[Wordpress] Telefoonnummer in Header
  • 756 views
  • bevgrad
  • Laatst online: 24-09-2018
Beste Tweakers,
Ik ben bezig met een wordpress site snip en probeer ons telefoon nummer rechts boven in de header te krijgen. Na wat onderzoek gedaan te hebben ben ik er achter gekomen dat ik bij de header.php moet wezen.
PHP:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
<!DOCTYPE html>
<!--[if IEMobile 7 ]> <html <?php language_attributes(); ?> xmlns="http://www.w3.org/1999/xhtml" class="no-js iem7"> <![endif]-->
<!--[if lt IE 7 ]> <html <?php language_attributes(); ?> xmlns="http://www.w3.org/1999/xhtml" class="no-js ie6 oldie"> <![endif]-->
<!--[if IE 7 ]>    <html <?php language_attributes(); ?> xmlns="http://www.w3.org/1999/xhtml" class="no-js ie7 oldie"> <![endif]-->
<!--[if IE 8 ]>    <html <?php language_attributes(); ?> xmlns="http://www.w3.org/1999/xhtml" class="no-js ie8 oldie"> <![endif]-->
<!--[if (gte IE 9)|(gt IEMobile 7)|!(IEMobile)|!(IE)]><!--><html xmlns="http://www.w3.org/1999/xhtml" <?php language_attributes(); ?> class="no-js"><!--<![endif]-->
<!--[if lt IE 9]>
    <script type="text/javascript">
         document.createElement('header');
         document.createElement('hgroup');
         document.createElement('nav');
         document.createElement('menu');
         document.createElement('section');
         document.createElement('article');
         document.createElement('aside');
         document.createElement('footer');
    </script>
<![endif]-->
    <head>
        <meta charset="utf-8">
                <!--[if IE 8 ]><meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7"><![endif]-->
        <meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1">
        <title><?php
         * Print the <title> tag based on what is being viewed.
        global $page, $paged;
        wp_title( '-', true, 'right' );
        // Add the blog name.
        bloginfo( 'name' );
        // Add a page number if necessary:
        if ( $paged >= 2 || $page >= 2 )
            echo ' - ' . sprintf( __( 'Page %s', 'qs_framework' ), max( $paged, $page ) );
        ?></title>
        <meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1">
        <meta name="description" content="">
        <meta name="author" content="">
        <?php if( of_get_option('qs_favicon') ): ?>
            <link rel="icon" type="image/png" href="<?php echo of_get_option('qs_favicon'); ?>">
        <?php endif; ?>
        <!-- default stylesheet -->
        <link rel="stylesheet" href="<?php echo get_template_directory_uri(); ?>/library/css/normalize.css">
        <link rel="stylesheet" href="<?php bloginfo('stylesheet_url'); ?>">
            <!-- wordpress head functions -->
            <?php wp_head(); ?>
            <!-- end of wordpress head -->
    </head>
    <body <?php body_class(); ?>>
            <header role="banner">
                <div id="header-bg"></div>
                <div id="inner-header" class="wrapper clearfix">
                    <div class="row">
                        <div class="twelve columns">
                            <!-- to use a image just replace the bloginfo('name') with your img src and remove the surrounding <p> -->
                            <div id="logo" class="h1">
                                <span><a href="<?php echo home_url(); ?>" rel="nofollow">
                                    <?php if(of_get_option('qs_logo')): ?>
                                        <img src="<?php echo of_get_option('qs_logo'); ?>" alt="<?php bloginfo('name'); ?>" />
                                    <?php else: ?>
                                        <span id="blog-name"><?php bloginfo('name'); ?></span>
                                    <?php endif; ?>
                                    </a>
                                </span>
                            </div>
                            <!-- if you'd like to use the site description you can un-comment it below -->
                            <?php // bloginfo('description'); ?>
                            <div class='menu-button'></div>
                            <nav role="navigation">
                                <?php
                                if ( has_nav_menu( 'primary' ) ) {
                                    wp_nav_menu( array( 'theme_location' => 'primary', 'walker' => new qs_walker(), 'items_wrap'      => '<ul id="nav" class="%2$s sf-menu sf-js-enabled">%3$s</ul>', ) );
                                else {
                                    theme_nav();
                            </nav>
                        </div>
                    </div>
                </div> <!-- end #inner-header -->
            </header> <!-- end header -->
Dit is de php code van mijn header. Nou moet ik dus als het goed is dit nummer <h1>020-1234567</h1> daar ergens tussen plakken. Ik heb het op meerdere plekken geprobeerd maar dit was natuurlijk totaal random uitgekozen omdat ik geen idee heb waar het zou moeten komen. Dit zorgt meestal voor een probleem in de opmaak of er gebeurt helemaal niks.
Kan iemand mij de goede kant op wijzen?
[ Voor 0% gewijzigd door BtM909 op 24-07-2014 15:43 ]
  • André
  • Laatst online: 16-10 11:31
André
Analytics dude
Regel 90
  • bevgrad
Bedankt voor je antwoord. Ik denk dat dit wel de juiste regel is alleen doe ik wat fout geloof ik.
Als je nu op de site kijkt dan zie je dat de opmaak is verpest en het telefoonnummer aan de linkerkant van het menu staat ipv de rechterkant. Enig idee wat ik fout heb gedaan?
  • henkjobse
  • Laatst online: 19:41
<h3 style="float: right;">020-1234567</h3>
[ Voor 8% gewijzigd door henkjobse op 24-07-2014 15:38 ]
  • BtM909
BtM909
Watch out Guys...
Welk deel begreep je niet van RobIII in "[Wordpress] Telefoonnummer in Header"
Je kan niet zomaar een nieuw topic openen, nadat de vorige is gesloten. Dit subforum is bedoeld om zelf dingen uit te zoeken en niet hier een oplossing te vragen.
Je topic gaat wederom dicht en het lijkt me verstandig om je of te gaan verdiepen in HTML en WordPress of een specialist in te huren om dit werk voor je te doen.
