Hail to the king baby!
[global]
workgroup = Fremouw.com
server string = Fremouw.com server
dead time = 15
hosts allow = 192.168.0. 127.
case sensitive = no
load printers = yes
log file = /usr/local/samba/var/log.%m
max log size = 50
security = user
encrypt passwords = yes
password level = 1
socket options = TCP_NODELAY
interfaces = 192.168.0.1/24
bind interfaces only = yes
local master = yes
os level = 65
domain master = yes
preferred master = yes
domain logons = yes
logon script = start.bat
[homes]
comment = Home Directory
browseable = no
writable = yes
[netlogon]
comment = Fremouw.com Network Logon Service
path = /usr/local/samba/lib/netlogon
guest ok = yes
browseable = no
writable = no
share modes = no
[DJ610C]
comment = HP Deskjet 610C
path = /var/spool/samba/printer1
print command = /var/spool/samba/DJ610C %s %u %m
guest ok = no
writable = yes
printable = yes
[DJ950C]
comment = HP Deskjet 950C
path = /var/spool/samba/printer2
print command = /var/spool/samba/DJ950C %s %u %m
guest ok = yes
writable = yes
printable = yes
[fremouw.com]
path = /fremouw.com
writable = yes
printable = no
dead time = 15
case sensitive = no
load printers = yes
max log size = 50
security = user
password level = 1
local master = yes
os level = 65
domain master = yes
domain logons = yes
[homes]
browseable = no
writable = yes
[netlogon]
guest ok = yes
browseable = no
writable = no
share modes = no
[DJ610C]
guest ok = no
writable = yes
printable = yes
[DJ950C]
guest ok = yes
writable = yes
printable = yes
[fremouw.com]
path = /fremouw.com
writable = yes
printable = no
Ok complete smb.conf overgenomen, alleen ip-adressen aangepast en printers weggelaten. Nu kan ik na meerdere keren allebei pc's te hebben geherstart de linux server niet zien, het windows station kan zelfs de werkgroep niet zien.
Ik kan wel pingen naar het ip-adres en ook de netbios naam van de linuxpc. Ik kan hem alleen niet zien in de networkneighbourhood.
Welke samba-versie is het?
Verder staat er een regel in Slackware z'n config die een beetje vreemd is!
Hij hangt de interface aan alle ip's die tot de machine behoren in het subnet 192.168.0.1-192.168.0.254.
Zie de interfaces regel!
Verder het wins-serveer gedeelte wel aangezet?
Ook de nameresolve order op de juiste manier gezet?
Zitten de machines in hetzelfde subnet en dezelde werkgroep/domein?
Als je hem eenmaal kan zien, dan een user-account aanmaken (zowel op het systeem zelf als in samba) en een computer (netbiosnaam) account aanmaken!
Voor welke Windows-versies moet hij als PDC draaien?
Win2k met SP2 (en volgens mij ook XP) hebben problemen om een 2.2 samba-PDC te joinen!
Verder heb je vrij weinig aan iemand z'n smb.conf, zo leer je nog niks!!!
Als je nou eens goed de documentatie door neemt, dan moet het toch echt wel lukken!
/me vraagt zich af of tegenwoordig iedereen met samba aan het spelen is, gezien het grote aantal vragen hierover de laatste tijd
Deze smb.conf is voor samba 2.2, dus ik weet niet of 't ook met andere versies goed werkt.
en die interface regels zouden als 't goed er voor zorgen dat mijn 2de netwerkkaart, waar 't internetverkeer binnenkomt, niet met samba werkt.(dat heb ik lang lang geleden es ingesteld dus 't zou kunnen dat 't nu niet meer nodig is).
Klopt wel, maar als dat ip van die kaart 192.168.0.1 is, dan zou ik het subnetmasker in 32 veranderen i.p.v. 24.
Nou zou hij op alle netwerkkaarten (en aliassen) werken op die computer die in reeds eerder genoemde range vallen.
Het werkt dus wel en het is eigenlijk ook gewoon een beetje mierenneuken (hoewel een goed begrip van subnetmasker in de beveiliging van je linux-computer eigenlijk wel heel belangrijk is)
Verder werkt deze config ook op 2.0.7 en HEAD en TNG, hoewel deze nog wat extra opties meenemen meestal.
Ik heb de allerlaatste versie gedownload dus 2.2.0 ofzo iets
Euhh lieve urk_forever het is wel de bedoeling dat je zelf ook een beetje dingen uit gaat zoeken! Daar is hele goede documentatie voor/over.
Ik zou het je waarschijnlijk zo kunnen zeggen, maar je mag eerst eens zelf wat moeite gaan doen!
[edit]
Linux == Lezen!
[edit]
Linux == Lezen!
Je zou ook eens SWAT kunnen proberen. Dat is een webbased configuratie tool, het zit standaart bij samba dacht ik zo. Zit ook een makelijke help functie bij.
Ja maar als je er met boeken van 600 bladzijden en verschillende bronnen van internet er al niet uitkomt dan wordt het wel heel moeilijk om het alleen te doen, maar ik zal wat meer zelf uit gaan zoeken voor het hier te vragen.
Hou het dan maar op alleen windowsOp dinsdag 12 juni 2001 19:36 schreef urk_forever het volgende:
Ghe, die opmerking ziet er misschien niet erg vriendelijk uit, maar hij heeft wel gelijk. Als je niet eeuwig afhankelijk wilt blijven van anderen, zul je moeten gaan lezen. Anders kun je idd beter bij een klikkerdieklik OS blijven.
Het zal wel niet, maar het zou maar wel.
Ok, i get your point.
Het goede nieuws is: Snap je het eindelijk, upgrade je naar een nieuwe distro voor leuke nieuwe kernel en al die ellende... en dan bestaan er ineens weer andere configuratie file's (of is dat alleen in RedHat). Kun je weer fijn opnieuw beginnen
[global]
workgroup = WORKGROUP
security = DOMAIN
encrypt passwords = Yes
time server = Yes
domain logons = Yes
preferred master = Yes
domain master = yes
create mask = 0774
directory mask = 0775
[homes]
read only = No
browseable = No
[Documenten]
comment = Documenten
path = /data/docs
read only = No
[FREEBSD]
comment = FREEBSD & UNIX
path = /data/unix
read only = No
[Data]
comment = DATA Files
path = /data/data
read only = No
[Uitzoeken]
comment = Uitzoeken
path = /data/sort
read only = No
[Temp]
comment = Uitzoek geblazen
path = /data/tydel
read only = No
[Muziek]
comment = Muziek MP3 en zound
path = /data/muziek
read only = No
[Deskjet540]
comment = HP Deskjet 540
path = /var/spool/lpd
guest ok = Yes
print ok = Yes
printer name = lp
let ff niet op de printer daar heb ik nog wat problemen mee.
Er komt na elke afdruk een leeg vel achter na. En als het afdruk is met een grote foto dan stopt hij er mee. Het is een lichte machine met waarschijnlijkeen te kleine spool en mem.
security = DOMAIN
time server = Yes
domain logons = Yes
domain master = yes
create mask = 0774
[homes]
read only = No
browseable = No
[Documenten]
path = /data/docs
read only = No
[FREEBSD]
path = /data/unix
read only = No
[Data]
path = /data/data
read only = No
[Uitzoeken]
comment = Uitzoeken
path = /data/sort
read only = No
[Temp]
path = /data/tydel
read only = No
[Muziek]
path = /data/muziek
read only = No
[Deskjet540]
guest ok = Yes
print ok = Yes
printer name = lp
