[Java/Minecraft] Laad verkeerde modules
  • Xerohumoris
  • Laatst online: 10:53
Hoi Allemaal,
Ik heb een probleem. Minecraft start niet meer. Tot zeer recent heeft die het wel gedaan. Ik heb al eerder problemen gehad maar het updaten van de nVidia driver hielp toen. Nu helaas niet.
Dit is de error die ik krijg
[00:16:44 INFO]: Client> OpenJDK 64-Bit Server VM warning: You have loaded library /data/DDH/.minecraft/versions/1.7.10/1.7.10-natives-27494512086700/liblwjgl.so which might have disabled stack guard. The VM will try to fix the stack guard now.
[00:16:44 INFO]: Client> It's highly recommended that you fix the library with 'execstack -c <libfile>', or link it with '-z noexecstack'.
[00:16:44 INFO]: Client> Exception in thread "main" java.lang.UnsatisfiedLinkError: /data/*/.minecraft/versions/1.7.10/1.7.10-natives-27494512086700/liblwjgl.so: /data/*/.minecraft/versions/1.7.10/1.7.10-natives-27494512086700/liblwjgl.so: verkeerde ELF-klasse: ELFCLASS32 (Possible cause: architecture word width mismatch)
[00:16:44 INFO]: Client>        at java.lang.ClassLoader$NativeLibrary.load(Native Method)
[00:16:44 INFO]: Client>        at java.lang.ClassLoader.loadLibrary1(ClassLoader.java:1965)
[00:16:44 INFO]: Client>        at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1890)
[00:16:44 INFO]: Client>        at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1880)
[00:16:44 INFO]: Client>        at java.lang.Runtime.loadLibrary0(Runtime.java:849)
[00:16:44 INFO]: Client>        at java.lang.System.loadLibrary(System.java:1088)
[00:16:44 INFO]: Client>        at org.lwjgl.Sys$1.run(Sys.java:73)
[00:16:44 INFO]: Client>        at java.security.AccessController.doPrivileged(Native Method)
[00:16:44 INFO]: Client>        at org.lwjgl.Sys.doLoadLibrary(Sys.java:66)
[00:16:44 INFO]: Client>        at org.lwjgl.Sys.loadLibrary(Sys.java:95)
[00:16:44 INFO]: Client>        at org.lwjgl.Sys.<clinit>(Sys.java:112)
[00:16:44 INFO]: Client>        at bao.K(SourceFile:2173)
[00:16:44 INFO]: Client>        at net.minecraft.client.main.Main.main(SourceFile:72)
[00:16:44 ERROR]: java.io.IOException: Stream closed
[00:16:44 ERROR]: Game ended with bad state (exit code 1)
[00:16:44 INFO]: Ignoring visibility rule and showing launcher due to a game crash
De info over versie:
[00:15:29 INFO]: Minecraft Launcher 1.4.4 (through bootstrap 5) started on linux...
[00:15:29 INFO]: Current time is Jul 17, 2014 12:15:29 AM
[00:15:29 INFO]: System.getProperty('os.name') == 'Linux'
[00:15:29 INFO]: System.getProperty('os.version') == '3.11.10-17-desktop'
[00:15:29 INFO]: System.getProperty('os.arch') == 'amd64'
[00:15:29 INFO]: System.getProperty('java.version') == '1.7.0_51'
[00:15:29 INFO]: System.getProperty('java.vendor') == 'Oracle Corporation'
[00:15:29 INFO]: System.getProperty('sun.arch.data.model') == '64'
Ik heb zelf het volgende al geprobeer dit op te lossen door de drivers te update/herinstalleren, draaien op een andere GPU (intel) en ~/.minecraft verwijderen. Ik heb ook geprobeerd om het op te lossen met een "oude" batch.
#!/bin/bash
export LD_LIBRARY_PATH="/usr/lib64/jvm/java-1.7.0-openjdk-1.7.0/jre/lib/amd64"
java -jar -Djava.awt.headless=false Minecraft.jar
Het lijkt namelijk een probleem te zijn met het feit dat minecraft een 32bit versie van lwjgl probeerd te gebruiken. Ik kan alleen nergens een 64bit vinden en ik heb altijd in 64bit gedraaid...
Wie heeft de oplossing? Of moet ik het voorlopig zonder Minecraft doen?
DDH
[ Voor 2% gewijzigd door BM op 17-07-2014 08:10 ]
  • Xerohumoris
Opgelost:
Minecraft werd geladen via een symbolic link. Daar ging het fout. Nu werkt het weer prima.
