[Google Drive] Niet opnieuw alle bestanden downloaden
  • maxxy
  • Laatst online: 28-11-2024
Ik ben van plan om binnenkort een schone installatie te doen (wat ik regelmatig doe).
Al mijn bestanden ook opgeslagen om mijn tweede harde schijf, waardoor ik bestanden op mijn pc blijven staan.
Echter als ik Google drive opnieuw download, download drive alle bestanden vanaf de server, terwijl ze ook nog gewoon nog op mijn pc staan.
Is er een mogelijkheid om mijn oude map met Google drive te synchroniseren, zodat alle bestanden niet opnieuw gedownload moeten worden?
  • F_J_K
F_J_K
Moderator CSA/PB/AI
Front verplichte underscores
Zoeken op Google levert me
Hi all,
You can now try an experimental feature which will attempt to reconcile the current documents in your Google Drive with the cloud equivalents in version 1.17 (now available). Please note this is experimental and still in development by our team. If you notice anything in your analysis that does not look right, please do not click 'proceed' in the last step. This only works for the same account and if your documents that were synced locally mirror your cloud contents (this includes hierarchy and actual contents).
In order to try this:
Quit Google Drive if it's running
Open up cmd.exe window on Windows or Terminal.app on OSX
On Windows:
Start the googledrivesync.exe process with the --enable_snapshot_reconstruct flag:
googledrivesync.exe --enable_snapshot_reconstruct
This executable may be located either in C:\Program Files\Google\Drive or C:\Program Files (x86)\Google\Drive depending on your version of Windows.
On OS X:
Start the Google Drive application with the --enable_snapshot_reconstruct flag:
"/Applications/Google Drive.app/Contents/MacOS/Google Drive" --enable_snapshot_reconstruct
Proceed through the setup normally. You will not encounter a warning for selecting a non-empty directory this time.
The application will examine the local contents of your Google Drive and attempt to reconcile them with the cloud version
The application will tell you a summary. If the summary is acceptable to you click proceed. If not (i.e. your local contents have diverged too much from the cloud ones), it is best to simply resync and redownload all your content.
Please let us know your results and experience using this experimental feature, as it will help our team continue to improve it. Thanks for your input!
-R
Geen idee of het werkt. "Gewoon" de download afwachten klinkt veiliger.
