>
  <videolibrary>
  </videolibrary>
</advancedsettings>
Er wordt geen DB aangemaakt en er bestaat er ook niet al een ondder een andere eigenaar:
Afbeeldingslocatie: http://i.imgur.com/RJxxOJm.png
Ik heb dus een dedicated gebruiker:
Afbeeldingslocatie: http://i.imgur.com/Oix0Bfq.png
Ik heb de advancedsettings.xml op de juiste plek staan op OpenElec "\Userdata\advancedsettings.xml"
Ik kan van andere remote machines wel connecten naar de DB, met dezelfde credentails, en een DB aanmaken.
Ik snap er niets van :/ Wat zie ik over het hoofd??
  • DeTeraarist
  • Laatst online: 20-10 21:58
DeTeraarist
#Boots2Asses
Kodi geeft niet aan dat hij geen database kan maken, hij geeft aan dat hij de machine met de database niet kan bereiken.
Soms, als ik heel stil ben, kan ik de zon horen schijnen
  • Simkin
DeTeraarist schreef op woensdag 10 juni 2015 @ 22:05:
Naar mijn weten geeft hij die melding enkel aan om dat hij een scan doet naar bestaande DB, waar hij geen verbinding mee kan maken (omdat ze niet bestaan). Je ziet daaronder de melding dat hij geen DB aan kan maken.
  • DeTeraarist
DeTeraarist
#Boots2Asses
Deze foutmelding staat er tientallen keren in, maar jij kijkt naar die ene fout dat er geen database gemaakt kan worden. Begin gewoon bovenaan en werk dan naar beneden. 100 tegen 1 dat je als je de fout die ik aanhaal oplos de fout over een nieuwe database aanmaken niet meer tegenkomt.
  • Matthijz98
  • Laatst online: 13-10 13:12
Waarschijnlijk klopt je ip address niet als de db op de zelfde machine staat als de media speler is het ip localhost of 127.0.0.1. Als je tabel niet bestaat of de inlog gegevens niet kloppen krijg je een anderen error.
  • Simkin
Bedankt voor het meedenken maar ik ben er uit. Het probleem was dat de DB connectie op werd gezet door OpenElec voordat de NIC actief was (probleem met de wat snellere mediaspelers, e.g. Intel NUC). De workaround is om in '\Configfiles' een "autostart.sh" bestand aan te maken met de volgende content (pas je IP/gateway aan je eigen omgeving):
#!/bin/sh
ifconfig eth0 up
ifconfig eth0 192.168.0.19
route add default gw 192.168.0.1
  • Room42
Simkin schreef op donderdag 11 juni 2015 @ 21:54:
#!/bin/sh
ifconfig eth0 up
Volgens mij is er in OpenELEC (Kodi) gewoon een optie bij de netwerkinstellingen dat Kodi pas gestart moet worden als er een netwerkverbinding is. (Wait for connection, of zoiets).
https://github.com/OpenELEC/OpenELEC.tv/issues/3836
OpenELEC addon -> wait for network.
[ Voor 6% gewijzigd door Room42 op 11-06-2015 22:03 ]
  • Simkin
Room42 schreef op donderdag 11 juni 2015 @ 22:01:
Wist ik niet! Ga er eens naar kijken, zou niet verkeerd zijn dat die setting automatisch actief wordt gezet als er een externe DB referentie wordt gevonden in de advancedsettings.xml lijkt me zo :)
