Power on Virtual Machine Error
Ik heb een ESXI5.1 machine als hobby.
Draaide al een jaar perfect.
Stroom is uitgevallen en sindsdien kan ik geen Virtuele Machines meer opstarten.
Alsook krijg ik dezelfde foutmelding wanneer ik een nieuwe aangemaakte virtuele machine wil opstarten.
HDD lijkt in orde via Hard Disk Test.
Ik krijg steeds volgende fout
VMware ESX unrecoverable error: (vmx)
ASSERT bora/vmcore/vmx/main/timeTracker_user.c:232 bugNr=148722
2014-09-29T08:10:35.958Z| vmx| I120: SymBacktrace[0] 000003ffc9118510 rip=0000000027c0259e in function (null) in object /bin/vmx loaded at 0000000027628000
2014-09-29T08:10:35.958Z| vmx| I120: SymBacktrace[1] 000003ffc9118540 rip=000000002773ce89 in function (null) in object /bin/vmx loaded at 0000000027628000
2014-09-29T08:10:35.958Z| vmx| I120: SymBacktrace[2] 000003ffc9118a50 rip=00000000279f9491 in function (null) in object /bin/vmx loaded at 0000000027628000
2014-09-29T08:10:35.958Z| vmx| I120: SymBacktrace[3] 000003ffc9118af0 rip=000000002788b634 in function (null) in object /bin/vmx loaded at 0000000027628000
2014-09-29T08:10:35.958Z| vmx| I120: SymBacktrace[4] 000003ffc9118b40 rip=000000002773da25 in function (null) in object /bin/vmx loaded at 0000000027628000
2014-09-29T08:10:35.958Z| vmx| I120: SymBacktrace[5] 000003ffc9118b90 rip=000000002773dd27 in function (null) in object /bin/vmx loaded at 0000000027628000
2014-09-29T08:10:35.958Z| vmx| I120: SymBacktrace[6] 000003ffc9118c40 rip=000000002773b928 in function (null) in object /bin/vmx loaded at 0000000027628000
2014-09-29T08:10:35.958Z| vmx| I120: SymBacktrace[7] 000003ffc9118ce0 rip=000000002773bf6e in function main in object /bin/vmx loaded at 0000000027628000
2014-09-29T08:10:35.958Z| vmx| I120: SymBacktrace[8] 000003ffc9118d20 rip=000000004cb25a68 in function __libc_start_main in object /lib64/libc.so.6 loaded at 000000004cb08000
2014-09-29T08:10:35.958Z| vmx| I120: SymBacktrace[9] 000003ffc9118df0 rip=000000002773a1f9 in function (null) in object /bin/vmx loaded at 0000000027628000
2014-09-29T08:10:35.958Z| vmx| I120: Msg_Post: Error
2014-09-29T08:10:35.958Z| vmx| I120: [msg.log.error.unrecoverable] VMware ESX unrecoverable error: (vmx)
2014-09-29T08:10:35.958Z| vmx| I120+ ASSERT bora/vmcore/vmx/main/timeTracker_user.c:232 bugNr=148722
2014-09-29T08:10:35.958Z| vmx| I120: [msg.panic.haveLog] A log file is available in "/vmfs/volumes/51df0170-d1d09970-8cf3-bc5ff43b65b0/Test Machine/vmware.log".
2014-09-29T08:10:35.958Z| vmx| I120: [msg.panic.requestSupport.withoutLog] You can request support.
2014-09-29T08:10:35.958Z| vmx| I120: [msg.panic.requestSupport.vmSupport.vmx86]
2014-09-29T08:10:35.958Z| vmx| I120+ To collect data to submit to VMware technical support, run "vm-support".
2014-09-29T08:10:35.958Z| vmx| I120: [msg.panic.response] We will respond on the basis of your support entitlement.
  • plizz
  • Laatst online: 12-10 20:29
Wat zegt je favoriet zoekmachine als je de bugnr invoer?
  • .Kaas
  • Laatst online: 04-09 13:53
Te lui om te troubleshooten?
Wat staat er in dit log bestand?
Bugnr in de knowledge base van Vmware:
http://kb.vmware.com/self...displayKC&externalId=1227
Ik had dit inderdaad al door de google machine laten lopen.
Helaas kan ik niks terugvinden ivm deze fout
De logging die ik meegeef is de vmware.log file.
Ik zou geen topic starten zonder eerst zelf even te zoeken.
Beetje kort door de bocht dus.
Momenteel ben ik bezig met een nieuwe Esxi USB stick aan het creëren.
Alsook heb ik een lege Harde schijf ter beschikking. Zo kan ik testen of er effectief hardware defect is.
  • Koffie
  • Laatst online: 20:56
Koffie
Koffiebierbrouwer
Braaimeneer
Dan moet je dat de volgende keer aangeven .. ;)
Maar zoals al gevraagd : wat staat er in het logbestand /vmfs/volumes/51df0170-d1d09970-8cf3-bc5ff43b65b0/Test Machine/vmware.log ?
Move PNS > NOS
Braaikamer - Smoke&BBQ - Huis
  • plizz
Hmm, raar. Als ik op "ASSERT bora/vmcore/vmx/main/timeTracker_user.c:232 bugNr=148722" zoek, krijg ik veel hits. Leveren die hits geen concreet antwoord of oplossing?
  • Hero of Time
  • Laatst online: 22:18
Hero of Time
Moderator LNX
There is only one Legend
* Hero of Time slaps Koffie. VMware is SWS.
* Hero of Time kopt 't topic over de schutting verder, NOS -> SWS.
Commandline FTW
  • Question Mark
  • Laatst online: 20:42
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
Verwijderd schreef op dinsdag 30 september 2014 @ 21:16:
Nou nee.... In het algemeen beleid staat namelijk duidelijk vermeld wat je in een topicstart moet opnemen (en waarom)
  • Geef eerst globaal aan wat het probleem is.
  • Geef vervolgens aan waar je denkt dat het aan ligt.
  • Geef daarna aan wat je al geprobeerd hebt om zelf tot een oplossing te komen.Een duidelijke omschrijving geven van dingen die je al geprobeerd hebt voorkomt ook dat mensen tips geven die voor jou oude koek zijn.
  • Geef aan waarom je denkt dat jouw oplossing niet werkt of geef aan waarom je denkt dat dat niet werkt.
  • Je eigen oplossing heeft niet gewerkt. Als je begrijpt waarom niet, vertel dit dan. Als je dat niet begrijpt, kun je dat als "subvraag" in je topicstart opnemen.
Als ik dit nu even naast jouw topicstart houdt, dan mist daar wel het een en ander aan informatie. Zou je daarom eens willen posten welke troubleshoot stappen en KB-artikelen van VMWare je nu al doorlopen hebt?
Net zoals plizz vind ik nl. een hoop informatie op de VMware site als je zoekt op het betreffende bug nummer.
Overigens zou het ook nog een optie zijn om gewoon je VMFS volume even te controleren op corruptie. De bug lijkt te wijzen op een corrupt config bestand, en dat in combinatie met stroomuitval kan een aardige indicatie zijn.
Uiteindelijk was het een Local Disk in Esxi die toch problemen had.
Gelukkig stond daar enkel het OS Freenas op (heb dus geen data verloren).
Toch een vreemde foutmelding
