JS: Function not working
  • 339 views
For some weird reason my function isn't working and I was wondering what im missing, I'll try to explain.
When you first load the website it needs to load a function, after this it will start loading into divs.
Code in my div (Also tried: body onload or in the header)
<script type="text/javascript">
<?php
if(empty($write_page['1'])) {
loadthisframe(home);
<?php
else
var <?php echo $write_page['1']; ?>;
loadthisframe(<?php echo $write_page['1']; ?>);
<?php
</script>
So i stripped down the complete function to test:
function loadthisframe(loadthisframe) {
    console.log("load page");
The code above will display something like:
</script>
or
var contact;
loadthisframe(contact);
</script>
This is based on what page you are at,
But it doesn't work, when I delete the "var <?php echo $write_page['1']; ?>;"
I get the following: "ReferenceError: home is not defined"
The rest of the website works fine, its not that its waiting for jquery or so..
When i click on a existing tab, which does the same (kinda), works fine.
$('#tabhome').bind('click', function(event) {
var home = "home";
loadpageframe(home);
window.history.pushState("object or string", "Title", "/");
I also tried replacing loadthisframe with loadpageframe but there is where the problem started so i'm trying to strip down till i find the issue.
  • HamuNaptra
Can you reproduce the issue in a codepen?
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
Can you create a new topic in Dutch?
Je eigen tweaker.me redirect
Over mij
