Directadmin niet bereikbaar
Mijn directadmin is niet bereikbaar van buitenaf de VPS.
Maar lokaal werkt hij wel.
firewall is uit.
error logs:
[root@server directadmin]# cat /var/log/directadmin/error.log (this one is empty even with ./directadmin b200)
[root@server directadmin]# cat /var/log/directadmin/errortaskq.log
2014:07:01-04:20:01: Reset All has started
2014:07:01-04:20:01: Reset All has finished
[root@server directadmin]# cat /var/log/directadmin/system.log
2014:07:04-20:15:01: directadmin started
2014:07:04-20:17:33: signal TERM received. Waiting for children to exit
2014:07:04-20:17:33: Clean shutdown successful
[root@server directadmin]# cat /var/log/directadmin/security.log
cat: /var/log/directadmin/security.log: Bestand of map bestaat niet
Hier enkele test's (local):
[root@server directadmin]# service iptables status
iptables: Firewall is not running.
[root@server directadmin]# telnet localhost 2222
Trying ::1...
telnet: connect to address ::1: Connection refused
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
GET / HTTP/1.1
User-Agent: Testing
Accept: ALL
Connection: close
HTTP/1.1 200 OK
Server: DirectAdmin Daemon v1.45.4 Registered to Today ISP B.V.
Set-Cookie: session=; path=/; HttpOnly
Connection: close
Cache-Control: no-cache
Pragma: no-cache
X-DirectAdmin: unauthorized
Content-Type: text/html
(..... removed HTML part .....)
Connection closed by foreign host.
Hier enkele test's (eigen pc):
MacBook-Pro-van-Wesley:~ Wes$ telnet 185.27.175.28 2222
Trying 185.27.175.28...
telnet: connect to address 185.27.175.28: Operation timed out
telnet: Unable to connect to remote host
MacBook-Pro-van-Wesley:~ Wes$ telnet 185.27.175.28 80
Connected to hosted.by.pcextreme.
GET / HTTP/1.1
User-Agent: test from local
Accept: ALL
Connection: close
HTTP/1.1 400 Bad Request
Date: Fri, 04 Jul 2014 18:42:47 GMT
Server: Apache/2
Content-Length: 287
Connection: close
Content-Type: text/html; charset=iso-8859-1
Ik heb het volgende al geprobeert:
http://help.directadmin.com/item.php?id=75
http://help.directadmin.com/item.php?id=30
http://www.directadmin.com/features.php?id=1168
http://help.directadmin.com/item.php?id=293
Ik hoop dat iemand me kan helpen om dit probleem op te lossen
Alvast bedankt.
[ Voor 1% gewijzigd door Verwijderd op 04-07-2014 21:15 . Reden: typo ]
  • LXXI
Wat voor output geeft lsof -i :2222 op de VPS?
  • pablo_p
  • Laatst online: 05-04 09:35
Weet je zeker dat netadmin luistert op het externe IP adres? Probeer eens een een connectie vanaf de VPS zelf naar het externe interface IP adres (ipv loopback). Misschien is netadmin wel alleen aan de loopback interface verbonden. Wat voor output geeft: "netstat -an | grep 2222"
  • Equator
  • Laatst online: 16:24
Equator
Crew Council
🦺#Rodekruis #whisky #barista
Mja, dit heeft natuurlijk niets met Professional Networking & Servers te maken. Move naar Serversoftware en Windows Servers :)
