WCF over HTTPS problemen
Ik probeer onze WCF service via HTTPS beschikbaar te krijgen, echter lukt het me niet om dit werkend te krijgen.
Ik blijf continue foutmeldingen krijgen, en weet nu even neit zo goed meer waar ik het moet zoeken.
Web.config
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
<?xml version="1.0"?>
  For more information on how to configure your ASP.NET application, please visit
  http://go.microsoft.com/fwlink/?LinkId=169433
<configuration>
    <connectionStrings>
        <add name="SIMSCENARIOSConnectionString" connectionString="Data Source=sqlsrv17;Initial Catalog=SIMSCENARIOS;User ID=simscen;Password=simscen" providerName="System.Data.SqlClient" />
         </connectionStrings>
    <system.web>
        <compilation strict="false" explicit="true" targetFramework="4.0" />
    </system.web>
    <system.serviceModel>
        <client>
            <endpoint address="https://simscendb.stc-group.nl/SimScenarioService.svc" binding="basicHttpBinding" bindingConfiguration="BasicHttpBinding_ISimScenarioService" contract="ServiceReference1.ISimScenarioService" name="BasicHttpBinding_ISimScenarioService" />
        </client>
        <behaviors>
            <serviceBehaviors>
                <behavior name="">
                    <serviceMetadata httpsGetEnabled="true" />
                    <serviceDebug includeExceptionDetailInFaults="true" />
                </behavior>
            </serviceBehaviors>
        </behaviors>
        <bindings>
            <basicHttpBinding>
                <binding name="BasicHttpBinding_ISimScenarioService">
            <readerQuotas maxDepth="2147483647" maxStringContentLength="2147483647" maxArrayLength="2147483647" maxBytesPerRead="2147483647" maxNameTableCharCount="2147483647" />
                 <security mode="Transport">
                         <transport clientCredentialType="None" />
                        </security>
        </binding>
            </basicHttpBinding>
            <customBinding>
                <binding name="SimScenarios.Web.SimScenario.customBinding0">
                    <binaryMessageEncoding />
                    <httpTransport />
                </binding>
            </customBinding>
        </bindings>
        <serviceHostingEnvironment multipleSiteBindingsEnabled="true" />
         <services>
             <service name="SimScenarios.Web.SimScenario">
                <endpoint address="https://simscendb.stc-group.nl/simscenarioservice.svc" binding="customBinding" bindingConfiguration="SimScenarios.Web.SimScenario.customBinding0" contract="ServiceReference1.ISimScenarioService" />
                <endpoint address="mex" binding="mexHttpsBinding" contract="IMetadataExchange" />
            </service>
        </services>
    </system.serviceModel>
</configuration>
Ik krijg de onderstaande foutmelding:
Server Error in '/' Application.
Service 'SimScenarios.Web.SimScenarioService' has zero application (non-infrastructure) endpoints. This might be because no configuration file was found for your application, or because no service element matching the service name could be found in the configuration file, or because no endpoints were defined in the service element.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.InvalidOperationException: Service 'SimScenarios.Web.SimScenarioService' has zero application (non-infrastructure) endpoints. This might be because no configuration file was found for your application, or because no service element matching the service name could be found in the configuration file, or because no endpoints were defined in the service element.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[InvalidOperationException: Service 'SimScenarios.Web.SimScenarioService' has zero application (non-infrastructure) endpoints. This might be because no configuration file was found for your application, or because no service element matching the service name could be found in the configuration file, or because no endpoints were defined in the service element.]
System.ServiceModel.Description.DispatcherBuilder.EnsureThereAreApplicationEndpoints(ServiceDescription description) +346
System.ServiceModel.Description.DispatcherBuilder.InitializeServiceHost(ServiceDescription description, ServiceHostBase serviceHost) +292
System.ServiceModel.ServiceHostBase.InitializeRuntime() +90
System.ServiceModel.ServiceHostBase.OnOpen(TimeSpan timeout) +182
System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout) +742
System.ServiceModel.HostingManager.ActivateService(ServiceActivationInfo serviceActivationInfo, EventTraceActivity eventTraceActivity) +126
System.ServiceModel.HostingManager.EnsureServiceAvailable(String normalizedVirtualPath, EventTraceActivity eventTraceActivity) +901
[ServiceActivationException: The service '/simscenarioservice.svc' cannot be activated due to an exception during compilation. The exception message is: Service 'SimScenarios.Web.SimScenarioService' has zero application (non-infrastructure) endpoints. This might be because no configuration file was found for your application, or because no service element matching the service name could be found in the configuration file, or because no endpoints were defined in the service element..]
System.Runtime.AsyncResult.End(IAsyncResult result) +654324
System.ServiceModel.Activation.HostedHttpRequestAsyncResult.End(IAsyncResult result) +210877
System.Web.AsyncEventExecutionStep.OnAsyncEventCompletion(IAsyncResult ar) +166
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.18446
  • Merethil
  • Laatst online: 10:29
Kun je alles tussen [.code] [./] zetten? (even de punt eruit halen).
Daarnaast: Wat is de class waar je endpoint zou moeten zitten? Kloppen die namen 1:1 met wat er in je web.config staat?
