Misschien helpt dit:
(vraag het even aan een developer/iemand die handig is met computers mocht je er niet uit komen ;) )
"Ok guys. I've already done so I won't be able to go back to those pages and take screen shots. So this might not be 100% clear.
On the page with the red button not working press F12 (do it on I.E. just in case... and I hope your I.E. is updated to the same degree as mine, because things could be different).
When you rpess f12 a tab will open on the bottom of the page. If your's is the same as mine, than on the left of that tab there is a black ribbon with several icons.
The first one is "F12" than <arrow> than a box wth > inside and next is a little spider. That is the DEBUGGER button. You could also press CTRL+3 on this version.
When you open it, right below the "debugger" text there is a little folder icon with a arrow pointing down. That is the "open new fle" icon. Click it or, in this version, just hit CTRL O.
type the following in the window
56130e2070f23ccb496fd4fd6ef1469c_1416581504.js
This file will either have 11k+ lines or only 1k+ lines. If its not 11 or something near that, press CTRL SHITF P so that it will reorganize the text.
Go on the search box on the right and type
this.options.onFormValidate
it should highlight that text on line 4409. Now you put your mouse over the line bellow that (it reads "return result") and press f9.
A little red ball should appear and on the right there should have appeared something ends with (4410, 9) on the breakpoint part.
Now you enter your information and click on "save". You will see that the screen will pause (a pause signal will apear). Now go to the right, above the place that apeared the (4410, 9) in a place thats called WATCHES. Double click the "false" thats written in front of "result" and change it to "true".
Click anywhere in the screen and press F5. it should save and you are done.
Try going to the cart again and repeat as necessary."
  • FrankGuthrie
  • Laatst online: 04-10 21:47
FrankGuthrie
I Wanna Be Kate
Heb een makkelijkere oplossing, namelijk javascript uitzetten:
In Google Chrome ga je naar de Setting. Dan naar Advanced Setting dan naar Privacy dan naar Content Setting en dan do not allow any site to run javascript
Ik ben toen naar mijn billing/shipping addres gegaan en heb daar mijn gegeven ingevuld. Daarna javascript aangezet om de checkout te doen, en toen weer Javascript uitgezet om mijn naam en achternaam in te vullen. Vervolgens op Save, en dan kom je er wel doorheen. Wel weer Java script aan zetten. Iedere keer als je dat doenuit/aanzetten, effe F5.
Russian Blue Neji
Kate Bush
Blue Horizon(a website about Star Trek & Babylon 5)
  • CaDje
  • Laatst online: 08-11 08:33
CaDje
Framedrops for life
Derde en laatste keer. 178min left
Members only:
  • binja
  • Laatst online: 17-03-2022
CaDje schreef op zaterdag 22 november 2014 @ 09:01:
Members only:
Zeer dankbaar, kan hem eindelijk gaan bestellen.
  • kukelinho
  • Laatst online: 05-11 16:39
Members only:
Het konings???? was geschreven door John Ewbank ;)
  • ComTech
  • Laatst online: 31-10 19:22
Members only:
De eerste en de laatste letter omwisselen.
  • DaydreamBelieve
  • Laatst online: 19:02
en om ff te puzzelen :)
Members only:
  • hb96
Members only:
Draai de code volledig om, om zo de invite te kunnen claimen.
Hoor graag wie de gelukkig is!
Succes!
  • DaydreamBelieve
meer invites dan mensen die claimen (en dan ook daadwekelijk bestellen)
  • sypie
Die van hb69 was na 20 minuten nog niet geclaimd. Zeldzaam.
Het javascript issue lijkt nu verholpen, mijn Oneplus One komt eraan :)
FrankGuthrie schreef op zaterdag 22 november 2014 @ 01:52:
  • hb96
sypie schreef op zaterdag 22 november 2014 @ 10:29:
Het heeft inderdaad opmerkelijk lang geduurt.
Maar hij is nu geclaimed, weet alleen nog niet door wie...
  • FrankGuthrie
FrankGuthrie
I Wanna Be Kate
Verwijderd schreef op zaterdag 22 november 2014 @ 10:54:
Is dat opgelost, wordt mijn creditcard geweigerd. Flinke uitgaven gedaan aan een INE bootcamp... 8)7
Edit: Geld overgemsakt via Ideal. Is nu dus gelukt.
[ Voor 8% gewijzigd door FrankGuthrie op 22-11-2014 11:40 ]
Russian Blue Neji
Kate Bush
Members only:
XX=GL
laat ff weten als je hem hebt _/-\o_
  • bierglazen
  • Laatst online: 07-11 18:46
Verwijderd schreef op zaterdag 22 november 2014 @ 11:32:
Members only:
XX=GL
Dank je wel, ik heb de derde.
Members only:
XX=GL
Ik heb de eerste. Thx!
  • HaTe
  • Laatst online: 14:50
HaTe
haat niet
https://account.oneplus.net/invite/claim/
BEIDE GECLAIMD!
Members only:
Eerst alle blokjes in de goede volgorde zetten: van 4213 naar 1234
Daarna zelfde voor alle karakters in elk blokje
Members only:
Zelfde, maar dan voor 3142
Succes :)
[ Voor 77% gewijzigd door HaTe op 22-11-2014 14:52 ]
WP: ME PUHZ-SW75YAA + ERST30D-VM2ED | Solar: 17x TSM-340-DE06M.08 (5780Wp ~6200kWh), Azimuth 179°, Hellingshoek: 34° | PC specs
  • MathijsJH
  • Laatst online: 30-10 14:43
HaTe schreef op zaterdag 22 november 2014 @ 13:37:
Succes :)
Bedankt ! :) Ik heb de eerste code. Het is wel op een hele andere manier puzzelen met de tijdsdruk ;-)
  • vdjager
  • Laatst online: 30-04-2025
Members only:
Members only:
4 dagen over! veel plezier ermee.
  • fly guy
@vdjager: Thanks! Ik heb er eentje :-)
  • Thaxje
  • Laatst online: 15-08-2022
Members only:
Members only:
Adios.
Members only:
* = Eerste letter van achternaam van Nederlands meest succesvolle Olympiër. Ireen .....
Members only:
* = Eerste letter voornaam huidige trainer van PSV
Members only:
* = Eerste letter van de achternaam van Nederlands meest succesvolle roeier
  • Snuffert
  • Laatst online: 19:14
Bedankt! De tweede is nu ook geclaimt
[ Voor 46% gewijzigd door Snuffert op 22-11-2014 15:01 ]
hmz...
  • NESFreak
  • Laatst online: 06-11 16:00
Verwijderd schreef op zaterdag 22 november 2014 @ 14:57:
Members only:
tnx, geclaimed
Thaxje schreef op zaterdag 22 november 2014 @ 14:42:
Members only:
Members only:
Adios.
Ik heb er eentje. Dank!
Members only:
Members only:
Members only:
Danku voor de invites, ik heb de 3de geclaimd en ga hem direct bestellen!
  • Katje96
  • Laatst online: 21:02
Katje96 schreef op vrijdag 21 november 2014 @ 15:30:
Nog 6 dagen geldig
Members only:
Members only:
Members only:
Gisteren allemaal geclaimd maar vandaag weer vrij...
  • Droid
  • Laatst online: 19:01
Katje96 schreef op zaterdag 22 november 2014 @ 17:50:
Onderste geclaimed.
  • HaNS1443
  • Laatst online: 06-11 18:39
Middelste geclaimed.
Hartelijk dank!
[ Voor 4% gewijzigd door HaNS1443 op 22-11-2014 18:23 ]
  • Faris
  • Laatst online: 25-11-2022
Bedankt, eerste geclaimd.
  • cabrioot
  • Laatst online: 28-10 10:16
Ik heb de https://account.oneplus.net/invite/claim/GL8R-TRFI-6IEV-UW6J van Vinpower gebruikt ( van 20 november ) , die bleek het nog gewoon te doen ! ) thanks !
  • omniaqwerty
  • Laatst online: 11-08-2020
Verwijderd schreef op zaterdag 22 november 2014 @ 15:17:
zaterdag 22 november 2014 14:42
Thaxje
Members only:
https://account.oneplus.net/invite/claim/GL3L-RSIA-1U0L-SDGD
Members only:
https://account.oneplus.net/invite/claim/GLQX-1NEI-EGTR-ZQI6
En ik heb de andere gebruikt. Tanx a lot
[ Voor 44% gewijzigd door omniaqwerty op 22-11-2014 18:46 ]
  • brutalbasterd
  • Laatst online: 05-11 16:05
Members only:
[ Voor 4% gewijzigd door brutalbasterd op 22-11-2014 18:48 ]
This message was deleted
  • ralfverstappen
  • Registratie: November 2014
  • Laatst online: 22-07-2023
brutalbasterd schreef op zaterdag 22 november 2014 @ 18:46:
Mohttps://account.oneplus.net/invite/claim/GLUM-QYTR-DEUZ-3KRB/mo
Thanks!
  • greyfoxhl
  • Laatst online: 23-08 17:57
Members only:
  • Delsin
  • Laatst online: 19-09-2025
greyfoxhl schreef op zaterdag 22 november 2014 @ 21:09:
Members only:
Dank je wel _/-\o_ ! Meteen omgezet in een order en nu al status 'Pending Shipment'.
  • Azerion
  • Laatst online: 17-08 13:13
gebruikelijke twitter search
Members only:
sorry maar geen zin om ze te versleutelen.
[ Voor 10% gewijzigd door Azerion op 22-11-2014 22:24 ]
  • RHPJS
  • Laatst online: 19-10 23:13
Azerion schreef op zaterdag 22 november 2014 @ 21:53:
Members only:
Hartelijk dank! _/-\o_
Dat er zoveel rondslingert op twitter zeg :)
EDIT: Alle invites zijn al geclaimd zie ik, namens hen zal ik dan wel even een bedankje doen. :9
[ Voor 12% gewijzigd door RHPJS op 22-11-2014 22:18 ]
Dank je! :)
  • tweakerrobin
  • Laatst online: 01-11 10:30
Members only:
Members only:
Members only:
Members only:
Members only:
Goed voor mijn karma 8)7
  • Trick7
  • Laatst online: 03-01-2025
tweakerrobin schreef op zaterdag 22 november 2014 @ 22:25:
Members only:
Hebbes! En idd, goed voor je karma, hardstikke bedankt! :)
  • greyfoxhl
Members only:
  • Maite
  • Laatst online: 22:00
greyfoxhl schreef op zaterdag 22 november 2014 @ 23:24:
Members only:
Bedankt 😄
  • dunedanh
  • Laatst online: 00:08
Ik moet toch eens op wat normalere tijden in dit topic gaan rondhangen, dr komen een hoop invites langs! Toch mooi om te zien dat er ook nog mensen zijn die wel belangeloos een ander willen helpen :D
ik hoop mijn oneplus binnen een paar weken te hebben, de invites die ik dan krijg zullen ook hierheen komen :)
  • kukelinho
kukelinho schreef op zaterdag 22 november 2014 @ 09:23:
Members only:
Deze is weer vrijgekomen. Good luck
kukelinho schreef op zondag 23 november 2014 @ 10:02:
Mijn dank is groot naar u! _/-\o_
  • greyfoxhl
TripleQ schreef op vrijdag 21 november 2014 @ 18:45:
Members only:
Bedank mijn vriendin maar ;-)
en weg....
Deze zijn ook alle drie vrijgekomen. Good luck.
  • bart57
  • Laatst online: 07-12-2021
De eerste heb ik gebruikt, hartelijk dank!
greyfoxhl schreef op zondag 23 november 2014 @ 10:06:
  • Gilbertvv
  • Laatst online: 12-07-2018
De derde heb ik gebruikt; Dank!
  • Joindry
  • Laatst online: 23:02
Joindry
- I'm afraid I can't do that -
Weet iemand hoe lang het duurt (en hoeveel je er krijgt) eer je invites krijgt nadat je zelf een gekocht hebt? Ik heb mijn invite hier verkregen en zal de mijne dus ook doorgeven. Alleen weet ik niet hoe lang ik er op moet wachten. :9
  • Pierre
  • Laatst online: 19:58
Pierre
Van nature lui!
Ben ook wel nieuwsgierig naar dit toestel, kijken of ik een invite kan bemachtigen. Uiteraard zal ik de mijne dan ook hier delen :)
Joindry schreef op zondag 23 november 2014 @ 10:28:
Het heeft niet echt een systeem van wanneer het wordt uitgegeven. Je krijg de invites sowieso wel alleen posten de Staff van OPO wanneer ze de invites van mensen die in de maand xxxx hebben besteld wanneer die het binnen krijgen.
[ Voor 11% gewijzigd door Verwijderd op 23-11-2014 10:42 ]
  • nl03228
  • Laatst online: 18-06 20:27
aan het einde een W toevoegen
Members only:
na claimen heb je 24 uur de tijd om de telefoon met je PayPal te kopen !
heb je geen PayPal, dan svp niet claimen
  • SonyEricsson
  • Laatst online: 07-11 23:27
nl03228 schreef op zondag 23 november 2014 @ 11:24:
Members only:
weg, maar niet door mij :/ toch bedankt
  • DaydreamBelieve
laatste x, rottig encode
Members only:
  • nico445
  • Laatst online: 21:30
Members only:
Members only:
Members only:
  • RoD
RoD
Admin Mobile & FP PowerMod
nico445 schreef op zondag 23 november 2014 @ 13:54:
Members only:
Members only:
Members only:
Dank :)
  • kukelinho
Members only:
Ander woord voor penis = ??? :)
  • kukelinho
vdjager schreef op zaterdag 22 november 2014 @ 14:06:
Members only:
Members only:
Deze doen het ook nog steeds
  • markisoke
  • Laatst online: 18:29
kukelinho schreef op zondag 23 november 2014 @ 17:21:
Members only:
Gebruikt, thanks
  • 82marco
  • Laatst online: 01-10 14:12
kukelinho schreef op zondag 23 november 2014 @ 17:27:
Thx used it
  • greyfoxhl
Members only:
  • daboytim
  • Laatst online: 02-11 07:57
greyfoxhl schreef op zondag 23 november 2014 @ 20:08:
Members only:
Thanks, zojuist geclaimed en besteld! Als ik invites krijg komen die ook hier.
  • FrankGuthrie
FrankGuthrie
I Wanna Be Kate
supernova schreef op vrijdag 21 november 2014 @ 15:51:
Hier zijn drie invites. Zijn nog 5 dagen geldig.
Laat het even weten als ze gebruikt zijn. Veel plezier met het toestel. 8)
Members only:
Zo te zien zijn deze 3 nog beschikbaar.
Zijn dus niet van mij,
Russian Blue Neji
Kate Bush
  • nielske5001
FrankGuthrie schreef op zondag 23 november 2014 @ 20:23:
Ik claimde de eerste thanks!
  • FrankGuthrie
FrankGuthrie
I Wanna Be Kate
Medjai schreef op vrijdag 21 november 2014 @ 15:57:
Nog 6 dagen geldig:
Members only:
Mede mogelijk gemaakt door superericje
Hiervan is de 2de nog geldig. Zie poster, deze zijn ook niet van mij.
Nog 6 dagen geldig
Members only:
Members only:
Members only:
En van hierboven is de 3de nog beschikbaar.
BeAtS schreef op vrijdag 21 november 2014 @ 11:04:
Members only:
De 3de is nog beschikbaar
frankivo schreef op vrijdag 21 november 2014 @ 09:25:
Members only:
* = J
Beschikbaar. Het loont dus om terug te scrollen. Sommige zijn dus weer vrijgekomen.
[ Voor 62% gewijzigd door FrankGuthrie op 23-11-2014 20:48 ]
Russian Blue Neji
Kate Bush
  • FrankGuthrie
FrankGuthrie
I Wanna Be Kate
Waren wel snel weg, en geen bedankje voor de originele eigenaren. Toch vreemd, of een bot, of wat ondankbare mensjes...
Zal in ieder geval geen opsomming meer maken :/
Russian Blue Neji
Kate Bush
  • Morbid2002
  • Laatst online: 24-10 10:57
  • tn-fr
  • Laatst online: 18:11
FrankGuthrie schreef op zondag 23 november 2014 @ 20:58:
Zijn snel weg ;( Ga zelf ook maar terugscrollen
  • Snorretje de Vries
  • Laatst online: 11-11-2025
FrankGuthrie schreef op zondag 23 november 2014 @ 20:42:
De tweede van de bovenste geclaimd, mijn dank!
  • herremolog
  • Laatst online: 07-11 19:53
To decrypt following message use https://www.infoencrypt.com
<Encrypted>
/QXASo0D3bz4xM58gZTRzWEv2o60ywmLS/aVTRlxkfch4ymSh3rW2+ml733WGEhNnrq2sZKl1ComyAVY
SdKB9b/y1B2GSkz7+ycwby+mG2MW6XgBeVse+G2iyeKnUsUkyEreVmVh65Btnpa3mTo+Kplco82NwoN6
UXuzWkR+lWs=
</Encrypted>
wachtwoord is naam van de band 8)
Afbeeldingslocatie: http://static.gigwise.com/artists/3rdeyegirl6008934.jpg
I support anyone's right to be who they want to be. My question is: to what extent do I have to participate in your self-image? -Dave Chapelle-
  • dunedanh
herremolog schreef op zondag 23 november 2014 @ 22:18:
<Encrypted>
UXuzWkR+lWs=
</Encrypted>
Geclaimed, mijn dank is groot. Als ik zelf invites krijg komen ze zeker hier te staan :)
  • frankivo
  • Laatst online: 06-11 14:21
Members only:
* = E
iRacing Profiel
  • sbghannibal
  • Laatst online: 02-03-2023
zo te zien beste gewoon 1-2 dagen terug kijken en dan heb je vaak wel 1 invite die werk werkte voor mij ook bij de twitter post
  • greyfoxhl
Members only:
  • hjbaard
  • Laatst online: 23-09 18:46
DM me maar voor een invite :)
Alvast bedankt voor de moeite!
Sorry verkeerd begrepen
[ Voor 58% gewijzigd door hjbaard op 24-11-2014 09:21 ]
  • Pierre
Pierre
Van nature lui!
hjbaard schreef op maandag 24 november 2014 @ 09:12:
Heb je de boodschap wel gelezen onder je bericht :)
[ Voor 5% gewijzigd door Pierre op 24-11-2014 09:27 ]
  • hb96
hb96 schreef op zaterdag 22 november 2014 @ 10:09:
Members only:
Succes!
Deze kan opnieuw geclaimed worden! Ben benieuwd wie de gelukkige word!
  • hjbaard
hb96 schreef op maandag 24 november 2014 @ 09:59:
Geweldig bedankt! Ik heb hem gekocht 8)
  • hb96
hjbaard schreef op maandag 24 november 2014 @ 10:07:
Heel veel plezier ermee!
  • hb96
Members only:
Succes!
  • Mighty Giesso
  • Laatst online: 07-11 14:26
Mighty Giesso
Me is Mighty I hope :P
hb96 schreef op maandag 24 november 2014 @ 10:10:
Members only:
Succes!
Ik helaas niet :(
Intel Core2 QUAD 6600, Asus P5K Deluxe, Scythe Infinity, OCZ Reaper HPC Edition 6144MB PC8500, 4x 500GB Samsung HD502IJ (stripe) SATA2, MSI N460GTX Hawk 1gb, Creative X-FI Xtreme Gamer Fatal1ty, Dell Ultrasharp 2209WA, Antec P182, Logitech Z-5500
Ik 2 minuten na plaatsen van de post al niet :<
  • Feths
  • Laatst online: 29-08 08:40
Members only:
* =E
  • Bone
  • Laatst online: 30-10 21:49
Bone
wwwwwwwwwwwwwwwww
Members only:
Een van elk getal aftrekken, ik hoop dat ik er iemand blij mee heb gemaakt! :)
  • Mighty Giesso
Mighty Giesso
Feths schreef op maandag 24 november 2014 @ 11:32:
Members only:
* =E
Thank You!!!!!!
  • Anti-Pesto
  • Laatst online: 01-01-2024
Members only:
ROT13
Succes!
  • qwerty1
  • Laatst online: 11-01-2023
TheBoneZx schreef op maandag 24 november 2014 @ 11:33:
Members only:
Ja......heel blij. Eindelijk het kerstkado wat ik graag wilde. Nu maar hopen dat de vrouw ook betaald! 8)7
  • Faris
Bestaan ook invites voor oneplus 16GB versie?
  • Wharfedale
  • Laatst online: 14-10 09:34
Members only:
Members only:
Members only:
  • RHPJS
Wharfedale schreef op maandag 24 november 2014 @ 12:23:
Members only:
Members only:
Members only:
Dank u! Zal mijn invites zo snel mogelijk hier plaatsen! :)
Het is feest!
Members only:
  • nl03228
veel plezier !
Members only:
  • Pierre
Pierre
Van nature lui!
@thelightning87 en bedankt voor je invite, ik ga hem bestellen _/-\o_
  • Toets
  • Laatst online: 08-11 12:56
nl03228 schreef op maandag 24 november 2014 @ 12:33:
veel plezier !
Members only:
Eerste geclaimed. Dank is groot!
Verwijderd schreef op maandag 24 november 2014 @ 12:31:
Het is feest!
Members only:
Dankjewel, juist eentje geclaimed!! _/-\o_
  • icyx
icyx
chown -R us ./base
Members only:
Veel plezier!
When you think you’ve succeeded / but something’s missing / means you have been defeated / by greed, your weakness.
  • bartios
  • Laatst online: 28-09 22:49
Members only:
met * = O
veel plezier ermee
  • tn-fr
bartios schreef op maandag 24 november 2014 @ 13:20:
Members only:
met * = O
veel plezier ermee
Dank je, ik heb hem geclaimd _/-\o_
Pagina: 1 ... 7 ... 41 Laatste
~~~[html]<h1>- Geen gebedel om invites!
- Geen geklaag.
- Geen "stuur me een DM voor een invite" of andere V&A/ruil activiteiten.
- Geen slowchat.
- Geen verhalen over bestellingen.
- niet je invite blijven herplaatsen.</h1>
<b>Wat is wel de bedoeling:</b>
- plaats de invite code tussen [ mo ][ /mo ] tags (spaties verwijderen) zodat ze alleen voor ingelogde tweakers zichtbaar zijn
- het helpt als je de code een beetje versleuteld en dan instructies geeft hoe deze te decrypten.
- als je een invite code gebruikt hebt, meld het dan met een bedankje.
<b>Wat is niet de bedoeling:</b>
- vragen/bedelen om codes
- zeggen "DM me maar voor een invite" of linken naar een website
- klagen over de ^&%$% die een invite gebruikt heeft zonder het te melden
- invites gaan gebruiken om op V&A te zetten of elders te verkopen
- discussies over invites (zie verder "klagen")~~~[/html]
