• sdk1985
  • Laatst online: 27-08 15:57
Ik op mijn XAMPP installatie regelmatig een error:
Bad Request
Your browser sent a request that this server could not understand.
Size of a request header field exceeds server limit.
Cookie
Apache/2.4.9 (Win32) OpenSSL/1.0.1g PHP/5.5.11 Server at blabla.info Port 80
Krijg er zojuist weer één maar niks in de apache error.log te vinden rond de tijd dat het voorkomt. Het clearen van mijn browser cookies lost het probleem overigens wel op. Toch zou ik graag achterhalen waar het probleem nu precies vandaan komt...
Op google werd ik ook niet echt wijzer. Heb dan ook eigenlijk totaal geen ervaring met apache en errors debuggen.
[Sun Jun 15 05:17:21.139264 2014] [cgi:error] [pid 2240:tid 1664] [client 185.56.80.133:35126] script not found or unable to stat: C:/xampp/cgi-bin/php
[Sun Jun 15 05:17:21.171266 2014] [cgi:error] [pid 2240:tid 1664] [client 185.56.80.133:35126] script not found or unable to stat: C:/xampp/cgi-bin/php5
[Sun Jun 15 05:17:21.195267 2014] [cgi:error] [pid 2240:tid 1664] [client 185.56.80.133:35126] script not found or unable to stat: C:/xampp/cgi-bin/php-cgi
[Sun Jun 15 05:17:21.215268 2014] [cgi:error] [pid 2240:tid 1664] [client 185.56.80.133:35126] script not found or unable to stat: C:/xampp/cgi-bin/php.cgi
[Sun Jun 15 05:17:21.236270 2014] [cgi:error] [pid 2240:tid 1664] [client 185.56.80.133:35126] script not found or unable to stat: C:/xampp/cgi-bin/php4
[Sun Jun 15 05:34:05.108557 2014] [mpm_winnt:notice] [pid 1828:tid 372] AH00422: Parent: Received shutdown signal -- Shutting down the server.
[Sun Jun 15 05:34:07.136560 2014] [mpm_winnt:notice] [pid 2240:tid 272] AH00364: Child: All worker threads have exited.
[Sun Jun 15 05:34:07.230160 2014] [mpm_winnt:notice] [pid 1828:tid 372] AH00430: Parent: Child process 2240 exited successfully.
[Sun Jun 15 14:08:00.368322 2014] [ssl:warn] [pid 1840:tid 376] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Sun Jun 15 14:08:01.565390 2014] [ssl:warn] [pid 1840:tid 376] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Sun Jun 15 14:08:02.229428 2014] [mpm_winnt:notice] [pid 1840:tid 376] AH00455: Apache/2.4.9 (Win32) OpenSSL/1.0.1g PHP/5.5.11 configured -- resuming normal operations
[Sun Jun 15 14:08:02.229428 2014] [mpm_winnt:notice] [pid 1840:tid 376] AH00456: Apache Lounge VC11 Server built: Mar 16 2014 12:13:13
[Sun Jun 15 14:08:02.229428 2014] [core:notice] [pid 1840:tid 376] AH00094: Command line: 'C:\\xampp\\apache\\bin\\httpd.exe -d C:/xampp/apache'
[Sun Jun 15 14:08:02.234429 2014] [mpm_winnt:notice] [pid 1840:tid 376] AH00418: Parent: Created child process 2248
AH00548: NameVirtualHost has no effect and will be removed in the next release C:/xampp/apache/conf/extra/httpd-vhosts.conf:82
[Sun Jun 15 14:08:07.100707 2014] [ssl:warn] [pid 2248:tid 272] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Sun Jun 15 14:08:08.635795 2014] [ssl:warn] [pid 2248:tid 272] AH01909: www.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Sun Jun 15 14:08:08.891809 2014] [mpm_winnt:notice] [pid 2248:tid 272] AH00354: Child: Starting 150 worker threads.
Iemand een tip?
Misschien is een clue dat het verkeerde domein onder de error code staat. Ik heb iets van 6 virtual hosts gemaakt. Elk met een eigen map in htdocs.
[ Voor 5% gewijzigd door sdk1985 op 16-06-2014 01:00 ]
  • brid
  • Laatst online: 30-07 16:21
brid
Onze excuses voor het ongemak
De melding kan toch niet duidelijker.......
De maxrequestsize in apache is blijkbaar te laag.
Er is genoeg info te vinden over hoe dit aan te passen. Bij me zelfs de eerste hit bij google op Size of a request header field exceeds server limit.
DIY NAS, Hoofd PC
Unchain your pc/laptop, buy a SSD!!!!!
