Survey dewire-er
  • 231 views
  • Mattie20
  • Laatst online: 02-02 09:55
Dear Tweakers,
I had an assignment for my school subject English to invent a new product that would make your everday life a bit easier and more comfortable. When I was thinking of an invention, I noticed all my wires behind my desk (for example (micro-)USB, audio jack etc.) and I thought can't that be solved on a more simple way?
That's how I created the idea of the dewire-er, a device that you can connect with your (already existing) wires and that transforms your wired signal into a wireless signal! In this way, your wires can't be entangled anymore, cause you put a sender on the beginning of the wire and a receiver on the end of the wire. Just for the record, this won't be a real existing product, it's just an idea.
I'm very curious how people will react on my idea, so I made a survey, the link of the site is below the page. Would you be so kind to fill in the survey (only 5 little questions). It will help me a lot with my assignment. You can answer the questions in English or in Dutch, according to what you prefer.
Thanks in advance!
Link to the survey: http://www.survio.com/survey/d/Z2R4A7G5D1G9C3K1L
  • __R__
  • Laatst online: 18:10
So you made a box which connects tot all your wires so it can connect with a nother box connected tot wires. And they communicate trough wireless.
Wireless Communications needs power. Congratulations. You have just added 2 more wires to your "problem".
_/-\o_
[ Voor 3% gewijzigd door __R__ op 13-04-2015 22:03 ]
  • Mattie20
However with my box, all your wires are on a central place and not just somewhere around. And sure wireless communications needs power, but that amount is negligible in comparison to the annual use of electricity.
  • _ferry_
_ferry_
Moderator Tweaking
Nipple Tweaker
Sorry, but our forum is primary Dutch. And we don't allow surveys either.
