• huberthoeve
  • Laatst online: 18-02 09:17
Hoi,
Ik heb dit ook al gevraagd op het OPO forum maar krijg nog weinig reactie.
Vanwege het gemakt plak ik het even direct over uit de OP op het OPO forum.
Two days ago I decided to switch from cm12 nightlies to cm12s.
After performing a clean flash I was very pleased to see that I even had the option to restore the apps I had installed before. However, when trying to install those apps I encountered a problem. Because the apps would not download. They would say "Downloading"but it woult get stuck forever.
I had never experienced such problem before but so I thought it was the cm12s flash. So, I flashed back to the latest cm12 nightly I still had on my OPO with the hope that the problem would have vanished. Unfortunately it didn't.
MY PROBLEM:
When I try to install apps from the play store they get stuck in an endless loop of "downloading".
What I tried so far:
flashing back to a normal cm12 nightly
flashing cm11s and after that upgrading to cm12s (in cm11s the problem also persists, same for SOKP-rom to see if it would also persist in a different rom)
rebooting with and without superSU after flashing OS.
entirely wiping my phone (cache, dalvik cache, system, data) and flashing cm12/s
after the step above^, deleting the data and/or cache from "Google Play Services", "Google play Store", "Google Play Framework" (and if possible deleting updates so it goes back to factory app)
changing location settings
deleting google account and re adding it.
clearing Cache and Dalvik Cache multiple times
using the 1-Click installer from this forum
Perhaps even more but I can't quite remember much more...
I experienced after flashing a new os multiple times that the problem is not really the play store and/or the apps in it. But I believe the problem is more with the "Google Play Services" because most of the apps I can update perfectly fine but the "Google Play Services" continuously refuse to update and get stuck at "downloading". Unfortunately that app is needed to be able to use e.g "Gmail".
Hopefully there are more people on this forum who have experienced this problem before and know how to fix it.
Na 3 dagen nog niet aangepast naar Nederlands, dus op slot
[ Voor 1% gewijzigd door 13art op 23-04-2015 08:49 ]
  • 13art
  • Laatst online: 12:08
13art
Moderator Mobile
Begin eens met alles gewoon in het Nederlands te zetten. We zijn een Nederlands forum, geen Engels.
Enjoy the silence...
