Nagios Monitoring Service
Goede avond,
Ik heb een probleempje met de notificaties van nagios naar mijn e-mail.
Ik zou graag willen dat ik een mailke ontvang via de smtp van gmail.
maar ik krijg deze error:
Afbeeldingslocatie: http://i58.tinypic.com/mt7ymc.jpg
Ubuntu 14.04
PHP 5.5
apache2
mysql
Nagios core 4.0.8
Iemand een idee hoe ik port 25 verander naar 587? dan zou het moeten lukken.
resource.cfg:
$USER5$=christiaaaaan.keyers@gmail.com
$USER7$=smtp.gmail.com
$USER9$= christiaaaaaan.keyers@gmail.com
$USER10$= passwoord
command.conf:
# 'notify-host-by-email' command definition define command{ command_name notify-host-by-email command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /usr/local/bin/sendEmail -s $USER7$ -xu $USER9$ -xp $USER10$ -t $CONTACTEMAIL$ -f $USER5$ -l /var/log/sendEmail -u "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" -m "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" }
# 'notify-service-by-email' command definition define command{ command_name notify-service-by-email command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$" | /usr/local/bin/sendEmail -s $USER7$ -xu $USER9$ -xp $USER10$ -t $CONTACTEMAIL$ -f $USER5$ -l /var/log/sendEmail -u "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" -m "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$" }
Alvast bedankt
groetjs
  • CAPSLOCK2000
  • Laatst online: 09:55
CAPSLOCK2000
zie teletekst pagina 888
Normaal gesproken gebruikt Nagios de mailserver die op je systeem staat geinstalleerd. Wat draai je? Postfix?
This post is warranted for the full amount you paid me for it.
  • Hero of Time
  • Laatst online: 22:25
Hero of Time
Moderator LNX
There is only one Legend
Precies, gebruik Postfix voor de authenticatie en relaying naar Gmail. Er zijn genoeg tutorials op 't web om dat te regelen. Je moet wel zorgen dat je 'From:' adres je Gmail adres is, anders kan deze geweigerd worden.
Commandline FTW
  • himlims_
himlims_
🐧 Linux HOoligan
kan zijn dat gmail dit blokkeerd? had vanochtend vergelijkbaar issue met geary, bleek authorisatie technische niet in orde. resultaat dat google het blokkeerde, en niet kon inloggen/mailen.
misschien dat het volgende helpt; askubuntu.com/questions/155248/how-can-i-have-nagios-alerts-emailed-to-my-gmail
//edit;persoonlijke voorkeur voor zabbix over nagios, misschien ook nog interresant?
[ Voor 14% gewijzigd door himlims_ op 04-02-2015 10:15 ]
  • Hero of Time
Hero of Time
Moderator LNX
Je moet idd bij Google aanmelden voordat je mag mailen via relaying. Maak gebruik van Postfix, als je meerdere servers hebt die moeten mailen zet je een enkele machine op om naar Gmail te gaan en stel je de rest in om via die machine te gaan mailen. Maakt het ook veel makkelijker om 'eventjes' van mail relay te veranderen. Je hoeft 't dan tenslotte maar op 1 server te doen.
Voor wat betreft Zabbix vs Nagios, daar kan jij zelf het beste wat over zeggen. Zabbix is best complex en vereist veel tijd om te leren en goed te configureren. Nagios is veel simplistischer en even een machine of check toevoegen is zo gedaan.
Commandline FTW
Ik draai postfix, de mail kan ik nu handmatig verzenden.
enkel nagios wil het nog niet doen voor mij :o
  • vanaalten
  • Laatst online: 13:52
Van wat ik zo zie heb je nagios ingesteld om direct de SMTP van gmail te contacten. Ik denk - als ik bovenstaande goed lees - dat je nagios moet instellen om de lokale SMTP te gebruiken (127.0.0.1 i.p.v. smtp.gmail.com, of zo iets)
  • u_nix_we_all
Je gebruikt volgens de command definitie /usr/local/bin/sendEmail (die praat zelf smtp met google volgens mij) , en die kun je gewoon host:port meegeven, dus als je met poort 587 wilt praten zul je in $USER7$ smtp.gmail.com:587 moeten zetten
You don't need a parachute to go skydiving. You need a parachute to go skydiving twice.
