Shoutcast server op 3G netwerk Bliep (Tmobile) werkt niet
  • dekker007
  • Laatst online: 03-01-2025
Goedemorgen,
Ik ben nu al enkele dagen bezig om shoutcast server aan het werk te krijgen op mijn Globesurfer 3+ Router.. Poorten open zetten heeft geen zin en DMZ werkt ook niet.. Krijg onderstaande melding. Heb gevoel dat de poort vanaf buitenaf geblokkeerd wordt door de provider? Kan iemand mij hierbij helpen of antwoord opgeven. Zie onderstaande log. Alvast bedankt.
aan mij
C:\Program Files\SHOUTcast>sc_serv.exe setup
2014-08-28 18:27:01 INFO ************************************************
2014-08-28 18:27:01 INFO ** SHOUTcast Distributed Network Audio Serve
r (DNAS) **
2014-08-28 18:27:01 INFO ** Copyright (C) 2014 Radionomy SA, All Rights
Reserved. **
2014-08-28 18:27:01 INFO [MAIN] SHOUTcast DNAS/win64 v2.2.2.123 (Jul 31 2
014)
2014-08-28 18:27:01 INFO [MAIN] PID: 1188
2014-08-28 18:27:01 INFO [MAIN] Entering setup mode - Open 127.0.0.1:8000
/setup in a
2014-08-28 18:27:01 INFO [MAIN] browser on the same machine the DNAS was
started on
2014-08-28 18:27:01 INFO [MAIN] if the browser does not automatically ope
n the page.
2014-08-28 18:27:01 INFO [MAIN] If working remotely then replace 127.0.0.
1 with the
2014-08-28 18:27:01 INFO [MAIN] IP / address of the remote system to use
this mode.
2014-08-28 18:27:01 INFO [MICROSERVER] Listening for connections on port
8000
2014-08-28 18:27:15 INFO [SETUP] Saving settings to sc_serv.conf
2014-08-28 18:27:15 INFO [SETUP] Saved settings to sc_serv.conf
2014-08-28 18:27:16 INFO [MAIN] Stopping setup mode. Preparing for broadc
asting...
2014-08-28 18:27:16 INFO [MAIN] Loaded config from sc_serv.conf
2014-08-28 18:27:16 INFO [MAIN] Calculated CPU count is 4 -> using all av
ailable CPUs
2014-08-28 18:27:16 INFO [MAIN] Starting 4 network threads
2014-08-28 18:27:16 INFO [MICROSERVER] Listening for source and client co
nnections on port 8000
2014-08-28 18:27:16 INFO [MICROSERVER] Listening for legacy source connec
tions on port 8001
2014-08-28 18:27:16 INFO [MICROSERVER] Flash policy file server not enabl
ed
2014-08-28 18:27:18 INFO [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
ion starting.
2014-08-28 18:27:18 ERROR [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
ion denied. Bad password.
2014-08-28 18:27:19 INFO [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
ion starting.
2014-08-28 18:27:19 ERROR [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
2014-08-28 18:27:20 INFO [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
ion starting.
2014-08-28 18:27:20 ERROR [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
2014-08-28 18:27:21 INFO [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
ion starting.
2014-08-28 18:27:21 ERROR [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
2014-08-28 18:27:22 INFO [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
ion starting.
2014-08-28 18:27:22 ERROR [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
2014-08-28 18:27:23 INFO [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
ion starting.
2014-08-28 18:27:23 ERROR [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
2014-08-28 18:27:24 INFO [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
ion starting.
2014-08-28 18:27:24 ERROR [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
2014-08-28 18:27:25 INFO [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
ion starting.
2014-08-28 18:27:25 ERROR [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
2014-08-28 18:27:26 INFO [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
ion starting.
2014-08-28 18:27:26 ERROR [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
2014-08-28 18:27:27 INFO [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
ion starting.
2014-08-28 18:27:27 ERROR [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
2014-08-28 18:27:33 INFO [SRC 127.0.0.1 sid=1] SHOUTcast 1 source connect
ion starting.
2014-08-28 18:27:43 DEBUG [YP] <?xml version="1.0" encoding="UTF-8"?>
<response><statusCode>200</statusCode><statusText>Ok</statusText><data><authhash
>N5PQWHJInSDgTwS8qo5Y</authhash></data></response>
200
2014-08-28 18:27:43 INFO [CONFIG] Created authhash for stream #1 [saved N
5PQWHJInSDgTwS8qo5Y]
2014-08-28 18:27:49 ERROR [YP] Stream #1 connection attempt failed. YP2 er
ror code is 480 [Cannot see your station/computer (URL: http://89.205.224.146:80
00) from the Internet, disable Internet Sharing/NAT/firewall/ISP cache.]
2014-08-28 18:27:49 ERROR [YP] See http://wiki.winamp.com/wiki/SHOUTcast_Y
P_Nak_Errors for more information to resolve this error.
  • Hero of Time
  • Laatst online: 14:00
Hero of Time
Moderator LNX
There is only one Legend
Ga eerst eens na wat het IP adres is van je systeem dat aan die 3G verbinding hangt, ipv naar watismijnip.nl te gaan en het daar uit halen. Grote kans dat je gewoon een 10.x.y.z adres hebt en daarmee ga je helemaal nergens komen. 3G e.d. is ook helemaal niet bedoelt om servers mee te draaien. Niet als consument iig.
Commandline FTW
  • NeHoX
  • Laatst online: 21-10 15:56
Er staat meermaals Bad password in de log. Daar even naar kijken! En je kan proberen een VPN op te zetten met je mobiel en dan kijken of het streamen wel gaat. Of wil je echt een shoutcast server op een 3G verbinding draaien? Neem aan gewoon op je thuisverbinding en dan streamen naar mobiel?
Tesla Model Y Juniper Performance
  • dekker007
De Globesurfer geeft mij het ip 192.168.1.2 . Vanuit de router heb ik poort open proberen te zetten.
Bad password komt omdat ik via winamp verkeerde wachtwoord inhad gevuld om op de shoutcast server te komen.
Lokaal is de stream wel te openen dat is het probleem niet. Wil de stream extern openen namelijk op een andere lokatie.
Hoeft niet perse Shoutcast te zijn. Maar wil wel graag deze kant van 3g als host gebruiken. Weet niet of er nog een andere oplossing voor is.
