• NeFoRcE
  • Laatst online: 15:20
NeFoRcE
Hallo? Bent u daar?
Heren,
op dit moment ben ik een (retetrage) backup aan het maken van mijn data van m'n iomega storcenter (wat een kommer en kwel apparaat).
Middels de diagtools zijn de volgende smart reports naar voren gekomen:
SDA
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   085   075   006    Pre-fail  Always       -       57535567
  3 Spin_Up_Time            0x0003   095   094   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       23
  5 Reallocated_Sector_Ct   0x0033   051   051   036    Pre-fail  Always       -       64896
  7 Seek_Error_Rate         0x000f   066   060   030    Pre-fail  Always       -       5039063
  9 Power_On_Hours          0x0032   087   087   000    Old_age   Always       -       11492
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       23
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   001   001   000    Old_age   Always       -       964
188 Command_Timeout         0x0032   100   091   000    Old_age   Always       -       206161707063
189 High_Fly_Writes         0x003a   099   099   000    Old_age   Always       -       1
190 Airflow_Temperature_Cel 0x0022   044   038   045    Old_age   Always   FAILING_NOW 56 (24 116 57 50)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       22
193 Load_Cycle_Count        0x0032   089   089   000    Old_age   Always       -       23425
194 Temperature_Celsius     0x0022   056   062   000    Old_age   Always       -       56 (0 21 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       192032282772608
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       236402876032
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       125014522823120
SDB
  1 Raw_Read_Error_Rate     0x000f   116   099   006    Pre-fail  Always       -       106519592
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       49
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   067   060   030    Pre-fail  Always       -       6051148
  9 Power_On_Hours          0x0032   087   087   000    Old_age   Always       -       12159
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       49
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   049   039   045    Old_age   Always   In_the_past 51 (3 58 51 46)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       48
193 Load_Cycle_Count        0x0032   088   088   000    Old_age   Always       -       25216
194 Temperature_Celsius     0x0022   051   061   000    Old_age   Always       -       51 (0 20 0 0)
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       131164006253786
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       104031563222
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       41096109337286
De nas heeft sinds vele maanden ineens weer aangegeven dat een schijf faalde. Reboot,en hij deed het weer. Schijf is al een keer vervangen geweest (weet alleen zo 1,2,3 niet meer of dat dezelfde is). Nu ben ik een backup aan het maken met ongv 1 MB/s...
Iemand die uit de SMART iets kan aflezen? Ik word er zelf niet echt wijs uit...
  • Swordlord
  • Laatst online: 08-11 20:53
Swordlord
Act first, think never
de disks zijn te warm, als in 60 graden heet...
voor de rest zijn er geen smart fails.
Waar staat je NAS? Of fans misschien kaduk?
Grote kans dat de CPU ook throtteld vanwege de temperatuur en dus brakke doorvoersnelheid..
als die oude (nu kapotte) schijf ook continue in hoge temperatuur heeft gedraaid, dan is het niet vreemd dat ie snel kapot was.
[ Voor 24% gewijzigd door Swordlord op 06-02-2015 00:10 ]
  • NeFoRcE
NeFoRcE
Hallo? Bent u daar?
Ik las op internet dat de fan (4cm) in de nas aanspringt bij 59 graden. Best wel laat als je het mij vraagt.
Verder zag ik in een dumpfile van de NAS dat schijf 1 (die problemen gaf) dat de "ATA ERROR COUNT" op 775 stond. At the moment doe ik een "File System Check". Een optie vanuit de NAS. Zal mij benieuwen.
  • Thralas
  • Laatst online: 09:51
NeFoRcE schreef op vrijdag 06 februari 2015 @ 09:11:
Was dat SDA?
Dat zou een hoop verklaren. Beetje aan de hoge kant voor een realistische waarde, maar kan er goed op duiden dat de schijf brak is.
En gezien de FAILING_NOW van Airflow_Temperature_Cel met (naar ik aanneem) 56 C (en die ander 51 C); dat is toch echt te warm. Je kunt de specs van de disks opzoeken, maar het zou me niet verbazen als die de limiet op 55 C leggen (dat is waar de SMART failed).
  • NeFoRcE
NeFoRcE
Hallo? Bent u daar?
SDA inderdaad. En ja de temp leek mij ook aan de hoge kant...
Iemand enig idee waar ik in kan stellen dat de fan altijd draait ipv vanaf 59C ? Via SSH ofzoiets?
  • Thralas
Het ding draait 'gewoon' Linux?
Dan ligt het er maar net aan in hoeverre Iomega gebruikmaakt van bestaande/gangbare software; dat soort vendors hebben wel eens de neiging om het wiel opnieuw uit te vinden en al die functionaliteit te verstoppen in een grote executable of library zodat je er verder weinig mee kunt.
De meest gangbare manier onder Linux is fancontrol (onderdeel van lm_sensors). Je zou kunnen kijken of er een config file /etc/fancontrol bestaat, en of de fancontrol daemon uberhaupt draait (ps aux | grep fancontrol).
  • NeFoRcE
NeFoRcE
Hallo? Bent u daar?
Dank! Ik zal als ik thuis ben eens even kijken. Onder water wordt linux gebruikt inderdaad.
