Butget gaming PC ~320euro (without GPU) - ENG
  • 369 views
  • Jokerr192
  • Registratie: Februari 2015
  • Laatst online: 31-05-2022
What do you do with your new system?
Gaming (GTA 5, Dying Light, War Thunder, BF3/4)
What can the system cost? Do you have an absolute maximum? Including or excluding shipping, assembly and the like?
Around 320 euro, without GPU, and WiFi adapter
Are there any components or peripherals that you already have and want to take it to your new system? Be specific and name brand and model.
I already have Sapphire R9 280X Toxic, and an WIFI adapter
What do you think you all need?
At least 8GB of ram
Do you still have some (brand) preferences? Why So?
I would prefer Intel core, rather than AMD, someone said that Intel is better for gaming, but if You think AMD would work better, and it performs better in the PC I'm assembling than I will stay with that
Do you have any specific requirements / needs? (Size, noise, power consumption, etc.)
I do own a laptop and while gaming it sounds like a jet during a takeoff, so something below that amount of noise would be perfect
Are you going to overclock?
If it would be possible to overclock, than Yes, but if the PC would handle everything nicely, then I would not bother with it
My Dutch isn't perfect, but I can use google translate if needed.
As I wrote, I do own Sapphire R9 280X Toxic, and WI-Fi adapter.
[ Voor 46% gewijzigd door Jokerr192 op 09-02-2015 18:00 ]
  • PDZ
  • Laatst online: 26-09 09:59
PDZ
The intention is that you come up with a list yourself. Please read the so called ''DAA Beleid'' carefully. After that, we should be able to help you. Good luck!
De tiid hâldt gjin skoft.
  • JaapN
  • Laatst online: 12:12
As i see you already have a fairly decent GPU. I came up with this:
#ProductPrijsSubtotaal
1AMD Athlon X4 860K Boxed€ 68,95€ 68,95
1MSI A78M-E45€ 48,95€ 48,95
1WD Blue WD10EZEX, 1TB€ 53,50€ 53,50
1Fractal Design Core 1000 USB 3.0€ 31,95€ 31,95
1Crucial Ballistix BLS2CP4G3D1609DS1S00CEU€ 63,-€ 63,-
1Antec VP450P€ 34,95€ 34,95
Bekijk collectie
Importeer producten
Totaal€ 301,30
The X4 860K Is a solid Quad Core CPU for the price, for a bit lower you could get the pentium G3258 which is better per core. However since the 860K Has more cores it will do better in multi threaded workloads
The A78M-E45 is also a good motherboard for the price featuring 4 DIMM Slots and 2 PCI-E X16 lanes for crossfire. It also offers plenty of upgradability
The ram I used is a personal favorite, cheap and realiable. Rocking it in my own system too.
The WD Blue is a 1 terabyte drive, should over plenty of fast and reliable storage for all your games and programs
The Basiq VP-450P is also a good PSU For the price, combining both a high wattage and silence for a low price.
Then the Core 1000, often called "the best case for those who are on a budget", it has room, plenty of it. Even Though it is kinda small.
Although i made a list for you now, at Tweakers we mostly expect some own effort by (atleast trying to) make your own list
The best thing you could do to decrease noise production is by getting an aftermarket CPU cooler
  • NitroX infinity
  • Laatst online: 18:17
1; Seagate 1TiB HDD is a bit cheaper.
2; Antec VP450P is not such a good psu. Cooler Master GM G450M perhaps?
3; case; pricewatch: Cooler Master N300 (KKN1, closed) has more room for the cpu cooler.
Graphene; a material that can do everything, except leave the lab. - Asianometry
  • PDZ
PDZ
I would replace the HDD with this SSD: pricewatch: Crucial MX100 128GB. If the SSD has not enough space, you can add an HDD later. With an SSD your computer will feel a lot faster.
[ Voor 13% gewijzigd door PDZ op 09-02-2015 17:56 ]
  • JaapN
NitroX infinity schreef op maandag 09 februari 2015 @ 17:52:
A better PSU would be this one, it has 2x 6+2 pins PCI Power, which are required for the GPU, the Coolermaster, Does not (it does oops)
[ Voor 1% gewijzigd door JaapN op 09-02-2015 17:58 . Reden: typo ]
  • br00ky
  • Laatst online: 19:55
br00ky
Tweakers is een Nederlandstalig forum, dus helaas moet ik dit topic op grond van dat gegeven sluiten, naast dat een eigen lijst ontbreekt.
[ Voor 15% gewijzigd door br00ky op 09-02-2015 18:03 ]
