fortiwifi -30B resetten/configureren
Deze wifi router heeft geen resetknop en is niet benaderbaar via de opgegeven ip adressen via netwerkkabel en ook via het fortinet management programma via usb is deze niet te benaderen. ik heb ook als opgegeven bij de fortinet site het ip adres van mijn netwerk adapter veranderd. Werkt niet. Ik vermoed dat de router zich in een soort onzichtbare consolemodus bevindt. Iemand ervaring met de fortiwifi -30B?
  • Cave_Boy
  • Laatst online: 12:03
Restore factory defaults
There may be a point where need to reset the FortiGate unit to its original defaults; for example, to begin with a fresh configuration. There are two options when restoring factory defaults. The first resets the entire device to the original out-of-the-box configuration:
To reset the FortiGate unit to its factory default settings - web-based manager
1. Go to System > Dashboard > Status.
2. In the System Information widget, select Restore for the System Configuration.
3. Select Restore Factory Defaults at the top of the page.
You can reset using the CLI by entering the command:
execute factoryreset
When prompted, type y to confirm the reset.
Alternatively, in the CLI you can reset the factory defaults but retain the interface and VDOM configuration.
Use the command:
execute factoryreset2
Staat op de website van Fortinet. http://docs-legacy.fortin...elp/using_cli.095.02.html
Conecten naar de CLI:
Connecting to the CLI
You can access the CLI in two ways:
• Locally — Connect your computer directly to the FortiGate unit’s console port. Local access is required in some cases:
• If you are installing your FortiGate unit for the first time and it is not yet configured to connect to your network, unless you reconfigure your computer’s network settings for a peer connection, you may only be able to connect to the CLI using a local serial console connection. For more information, see “Connecting to the CLI”.
• Restoring the firmware utilizes a boot interrupt. Network access to the CLI is not available until after the boot process has completed, making local CLI access the only viable option.
• Through the network — Connect your computer through any network attached to one of the FortiGate unit’s network ports. The network interface must have enabled Telnet or SSH administrative access if you will connect using an SSH/Telnet client, or HTTP/HTTPS administrative access if you will connect using the CLI Console widget in the web-based manager.
Dank je Cave _ boy maar helaas kom ik al niet in de web - based manager. Ik denk dat het default ip adres is gewijzigd of zo. Ik zal waarschijnlijk via een consolecable de console poort moeten benaderen. Maar die heb ik nog niet. Ik hou je op de hoogte
  • Hazzz-E
  • Laatst online: 11-09-2025
Hazzz-E
Que?
Op een FortiGate/FortiWifi heb je vaak te maken met Trusted Hosts voor de admin users.
Als het netwerk waar jij in zit, zich daar niet in bevind zal je geen verbinding kunnen maken. Ook niet via FortiExplorer (USB).
Het beste is om via de console poort via het pre-boot menu het boot device te formateren en dan via TFTP de firmware er nogmaals in te flashen.
Overigens heb je voor Forti devices niet perse een fortinet console kabel nodig. Een HP of Cisco console kabel werkt ook.
Succes !
Hey Hazzz - E de kabel die ik van fortiwifi had gezien was er een met een RJ45 connector aan de ene kant en een soort vga connector aan de andere kant. Zijn die van HP en Cisco anders?
  • Hazzz-E
Hazzz-E
Que?
Het zijn allemaal seriele kabels. Met aan de ene kant RS232 en aan de andere kant idd een RJ45 connector.
