A-Open CDRW 12x/10x/40x buffer underrun??
Lo people..
me overbuurman heeft pc hier neer gezet omdat ie geen cd's kon branden met z'n nieuwe A-Open CRRW-er en nou vroeg ie dus of ik er ff naar kon kijken...
ik heb al vanalles geprobeerd... 12x/8x branden, met of zonder image (op HD) maken, maar altijd kreeg ik een bufferunderrun en dat ziet 'r in 't log zo uit:
10:52:11#18 Phase 24 File dlgbrnst.cpp, Line 1353
Caching of files started
10:52:11#19 Phase 25 File dlgbrnst.cpp, Line 1353
Caching of files completed
10:52:11#20 Phase 32 File dlgbrnst.cpp, Line 1353
Simulation started at 12x (1800 KB/s)
10:52:11#21 Text 0 File ThreadedTransferInterface.cpp, Line 1836
Verifying CD position of item 0 (relocatable, no CD pos, patch infos, orig at #0): write at #0
10:52:11#22 Text 0 File Mmc.cpp, Line 15115
Set BUFE: JustLink -> ON
10:53:27#23 SCSI -1013 File Cdrdrv.cpp, Line 1351
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x032E70D0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x10
Sense Qual: 0x02
CDB Data: 0xAA 0x00 0x00 0x00 0xAE 0x60 0x00 0x00 0x00 0x1E 0x00 0x00
Sense Data: 0x71 0x00 0x05 0x00 0x00 0x00 0x00 0x0C
0x00 0x00 0x00 0x00 0x10 0x02
10:53:27#24 mmc -1013 File Writer.cpp, Line 311
Buffer underrun
10:53:27#25 Text 0 File ThreadedTransfer.cpp, Line 218
all writers idle, stopping conversion
10:53:27#26 Text 0 File ThreadedTransfer.cpp, Line 212
conversion idle, stopping reader
10:53:28#27 Phase 34 File dlgbrnst.cpp, Line 1353
Simulation failed at 12x (1800 KB/s)
11:03:59#28 Phase 36 File dlgbrnst.cpp, Line 1353
Burn process started at 12x (1800 KB/s)
11:03:59#29 Text 0 File ThreadedTransferInterface.cpp, Line 1836
11:03:59#30 Text 0 File Mmc.cpp, Line 15115
11:04:08#31 SCSI -1152 File Cdrdrv.cpp, Line 1142
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x64
Sense Qual: 0xC0
CDB Data: 0x54 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0C
0x00 0x00 0x00 0x00 0x64 0xC0
11:04:14#32 SCSI -1152 File Cdrdrv.cpp, Line 1351
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x032D809C
Sense Code: 0x64
Sense Qual: 0xC0
CDB Data: 0xAA 0x00 0xFF 0xFF 0xFF 0x6A 0x00 0x00 0x00 0x1E 0x00 0x00
11:04:14#33 mmc -1152 File Writer.cpp, Line 311
Medium speed error
11:04:14#34 Text 0 File ThreadedTransfer.cpp, Line 218
11:04:14#35 Text 0 File ThreadedTransfer.cpp, Line 212
11:04:15#36 Phase 38 File dlgbrnst.cpp, Line 1353
Burn process failed at 12x (1800 KB/s)
11:04:15#37 Text 0 File Scsicmd.cpp, Line 371
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Heeft iemand een idee hoe dit komt...
tis een Celeron 500Mhz met 64mb ram en de hd op primary master en de cd-rom speler op secondary master en de CDRW op secondary slave...
  • BYM
  • Laatst online: 31-01 14:50
BYM
In memoriam : De Gulden
Op maandag 11 juni 2001 11:40 schreef Locutus-of-Borg het volgende:
Lo people..
[knip logboek]
Ik persoonlijk zet een CD-brander altijd op de secondary master en een cd-rom op slave, dat zou je alvast kunnen proberen.....
Als ik een goeie signature zou weten, zou ik die hier neerzetten.
  • Shinji_Ikari
  • Laatst online: 06-12-2024
Draaien er geen andere progjes die het branden onderbreken\verstoren?
Misschien een ander progje voor het branden gebruiken?
Suc6
  • SmidsY
  • Laatst online: 10-09 19:43
SmidsY
hallo!?.............
dit probleem komt mij bekend voor, heb het zelf ook verschillende malen gezien (bij plextors). Als alle instellingen goed zijn, en geen progs op de achtergrond draaien die het branden bemoeilijken zeg ik driver verrot. Bij plextor kan je op de site een proggie downen die hun drivres test om te checken of dat zo is, misschien dat A-open ook zo iets heeft.
veel suc6
Het probleem is gelokaliseerd, het bevindt zich tussen het keyboard en de rugleuning.
Update!
Ik heb DMA aangezet voor beide cd-rom spelers en nu is de bufferunderun weg, maar is er weer iets nieuws:
15:23:06#336 Phase 24 File dlgbrnst.cpp, Line 1353
15:23:06#337 Phase 25 File dlgbrnst.cpp, Line 1353
15:23:08#338 Phase 36 File dlgbrnst.cpp, Line 1353
15:23:08#354 Text 0 File Mmc.cpp, Line 15115
15:23:18#355 SCSI -1152 File Cdrdrv.cpp, Line 1142
Sense Code: 0x64
Sense Qual: 0xC0
15:23:25#356 SCSI -1152 File Cdrdrv.cpp, Line 1351
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x033574C4
Sense Code: 0x64
Sense Qual: 0xC0
CDB Data: 0xAA 0x00 0xFF 0xFF 0xFF 0x6A 0x00 0x00 0x00 0x1A 0x00 0x00
15:23:25#357 mmc -1152 File Writer.cpp, Line 311
Medium speed error
15:23:25#358 Text 0 File ThreadedTransfer.cpp, Line 218
15:23:25#359 Text 0 File ThreadedTransfer.cpp, Line 212
15:23:26#360 Phase 38 File dlgbrnst.cpp, Line 1353
15:23:26#361 Text 0 File Scsicmd.cpp, Line 371
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.10.1998, size=19270 bytes, created 5-5-99 22:22:00
File 'IoSubsys\NEROCD95.VXD': Ver=4, 0, 0, 16, size=33451 bytes, created 11-6-01 10:23:52
File 'IoSubsys\CDR4VSD.VXD': Ver=2.5 (087), size=197984 bytes, created 2-6-01 10:00:02
File 'IoSubsys\CDFS.VXD': Ver=4.10.1998, size=59133 bytes, created 5-5-99 22:22:00
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 5-5-99 22:22:00
File '..\System\Vmm32\Ios.vxd': Ver=4.10.2222, size=69574 bytes, created 5-5-99 22:22:00
File 'IoSubsys\Disktsd.vxd': Ver=4.10.2222, size=18809 bytes, created 5-5-99 22:22:00
  • AlPha.BeYoNdeR
  • Laatst online: 04-05 16:07
Probeer nu eens op 8x of 4x te branden
Welke software gebruik je? (Mijn AOpen doet het voor geen FLIKKER met Nero, met Easy CD Creator 5 Platinum doet hij het peeeerfect en met CloneCD ook heel goed.
Nero = :r :r :r
Op maandag 11 juni 2001 16:18 schreef iefje het volgende:
Nero = :r :r :r
Mja, Nero 5.523 idd, denk ook dat het daar aan ligt.. ga nu Easy CD Creator proberen :P
  • Milly
Ik draai Nero v5.5.2.3. zonder probs (12x) op m'n AOpen 12x10x32... Ik denk dat de fout bij jou exemplarisch is!
Op maandag 11 juni 2001 18:32 schreef millyways het volgende:
Het lijkt erop, maar een andere overbuurvrouw had hetzelfde probleem met een andere brander en ook Nero en die installeerden toen Easy CD Creator en toen werkte wel alles ok.
Maar dan moet iemand mij maar eens vertellen hoe je aan Easy CD Creator komt. Ik had hier nog een cd liggen met versie 3, maar de upgrade (enige legale wat ik kan vinden) werkt daar niet op. En de versie is te oud en detecteerd de cdrw nie ;(
