Java error , Raspberry-PI
  • 367 views
  • itcouldbeanyone
  • Laatst online: 27-10 08:02
hi, ik probeer processing aan de praat te krijgen op een raspberry pi
programma start op, maar zodra ik een sketch start
krijg ik dit te zien
java.io.IOException: Cannot run program "/home/pi/processing-2.2.1/java/bin/java": error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1041)
at java.lang.Runtime.exec(Runtime.java:617)
at java.lang.Runtime.exec(Runtime.java:485)
at processing.core.PApplet.exec(PApplet.java:4041)
at processing.mode.java.runner.Runner$1.run(Runner.java:437)
at java.lang.Thread.run(Thread.java:724)
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.forkAndExec(Native Method)
at java.lang.UNIXProcess.<init>(UNIXProcess.java:135)
at java.lang.ProcessImpl.start(ProcessImpl.java:130)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1022)
... 5 more
Exception in thread "Thread-8" java.lang.RuntimeException: Could not open /home/pi/processing-2.2.1/java/bin/java -agentlib:jdwp=transport=dt_socket,address=8219,server=y,suspend=y -Djava.library.path=:/usr/java/packages/lib/arm:/lib:/usr/lib -cp /tmp/Rotate422050672793705994temp:/home/pi/processing-2.2.1/core/library/gluegen-rt-natives-linux-armv6hf.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt-natives-macosx-universal.jar:/home/pi/processing-2.2.1/core/library/jogl-all-natives-windows-amd64.jar:/home/pi/processing-2.2.1/core/library/jogl-all-natives-linux-amd64.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt-natives-linux-i586.jar:/home/pi/processing-2.2.1/core/library/jogl-all-natives-linux-armv6hf.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt-natives-windows-amd64.jar:/home/pi/processing-2.2.1/core/library/jogl-all-natives-windows-i586.jar:/home/pi/processing-2.2.1/core/library/core.jar:/home/pi/processing-2.2.1/core/library/jogl-all.jar:/home/pi/processing-2.2.1/core/library/jogl-all-natives-macosx-universal.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt-natives-windows-i586.jar:/home/pi/processing-2.2.1/core/library/jogl-all-natives-linux-i586.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt-natives-linux-amd64.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt-natives-linux-armv6hf.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt-natives-macosx-universal.jar:/home/pi/processing-2.2.1/core/library/jogl-all-natives-windows-amd64.jar:/home/pi/processing-2.2.1/core/library/jogl-all-natives-linux-amd64.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt-natives-linux-i586.jar:/home/pi/processing-2.2.1/core/library/jogl-all-natives-linux-armv6hf.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt-natives-windows-amd64.jar:/home/pi/processing-2.2.1/core/library/jogl-all-natives-windows-i586.jar:/home/pi/processing-2.2.1/core/library/core.jar:/home/pi/processing-2.2.1/core/library/jogl-all.jar:/home/pi/processing-2.2.1/core/library/jogl-all-natives-macosx-universal.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt-natives-windows-i586.jar:/home/pi/processing-2.2.1/core/library/jogl-all-natives-linux-i586.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt-natives-linux-amd64.jar:/usr/lib/jvm/jdk-7-oracle-armhf/jre/bin/../../jre/lib/rt.jar:/home/pi/processing-2.2.1/lib/ant-launcher.jar:/home/pi/processing-2.2.1/lib/ant.jar:/home/pi/processing-2.2.1/lib/antlr.jar:/home/pi/processing-2.2.1/lib/com.ibm.icu_4.4.2.v20110823.jar:/home/pi/processing-2.2.1/lib/jdi.jar:/home/pi/processing-2.2.1/lib/jdimodel.jar:/home/pi/processing-2.2.1/lib/jna.jar:/home/pi/processing-2.2.1/lib/org-netbeans-swing-outline.jar:/home/pi/processing-2.2.1/lib/org.eclipse.osgi_3.8.1.v20120830-144521.jar:/home/pi/processing-2.2.1/lib/pde.jar:/home/pi/processing-2.2.1/core/library/core.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt-natives-linux-amd64.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt-natives-linux-armv6hf.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt-natives-linux-i586.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt-natives-macosx-universal.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt-natives-windows-amd64.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt-natives-windows-i586.jar:/home/pi/processing-2.2.1/core/library/gluegen-rt.jar:/home/pi/processing-2.2.1/core/library/jogl-all-natives-linux-amd64.jar:/home/pi/processing-2.2.1/core/library/jogl-all-natives-linux-armv6hf.jar:/home/pi/processing-2.2.1/core/library/jogl-all-natives-linux-i586.jar:/home/pi/processing-2.2.1/core/library/jogl-all-natives-macosx-universal.jar:/home/pi/processing-2.2.1/core/library/jogl-all-natives-windows-amd64.jar:/home/pi/processing-2.2.1/core/library/jogl-all-natives-windows-i586.jar:/home/pi/processing-2.2.1/core/library/jogl-all.jar -ea processing.core.PApplet --editor-location=712,242 --external --display=0 Rotate --sketch-path=/home/pi/processing-2.2.1/modes/java/examples/Basics/Transform/Rotate
at processing.core.PApplet.exec(PApplet.java:4044)
heeft iemand een ide ? oplossing ? :)
Ben niet slim, maar wel dom
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
Pfoe, heb ik effe een stapel leesvoer voor je zeg :D
Kan iemand even...?
Help, mijn script werkt niet (goed)
Debuggen: Hoe doe ik dat?
Hoe post je code?
En tot slot: onze Quickstart: Wat heb je zelf al geprobeerd/gezocht/gevonden etc.? GoT is geen afhaalchinees waar je lekker je code (of stacktrace) kunt dumpen en vervolgens iemand op een zilveren dienblad je oplossing komt aandragen ;)
En zo te zien ben je al eerder gewezen op hoe we hier werken...
Verder is 't misschien handig als je de foutmelding gewoon even leest? "No such file or directory"... Lijkt me op z'n minst een hint die je in de goede richting moet wijzen?
[ Voor 16% gewijzigd door RobIII op 22-04-2015 11:17 ]
Je eigen tweaker.me redirect
Over mij
