• clogie886
  • Laatst online: 23-01 16:44
Ik heb hier een Arduino Uno die ik via een CC3000 wil laten communiceren met internet.
Ik gebruik de volgende code om te kijken of de CC3000 werkt met mijn draadloos netwerk:
C++:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
  This is an example for the Adafruit CC3000 Wifi Breakout & Shield
  Designed specifically to work with the Adafruit WiFi products:
  ----> https://www.adafruit.com/products/1469
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Kevin Townsend & Limor Fried for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
This example does a full test of core connectivity:
* Initialization
* SSID Scan
* AP connection
* DHCP printout
* DNS lookup
* Ping
* Disconnect
It's a good idea to run this sketch when first setting up the
module.
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ   3  // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
                                         SPI_CLOCK_DIVIDER); // you can change this clock speed but DI
#define WLAN_SSID       "network"        // cannot be longer than 32 characters!
#define WLAN_PASS       "wifi key"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY   WLAN_SEC_WPA2
    @brief  Sets up the HW and the CC3000 module (called automatically
            on startup)
void setup(void)
  Serial.begin(115200);
  Serial.println(F("Hello, CC3000!\n"));
  displayDriverMode();
  Serial.print("Free RAM: "); Serial.println(getFreeRam(), DEC);
  /* Initialise the module */
  Serial.println(F("\nInitialising the CC3000 ..."));
  if (!cc3000.begin())
    Serial.println(F("Unable to initialise the CC3000! Check your wiring?"));
    while(1);
  /* Optional: Update the Mac Address to a known value */
  uint8_t macAddress[6] = { 0x08, 0x00, 0x28, 0x01, 0x79, 0xB7 };
   if (!cc3000.setMacAddress(macAddress))
     Serial.println(F("Failed trying to update the MAC address"));
     while(1);
  uint16_t firmware = checkFirmwareVersion();
  if (firmware < 0x113) {
    Serial.println(F("Wrong firmware version!"));
    for(;;);
  displayMACAddress();
  /* Optional: Get the SSID list (not available in 'tiny' mode) */
#ifndef CC3000_TINY_DRIVER
  listSSIDResults();
#endif
  /* Delete any old connection data on the module */
  Serial.println(F("\nDeleting old connection profiles"));
  if (!cc3000.deleteProfiles()) {
    Serial.println(F("Failed!"));
    while(1);
  /* Optional: Set a static IP address instead of using DHCP.
     Note that the setStaticIPAddress function will save its state
     in the CC3000's internal non-volatile memory and the details
     will be used the next time the CC3000 connects to a network.
     This means you only need to call the function once and the
     CC3000 will remember the connection details.  To switch back
     to using DHCP, call the setDHCP() function (again only needs
     to be called once).
  uint32_t ipAddress = cc3000.IP2U32(192, 168, 1, 19);
  uint32_t netMask = cc3000.IP2U32(255, 255, 255, 0);
  uint32_t defaultGateway = cc3000.IP2U32(192, 168, 1, 1);
  uint32_t dns = cc3000.IP2U32(8, 8, 4, 4);
  if (!cc3000.setStaticIPAddress(ipAddress, netMask, defaultGateway, dns)) {
    Serial.println(F("Failed to set static IP!"));
    while(1);
  /* Optional: Revert back from static IP addres to use DHCP.
     See note for setStaticIPAddress above, this only needs to be
     called once and will be remembered afterwards by the CC3000.
  if (!cc3000.setDHCP()) {
    Serial.println(F("Failed to set DHCP!"));
    while(1);
  /* Attempt to connect to an access point */
  char *ssid = WLAN_SSID;             /* Max 32 chars */
  Serial.print(F("\nAttempting to connect to ")); Serial.println(ssid);
  /* NOTE: Secure connections are not available in 'Tiny' mode!
     By default connectToAP will retry indefinitely, however you can pass an
     optional maximum number of retries (greater than zero) as the fourth parameter.
  if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
    while(1);
  Serial.println(F("Connected!"));
  /* Wait for DHCP to complete */
  Serial.println(F("Request DHCP"));
  while (!cc3000.checkDHCP())
    delay(500); // ToDo: Insert a DHCP timeout!
  /* Display the IP address DNS, Gateway, etc. */
  while (! displayConnectionDetails()) {
    delay(1000);
  /* Try looking up www.adafruit.com */
  uint32_t ip = 0;
  Serial.print(F("www.adafruit.com -> "));
  while  (ip  ==  0)  {
    if  (!  cc3000.getHostByName("www.adafruit.com", &ip))  {
      Serial.println(F("Couldn't resolve!"));
    delay(500);
  cc3000.printIPdotsRev(ip);
  /* Do a quick ping test on adafruit.com */
  Serial.print(F("\n\rPinging ")); cc3000.printIPdotsRev(ip); Serial.print("...");
  uint8_t replies = cc3000.ping(ip, 5);
  Serial.print(replies); Serial.println(F(" replies"));
  if (replies)
    Serial.println(F("Ping successful!"));
#endif
  /* You need to make sure to clean up after yourself or the CC3000 can freak out */
  /* the next time you try to connect ... */
  Serial.println(F("\n\nClosing the connection"));
  cc3000.disconnect();
void loop(void)
  delay(1000);
    @brief  Displays the driver mode (tiny of normal), and the buffer
            size if tiny mode is not being used
    @note   The buffer size and driver mode are defined in cc3000_common.h
void displayDriverMode(void)
  #ifdef CC3000_TINY_DRIVER
    Serial.println(F("CC3000 is configure in 'Tiny' mode"));
  #else
    Serial.print(F("RX Buffer : "));
    Serial.print(CC3000_RX_BUFFER_SIZE);
    Serial.println(F(" bytes"));
    Serial.print(F("TX Buffer : "));
    Serial.print(CC3000_TX_BUFFER_SIZE);
  #endif
    @brief  Tries to read the CC3000's internal firmware patch ID
uint16_t checkFirmwareVersion(void)
  uint8_t major, minor;
  uint16_t version;
  if(!cc3000.getFirmwareVersion(&major, &minor))
    Serial.println(F("Unable to retrieve the firmware version!\r\n"));
    version = 0;
  else
    Serial.print(F("Firmware V. : "));
    Serial.print(major); Serial.print(F(".")); Serial.println(minor);
    version = major; version <<= 8; version |= minor;
#endif
  return version;
    @brief  Tries to read the 6-byte MAC address of the CC3000 module
void displayMACAddress(void)
  uint8_t macAddress[6];
  if(!cc3000.getMacAddress(macAddress))
    Serial.println(F("Unable to retrieve MAC Address!\r\n"));
  else
    Serial.print(F("MAC Address : "));
    cc3000.printHex((byte*)&macAddress, 6);
    @brief  Tries to read the IP address and other connection details
bool displayConnectionDetails(void)
  uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
  if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
    Serial.println(F("Unable to retrieve the IP Address!\r\n"));
    return false;
  else
    Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
    Serial.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);
    Serial.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);
    Serial.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);
    Serial.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
    Serial.println();
    return true;
    @brief  Begins an SSID scan and prints out all the visible networks
void listSSIDResults(void)
  uint32_t index;
  uint8_t valid, rssi, sec;
  char ssidname[33];
  if (!cc3000.startSSIDscan(&index)) {
    Serial.println(F("SSID scan failed!"));
    return;
  Serial.print(F("Networks found: ")); Serial.println(index);
  Serial.println(F("================================================"));
  while (index) {
    index--;
    valid = cc3000.getNextSSID(&rssi, &sec, ssidname);
    Serial.print(F("SSID Name    : ")); Serial.print(ssidname);
    Serial.println();
    Serial.print(F("RSSI         : "));
    Serial.println(rssi);
    Serial.print(F("Security Mode: "));
    Serial.println(sec);
    Serial.println();
  cc3000.stopSSIDscan();
Resultaat in "Serial Monitor"
Hello, CC3000!
RX Buffer : 131 bytes
TX Buffer : 131 bytes
Free RAM: 1215
Lijkt er dus op dat de Arduino wel communiceert met de CC3000 maar dat hij niet op mijn wifi network komt.
Ik gebruik WPA2-PSK maar dat zou volgens sommige websites gewoon moeten werken.
Hopelijk kan iemand mij vertellen waarom hij blijft hangen op Initializing?
Als hij namelijk niet goed aangesloten zou zijn had ik de boodschap "Unable to initialise the CC3000! Check your wiring?"verwacht maar die staat pas op de volgend regel :?
[ Voor 255% gewijzigd door clogie886 op 10-09-2014 11:38 ]
De overheid is niet de oplossing maar de oorzaak van veel problemen.
  • Raven
Raven
Marion Raven fan
Zet die lap code eerst eens tussen
C++:
[code=C++] code [/]
om het overzichtelijk te maken ;)
En bekijk https://forums.adafruit.c...php?f=31&t=51941&start=15 eens? Daar lijkt het om een defect model te gaan. Er zijn er trouwens meer met dat probleem zo te zien: https://www.google.nl/sea....hp..3.1.68.0.Kf_C_K_-om4
Let vooral op dit stukje:
Also: this one is slightly obscure, but check your wireless router to see what kind of connections it supports. About a week ago someone had a problem because their router was set to accept only 802.11n connections, and the CC3000 uses 802.11b/g connections.
[ Voor 60% gewijzigd door Raven op 10-09-2014 09:53 ]
Oscar Wilde
  • clogie886
Code overzichtelijk gemaakt - bedankt voor de tip / uitleg.
Verder misschien nog het vermelden waard, ik gebruik een ZyXEL P-660HW-T1 als ADSL modem
  • clogie886
Probleem gevonden...
Er is een 'breakout board' van Adafruit voor de CC3000 en een van Sparkfun, de pin layout is echter wel verschillend vandaar dat het niet werkte!
Nadat ik de pin layout had aangepast voor Sparkfun werkte het direct.
  • Raven
Raven
Marion Raven fan
Mooi dat het werkt :D
Voor 't geval dat er meer tegen aanlopen, zou je de verschillen willen vermelden? ;)
[ Voor 22% gewijzigd door Raven op 10-09-2014 17:57 ]
Oscar Wilde
  • clogie886
Adafruit
1 GND
2 3V3
3 VIN
4 CLK
5 MISO
6 MOSI
7 CS
8 VBEN
9 IRQ
SparkFun
1 GND
2 VCC
3 3V3
4 MOSI
5 MISO
6 CS
7 INT
8 SCK
9 EN
  • Cilph
  • Laatst online: 14-10 19:23
3v3 en VCC/VIN omwisselen, heeft dat geen schade aangericht? Veel van die 3.3v chips zijn niet tolerant voor 5v.
  • clogie886
Getest met de SparkFun test program:
SparkFun CC3000 - Board Test
CC3000 initialization complete
Firmware version: 1.24
MAC address: 70:FF:76:01:FB:C9
Finished board test
Hij lijkt het dus nog te doen maar zal hem wel goed in de gaten houden, je hebt namelijk wel gelijk.
