Intel 320 series SSD Bad Context 13x Error
  • Rainbow
  • Registratie: Maart 2014
Eén van mijn SSDs is er plotseling mee opgehouden: de computer boot niet meer. Na wat nadere inspectie kom ikerachter dat er een probleem is met de SSD. Het moederbord en de rest van de computer is al uitgesloten, want ook in een andere computer is deze schijn onleesbaar.
In Linux zie ik in "dmesg" het volgende:
[2241712.819310] scsi 23:0:0:0: Direct-Access     Generic  STORAGE DEVICE   9451 PQ: 0 ANSI: 0
[2241712.825852] sd 23:0:0:0: Attached scsi generic sg0 type 0
[2241712.830937] sd 23:0:0:0: [sda] Attached SCSI removable disk
[2241713.657805] usb 1-1.2.1: new high-speed USB device number 38 using dwc_otg
[2241713.758946] usb 1-1.2.1: New USB device found, idVendor=13fd, idProduct=1340
[2241713.758984] usb 1-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[2241713.758999] usb 1-1.2.1: Product: External
[2241713.759013] usb 1-1.2.1: Manufacturer: Generic
[2241713.759027] usb 1-1.2.1: SerialNumber: XXXX445X435458202020XXXX
[2241713.760633] usb-storage 1-1.2.1:1.0: USB Mass Storage device detected
[2241713.764024] scsi24 : usb-storage 1-1.2.1:1.0
[2241714.758560] scsi 24:0:0:0: Direct-Access     Generic  External         2.10 PQ: 0 ANSI: 4
[2241714.766006] sd 24:0:0:0: [sdb] 16384 512-byte logical blocks: (8.38 MB/8.00 MiB)
[2241714.766774] sd 24:0:0:0: [sdb] Write Protect is off
[2241714.766808] sd 24:0:0:0: [sdb] Mode Sense: 21 00 00 00
[2241714.767098] sd 24:0:0:0: Attached scsi generic sg1 type 0
[2241714.769578] sd 24:0:0:0: [sdb] No Caching mode page found
[2241714.769619] sd 24:0:0:0: [sdb] Assuming drive cache: write through
[2241714.772533] sd 24:0:0:0: [sdb] No Caching mode page found
[2241714.772568] sd 24:0:0:0: [sdb] Assuming drive cache: write through
[2241714.773925]  sdb: unknown partition table
[2241714.779568] sd 24:0:0:0: [sdb] No Caching mode page found
[2241714.779611] sd 24:0:0:0: [sdb] Assuming drive cache: write through
[2241714.779637] sd 24:0:0:0: [sdb] Attached SCSI disk
Waarin dus duidelijk te zien is: "sdb: unknown partition table", ook al heeft deze schijf gewoon een normale partitie tabel met 1 (Windows) partitie.
Ook de smartctl -a output ziet er niet goed uit:
$ sudo smartctl -a /dev/sdb
smartctl 5.41 2011-06-09 r3365 [armv6l-linux-3.12.28+] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family:     Intel 320 Series SSDs
Device Model:     INTEL SSDSA2CW120G3
Serial Number:    BAD_CTX     00000130
LU WWN Device Id: 5 001517 95954c4a1
Firmware Version: 4PC10302
User Capacity:    8,388,608 bytes [8.38 MB]
Sector Size:      512 bytes logical/physical
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   8
ATA Standard is:  ATA-8-ACS revision 4
Local Time is:    Tue Mar  3 19:22:36 2015 CET
SMART support is: Unavailable - device lacks SMART capability.
A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options.
Hij geeft dus op de een of andere manier aan dat er maar iets meer dan 8MB capaciteit is, terwijl dit een 120GB SSD is. Ook kunnen er geen andere SMART gegevens geladen worden (al weet ik niet of dat normaal is voor SSDs).
Het gaat hier overigens om een Intel SSD 320 Series 120GB van 4 jaar oud.
Mijn vraag is, zijn er trucjes die ik kan uithalen om de oorzaak te achterhalen, en eventueel iets te fixen? Bij reguliere hard disks heb ik alleen dit soort problemen gezien als de hard disk ook echt lawaai maakt, en vaak na meerdere SMART errors (dus dan zag ik het al aankomen, en gebruikte de schijf ook niet meer voor iets belangrijks).
Ik kan zo 1-2-3 niet echt heel veel informatie vinden via Google of op GOT over een soortgelijk issue. Ik begin een beetje bang te worden dat dit niet meer te repareren is. :/
  • Rainbow
Oei wat ben ik dom, Google ik nog een keer, vind ik: https://communities.intel.com/thread/24121?tstart=0 en https://communities.intel.com/thread/24205?tstart=0
Ziet er naar uit dat ik pech heb en de hard disk moet erasen... :(
Ach, helaas, ik kan de topic titel niet aanpassen. Anders zou ik er zoiets van maken als "Intel 320 series SSD Bad Context 13x Error".
[ Voor 26% gewijzigd door Rainbow op 03-03-2015 19:47 ]
  • br00ky
  • Laatst online: 15:37
br00ky
Rainbow schreef op dinsdag 03 maart 2015 @ 19:31:
Fixed :).
  • Reepje
Je had ook kunnen googlen op 8 mb bug intel 320.
  • Rainbow
Thanks!
Reepje schreef op dinsdag 03 maart 2015 @ 21:21:
Ja dat is dus het vreemde, hier had ik op gezocht, maar niets gevonden. Ik zal wel een rare typo gemaakt hebben ofzo. :?
Nu wordt het wel zoeken of er ergens iemand is die dit kan fixen, eventueel voor een prijs. Als iemand ideeën heeft hoor ik ze graag in ieder geval. Ik zal zelf ook wel verder zoeken.
  • Rainbow
Enige die ik kan vinden, is deze partij: http://www.datarecovery.net/articles/intel-ssd-BAD_CTX.html
Maar op het moment dat je telefonisch een quote moet gaan aanvragen, weet je al dat het niet goedkoop zal zijn. Daarnaast zou je ook wel denken dat in die 4 jaar er anderen zouden zijn die het probleem al hebben weten op te lossen, dus dat zet ook wel vraagtekens bij deze partij...
Dat wordt dus terugzetten van back-up, die helaas al super oud is (computer niet in mijn gebruik, maar een kennis, die daar schijnbaar niet zo strict mee is). Laat wel weer zien hoe belangrijk een back-up is.
  • Reepje
Vergeet niet de firmware te updaten. Toen deze bug bekend werd, is er een firmware update uitgebracht die dit voorkomt. Dat was 2011. Het is een goed idee om de boel up-to-date te houden. En natuurlijk is het een goed idee een goede back-up strategie te hebben als je data je lief is.
