• digidokter.net
  • Laatst online: 07-01-2024
digidokter.net
... en 'Niets' van 'Alles' LOL
12:19:46.748 Patchbay uitgeschakeld.
12:19:46.750 Initialisatie van statistieken.
12:19:46.782 ALSA verbindingen aangepast.
12:19:46.847 DBUS : Service is beschikbaar (org.jackaudio.service ook gekend als jackdbus).
Cannot connect to server socket err = Bestand of map bestaat niet
Cannot connect to server request channel
jack server is not running or cannot be started
12:19:46.863 ALSA verbindingen aangepast.
12:23:14.200 DBUS : JACK server kon niet worden gestart. Sorry
Wed Jun 10 12:22:49 2015: Starting jack server...
Wed Jun 10 12:22:49 2015: JACK server starting in realtime mode with priority 10
Wed Jun 10 12:22:49 2015: self-connect-mode is "Don't restrict self connect requests"
Wed Jun 10 12:22:49 2015: Acquired audio card Audio0
Wed Jun 10 12:22:49 2015: creating alsa driver ... hw:0|hw:0|1024|2|44100|0|0|nomon|swmeter|-|32bit
Wed Jun 10 12:22:49 2015: ERROR: ALSA: Cannot open PCM device alsa_pcm for playback. Falling back to capture-only mode
Wed Jun 10 12:22:49 2015: configuring for 44100Hz, period = 1024 frames (23.2 ms), buffer = 2 periods
Wed Jun 10 12:22:49 2015: ALSA: final selected sample format for capture: 16bit little-endian
Wed Jun 10 12:22:49 2015: ALSA: use 2 periods for capture
Wed Jun 10 12:22:54 2015: ERROR: JackPosixProcessSync::LockedTimedWait error usec = 5000000 err = Connection timed out
Wed Jun 10 12:22:54 2015: ERROR: Driver is not running
Wed Jun 10 12:22:54 2015: ERROR: Cannot open client name = dbusapi
Wed Jun 10 12:22:54 2015: ERROR: failed to create dbusapi jack client
Wed Jun 10 12:23:24 2015: ERROR: ALSA: poll time out, polled for 34828038 usecs
Wed Jun 10 12:23:24 2015: ERROR: JackAudioDriver::ProcessAsync: read error, stopping...
Wed Jun 10 12:23:24 2015: Released audio card Audio0
Wed Jun 10 12:23:24 2015: Saving settings to "/home/ubuntu/.config/jack/conf.xml" ...
12:23:30.748 Kon niet verbinden als client met de JACK server. - Gehele toepassing gefaald. - Kan niet met de server verbinden. Gelieve het berichten venster te lezen voor meer info.
12:24:36.547 DBUS : JACK server kon niet worden gestart. Sorry
Wed Jun 10 12:24:11 2015: Starting jack server...
Wed Jun 10 12:24:11 2015: JACK server starting in realtime mode with priority 10
Wed Jun 10 12:24:11 2015: self-connect-mode is "Don't restrict self connect requests"
Wed Jun 10 12:24:11 2015: Acquired audio card Audio0
Wed Jun 10 12:24:11 2015: creating alsa driver ... hw:0|hw:0|1024|2|44100|0|0|nomon|swmeter|-|32bit
Wed Jun 10 12:24:11 2015: ERROR: ALSA: Cannot open PCM device alsa_pcm for playback. Falling back to capture-only mode
Wed Jun 10 12:24:11 2015: configuring for 44100Hz, period = 1024 frames (23.2 ms), buffer = 2 periods
Wed Jun 10 12:24:11 2015: ALSA: final selected sample format for capture: 16bit little-endian
Wed Jun 10 12:24:11 2015: ALSA: use 2 periods for capture
Wed Jun 10 12:24:16 2015: ERROR: JackPosixProcessSync::LockedTimedWait error usec = 5000000 err = Connection timed out
Wed Jun 10 12:24:16 2015: ERROR: Driver is not running
Wed Jun 10 12:24:16 2015: ERROR: Cannot open client name = dbusapi
Wed Jun 10 12:24:16 2015: ERROR: failed to create dbusapi jack client
12:24:45.583 Kon niet verbinden als client met de JACK server. - Gehele toepassing gefaald. - Server communicatie fout. Gelieve het berichten venster te lezen voor meer info.
Cannot read socket fd = 17 err = Gelukt
CheckRes error
JackSocketClientChannel read fail
Cannot open qjackctl client
Wed Jun 10 12:24:45 2015: ERROR: JackPosixProcessSync::LockedTimedWait error usec = 5000000 err = Connection timed out
Wed Jun 10 12:24:45 2015: ERROR: Driver is not running
Wed Jun 10 12:24:45 2015: ERROR: Cannot create new client
Wed Jun 10 12:24:46 2015: ERROR: ALSA: poll time out, polled for 34828033 usecs
Wed Jun 10 12:24:46 2015: ERROR: JackAudioDriver::ProcessAsync: read error, stopping...
Wed Jun 10 12:24:46 2015: Released audio card Audio0
Wed Jun 10 12:24:46 2015: Saving settings to "/home/ubuntu/.config/jack/conf.xml" ...
12:39:35.702 ALSA verbindingen aangepast.
12:41:10.333 DBUS : JACK server kon niet worden gestart. Sorry
Wed Jun 10 12:40:45 2015: Starting jack server...
Wed Jun 10 12:40:45 2015: JACK server starting in realtime mode with priority 10
Wed Jun 10 12:40:45 2015: self-connect-mode is "Don't restrict self connect requests"
Wed Jun 10 12:40:45 2015: Acquired audio card Audio0
Wed Jun 10 12:40:45 2015: creating alsa driver ... hw:0|hw:0|1024|2|44100|0|0|nomon|swmeter|-|32bit
Wed Jun 10 12:40:45 2015: ERROR: ALSA: Cannot open PCM device alsa_pcm for playback. Falling back to capture-only mode
Wed Jun 10 12:40:45 2015: configuring for 44100Hz, period = 1024 frames (23.2 ms), buffer = 2 periods
Wed Jun 10 12:40:45 2015: ALSA: final selected sample format for capture: 16bit little-endian
Wed Jun 10 12:40:45 2015: ALSA: use 2 periods for capture
Wed Jun 10 12:40:50 2015: ERROR: JackPosixProcessSync::LockedTimedWait error usec = 5000000 err = Connection timed out
Wed Jun 10 12:40:50 2015: ERROR: Driver is not running
Wed Jun 10 12:40:50 2015: ERROR: Cannot open client name = dbusapi
Wed Jun 10 12:40:50 2015: ERROR: failed to create dbusapi jack client
12:41:19.166 Kon niet verbinden als client met de JACK server. - Gehele toepassing gefaald. - Server communicatie fout. Gelieve het berichten venster te lezen voor meer info.
Wed Jun 10 12:41:19 2015: ERROR: JackPosixProcessSync::LockedTimedWait error usec = 5000000 err = Connection timed out
Wed Jun 10 12:41:19 2015: ERROR: Driver is not running
Wed Jun 10 12:41:19 2015: ERROR: Cannot create new client
Wed Jun 10 12:41:20 2015: ERROR: ALSA: poll time out, polled for 34828082 usecs
Wed Jun 10 12:41:20 2015: ERROR: JackAudioDriver::ProcessAsync: read error, stopping...
Wed Jun 10 12:41:20 2015: Released audio card Audio0
Wed Jun 10 12:41:20 2015: Saving settings to "/home/ubuntu/.config/jack/conf.xml" ...
Gek is dat ik wel in ff geluid heb maar als ik jack opstart het uitvalt en vast loopt. Ik draai ubuntu in virtualbox ook handig et weten.
Verstand van 'Alles' van 'Niets'
  • CAPSLOCK2000
  • Laatst online: 19:55
CAPSLOCK2000
zie teletekst pagina 888
Wat heb je zelf al geprobeerd om het op te lossen?
Het is niet de bedoeling dat je hier je problemen dumpt en hoopt dat wij het voor je oplossen.
Op internet zijn er zat mensen te vinden met vergelijkbare problemen. Probeer eens wat van de oplossingen die hun wordt aangeraden. Controleer bv eens of er wel gebruikt wordt gemaakt van de juiste geluidskaart.
Heb je jack overigens echt nodig? Dat is voor voor geavanceerde professionele toepassingen.
This post is warranted for the full amount you paid me for it.
