• Paultje3181
  • Laatst online: 00:41
Ik probeer zelf in exim een domain alias optie te maken. Nu heb ik volgens mij de goede mysql-codes om de alias te herleiden naar een bestaand adres. Maar ik krijg de volgende foutmelding, waardoor hij niet verder gaat:
29
30
routing info@alias.nl
--------> dnslookup_relay_to_domains router <--------
local_part=info domain=alias.nl
checking domains
search_open: mysql "NULL"
search_find: file="NULL"
  key="SELECT fqdn AS domain FROM domains WHERE fqdn='alias.nl' AND type='local' AND active=1" partial=-1 affix=NULL starflags=0
LRU list:
internal_search_find: file="NULL"
  type=mysql key="SELECT fqdn AS domain FROM domains WHERE fqdn='alias.nl' AND type='local' AND active=1"
database lookup required for SELECT fqdn AS domain FROM domains WHERE fqdn='alias.nl' AND type='local' AND active=1
MySQL query: SELECT fqdn AS domain FROM domains WHERE fqdn='alias.nl' AND type='local' AND active=1
MYSQL new connection: host=127.0.0.1 port=0 socket=NULL database=maildb user=email
MYSQL: no data found
lookup failed
  cached open
  key="SELECT domain_aliases.alias_fqdn AS domain FROM domain_aliases,domains WHERE domain_aliases.alias_fqdn='alias.nl' AND domain_aliases.id=domains.id AND domain_aliases.active=1" partial=-1 affix=NULL starflags=0
LRU list:
  type=mysql key="SELECT domain_aliases.alias_fqdn AS domain FROM domain_aliases,domains WHERE domain_aliases.alias_fqdn='alias.nl' AND domain_aliases.id=domains.id AND domain_aliases.active=1"
database lookup required for SELECT domain_aliases.alias_fqdn AS domain FROM domain_aliases,domains WHERE domain_aliases.alias_fqdn='alias.nl' AND domain_aliases.id=domains.id AND domain_aliases.active=1
MySQL query: SELECT domain_aliases.alias_fqdn AS domain FROM domain_aliases,domains WHERE domain_aliases.alias_fqdn='alias.nl' AND domain_aliases.id=domains.id AND domain_aliases.active=1
MYSQL using cached connection for 127.0.0.1/maildb/email
[b]lookup yielded: alias.nl
alias.nl in "@:localhost::alias.nl"? no (end of list)[/b]
alias.nl in "empty"? no (end of list)
alias.nl in "! +local_domains : +relay_to_domains"? no (end of list)
dnslookup_relay_to_domains router skipped: domains mismatch
Volgens mij zou het dikke stukje een yes moeten zijn: yes (matched "alias.nl")
Waar zou ik kunnen beginnen om dit op te lossen? in /etc/exim4/conf.d/main/000_mainlocal staat de $:localhost::[query om alias.nl te krijgen]
  • Sneezydevil
  • Laatst online: 29-09-2025
Wat doet die "::" precies kan het zo snel niet in de exim handleiding vinden, ik heb hier in een vergelijkbare situatie "@ : localhost : Query" staan.
Hoewel dat niet helemaal waar is wat ik daar zeg, bij mij staat het er zo:
domainlist local_domains_from_db = ${query}
domainlist local_domains = @ : localhost : +local_domains_from_db
  • Paultje3181
De : is een separator. Er staat @ localhost query1 query2
  • Sneezydevil
Ja snap het nu je hebt 2 queries achter elkaar staan, en aangezien de eerste leeg is staat er twee keer achter elkaar :, ik dacht even dat 2 seperators achter elkaar misschien een speciale betekenis had.
  • Paultje3181
Blijkbaar wel dus. Ik heb tussen de twee queries de @ gezet (iets andere volgorde dus) en nu werkt het...
Vaag
  • Paultje3181
En voor de volledigheid: het is belangrijk dat je een redirect router schrijft met je query als data. Deze moet de herschreven mail worden.
