gtx 780 ti 2.0 16 x ipv 3.0 16x
  • tattooboy1985
  • Laatst online: 10-10 19:03
hallo tweakers ,
ik heb sinds gisteren een asus gtx 780 ti en hiervoor een sapphire tri x r9 290
nu gaf cpu Z bij die sapphire kaart aan pci 3.0 16 x .
maar nu bij de gtx 780 ti zegt die steeds 2.0 16 x die behoort toch ook op 3.0 te gaan ?
ik heb al een andere gpu-z gedownload kaart een x verwisseld van slot mocht niet baten , iemand van jullie hiermee bekend ?
mijn specs :
i7 3820
asus sabertooth x 79
asus gtx 780 ti
  • Deem
  • Laatst online: 18-09 18:20
Deem
Ontcijfer mij!
Effe gezocht op internet:
GeForce GTX 680 Release Driver Limits PCI-Express to Gen 2.0 on X79/SNB-E Systems
Users of systems running Core i7 processors in the LGA2011 package and X79 chipset motherboards will find that their GeForce GTX 680 will not run at PCI-Express 3.0 x16 mode, using launch drivers. This is because NVIDIA decided against implementing Gen 3.0 support for the new GPU on X79/SNB-E systems, at the very last moment. Pre-launch drivers, including the driver that ships on discs with the graphics cards, and review drivers (which cannot be distributed), will let the GPU run at Gen 3.0 mode on some X79/SNB-E systems, however the post-launch stable drivers (such as GeForce 301.10 WHQL), won't. The specifications page of GeForce GTX 680 on GeForce.com has been updated to mention this:
GeForce GTX 680 supports PCI Express 3.0. The Intel X79/SNB-E PCI Express 2.0 platform is only currently supported up to 5GT/s (PCIE 2.0) bus speeds even though some motherboard manufacturers have enabled higher 8GT/s speeds. Sources in the PC motherboard industry we spoke with, confirmed this change. PCI-Express 3.0 x16, for now, might only run on upcoming "Ivy Bridge" Core systems, running on motherboards with PCI-Express 3.0 compliant components. NVIDIA could be working to fix the issue.
Bios update al geprobeerd? Laatste Nvidia drivers zijn geinstalleerd?
"May our framerates be high and our temperatures low."
  • Daniel.
  • Laatst online: 01:19
Hehe ik heb daar nooit op gelet maar ik zie dat mijn Asus ook 2.0 aangeeft. Zit wel goed denk ik. Ik heb zelf ongeveer dezelfde config als jij alleen een Asus Rampage IV Extreme
<GoTHC>Daniel#23781 | Mijn PC
  • Deem
Deem
Ontcijfer mij!
Nog een quote:
Interesting, misleading and somewhat wrong. The SB-E has 40 primary PCIe lanes, 32 lanes of PCIe 3.0 are dedicated to the GPU(s), all LGA 2011 CPUs & MOBO's are capable of PCIe 3.0, some BIOS upgrades have addressed PCIe 3.0 issues, but the X79 Chipset is a controller for 6 SATA ports (2xSATA3 & 4xSATA2) and USB 2.0 14 ports using an additional separate 8 lanes of PCIe 2.0. Ditto the Z77 has the same 8 lanes of PCIe 2.0. Meaning, the IB (Ivy Bridge) is the second set of CPU's from Intel to run PCIe 3.0 to the GPU(s). All LGA 1155 including the IB have half the number of PCIe lanes to the GPU in comparison to LGA 2011; SB/LGA 1155 16 lanes of PCIe 2.0, IB/LGA 1155 16 lanes of PCIe 3.0 vs SB-E/IB-E/LGA 2011 32 lanes of PCIe 3.0 to the GPUs then split in various ways.
  • garriej
  • Laatst online: 29-09 10:29
garriej
Ik las ondertieten.
Als je geen performance problemen heb zou ik me er niet teveel zorgen over maken, als je wel minder performance haalt als te verwachten zou ik het pas gaan uitzoeken.
  • Deem
Deem
Ontcijfer mij!
  • tattooboy1985
ik heb net de bios via asus gpu tweak geupdate en de laatste drivers zijn geinstalleerd 340.52
  • tattooboy1985
@deem bedankt heb je tooltje gedownload opnieuw opgestart en nu staat die op 3.0 x16 @ x16 1.1
  • Daniel.
Ik heb inmiddels ook dat tooltje gebruikt en bij mij staat die nu ook op 3.0 Kijken of ik verschil ga merken. Bedankt iedereen. Zonder dit topic was het me niet eens opgevallen :P
Edit: Ghosts loopt net ietsjes soepeler.
[ Voor 10% gewijzigd door Daniel. op 06-08-2014 11:26 . Reden: Ghosts ]
  • tattooboy1985
yeahh bij mij ook battlefield 4 thanx deem voor je handige link
  • Daniel.
Ik merk nu ik mijn 780Ti in PCI-E 3.0 heb staan dat mijn CPU flink minder wordt belast tijdens het spelen van Watch_Dogs. Kan dit kloppen?
Ik merk totaal geen verandering op met games
