beste geluidskwaliteit voor op de pc?
  • 250 views
  • pipichee
  • Laatst online: 21-04-2025
Hello,
im looking for the best sounding 2.1 pc speakers i can get for up to 500 euro's max
i'm currently using the KRK's Rokit RP6 Gen3, Sounds great but too flat for my taste.
i was looking into the Teufel Concept D 500 THX Multi Media and after watching reviews i decided to buy 1 but unfortunately they are not for sale anymore since 2013. :(
all the reviews i could find about it praised the Teufel Concept D 500 THX Multi Media really really high.
is there maybe i newer version of it? or do u know a 2.1 system that is as good or maybe even better then the Teufel Concept D 500 THX Multi Media? (max 500 euro's)
i use it mostly for Music,Games and movies but mostly Music (EDM,Trance,Vocal,Electro house) eg:
https://soundcloud.com/di...dlikemike/dvlm-tj-fg-nova
or
https://soundcloud.com/be...view-available-november-3
Opinions/Recommendations are very appreciated!
i might consider bookshelfs if its really that much better in that price range.
(i'm NOT looking for Studio Monitors!!)
  • fazerfreak
  • Laatst online: 09-02-2024
pricewatch: Bose Companion 5
try to listen to the set before you buy it. Best advice i can give you.
Battle.net :: FazerFreak#2695
  • FeaR
  • Laatst online: 29-09 21:35
FeaR
In GoT we trust
GoT is een Nederlandstalig forum, dus we verwachten ook posts in deze taal. Aan je vorige posts en de topictitel te zien ben je ook meer dan capabel dat te kunnen. Dit topic gaat op slot, een nieuw Nederlands topic kan je openen in Consumentenelektronica Aankoopadvies welke bestemd is voor aankoopadvies.
