Nieuwe versie VirtualBox released.
  • ShellGhost
  • Laatst online: 16-12-2021
Oracle heeft VirtualBox 5 RC1 vrij gegeven.
Download: http://dlc-cdn.sun.com/virtualbox/5.0.0_RC1/index.html
Schaamtelozen kopie/pasta actie van hun site: https://forums.virtualbox.org/viewtopic.php?f=15&t=68141
VirtualBox 5.0 will be a new major release. Here is an incomplete list of changes since VirtualBox 5.0 Beta 4:
GUI: NLS fixes. NLS strings are now frozen.
GUI: Improved HiDPI support for Windows host, icons/size-hint adjustments.
GUI: Use fast scaling mechanism for integer scale-factors (s. a. here).
Separate UI/VM: fixed completely broken re-attaching to a headless VM.
Drag and drop: fixed hang when reporting host errors such as inaccessible (locked) files.
PCNet: OpenStep fix (bug #10545)
Host-only networking: an attempt to fix some VERR_SUPDRV_COMPONENT_NOT_FOUND problems
NAT: Don't forcibly reset/drop all connections when link goes down
AHCI: fixed a possible hang during VM shutdown
Audio: fix audio output if the default output device changes, before this fix it would always stream to the output device being the default when the VM was started
VBoxSVC: don't keep the support driver permanently open
VBoxManage addencpassword: read the command line from the console or from a file
vbox-img: added resize command
X11 Additions: fix for X.org servers with RandR 1.1
Mocht dit hier verkeerd staan, mijn excuus. :)
  • Rhapsody
  • Laatst online: 08:28
Rhapsody
In Metal We Trust
Hier kun je terecht voor software/firmware updates: http://tweakers.net/submit/
🇪🇺 pro Europa!
  • ShellGhost
Rhapsody schreef op woensdag 10 juni 2015 @ 10:53:
Ah. Dank je wel voor de link. :)
