Kan .NET Framework 3.5 feature niet aanzetten in Windows 8.1
  • abusimbal
  • Laatst online: 11-08 23:31
Hallo, ben een beetje ten einde raad.
Heb Windows 8.1 Pro 64bit met laatste updates (update1)
Ik probeer VMWare Vsphere client te installeren, installatie loopt vast omdat .NET Framework 3.5 ontbreekt.
Dan geprobeerd deze feature in te schakelen via configuratiescherm programma's en onderdelen. Krijg fout 0x80070005 toegang geweigerd.
Dan feature geforceerd proberen te installeren met:dism /online /enable-feature /all /featurename:NetFX3 /source:D:\sources\sxs
Zoals hier staat: MSDN: Installing the .NET Framework 3.5 on Windows 8 or 8.1
Krijg dan weer error5: toegang geweigerd.
Dit kom ik in log file tegen:
Warning DISM DISM Provider Store: PID=11180 TID=9600 Failed to Load the provider: C:\Users\xxxxx\AppData\Local\Temp\3AE26544-70D0-4C40-AA43-F926C053F298\PEProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2014-06-02 20:00:48, Warning DISM DISM Provider Store: PID=11180 TID=9600 Failed to get the IDismObject Interface - CDISMProviderStore::Internal_LoadProvider(hr:0x80004002)
2014-06-02 20:00:48, Warning DISM DISM Provider Store: PID=11180 TID=9600 Failed to Load the provider: C:\Users\xxx\AppData\Local\Temp\3AE26544-70D0-4C40-AA43-F926C053F298\Wow64provider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x80004002)Warning DISM DISM Provider Store: PID=11180 TID=9600 Failed to Load the provider: C:\Users\xxx\AppData\Local\Temp\3AE26544-70D0-4C40-AA43-F926C053F298\EmbeddedProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2014-06-02 20:01:27, Error DISM DISM Package Manager: PID=11180 TID=9600 Failed finalizing changes. - CDISMPackageManager::Internal_Finalize(hr:0x80070005)
2014-06-02 20:01:27, Error DISM DISM Package Manager: PID=11180 TID=9600 Failed processing package changes with session options - CDISMPackageManager::ProcessChangesWithOptions(hr:0x80070005)
2014-06-02 20:01:27, Error DISM DISM Package Manager: PID=11180 TID=9600 Failed ProcessChanges. - CPackageManagerCLIHandler::Private_ProcessFeatureChange(hr:0x80070005)
2014-06-02 20:01:27, Error DISM DISM Package Manager: PID=11180 TID=9600 Failed while processing command enable-feature. - CPackageManagerCLIHandler::ExecuteCmdLine(hr:0x80070005)
2014-06-02 20:01:27, Error DISM DISM.EXE: DISM Package Manager processed the command line but failed. HRESULT=80070005
Iemand nog een idee wat ik zou kunnen proberen ?
  • Daannn1987
  • Laatst online: 15:31
Probeer eerst eens UAC uit te zetten
En anders op en je een Command prompt als Admin
En voer je de onderstaande regel uit:
DISM /Online /Enable-Feature /FeatureName:NetFx3 /All /LimitAccess /Source:d:\sources\sxs
Hierboven wordt er van uitgegaan dat d:\ de Windows 8 instal disk is.
21xDMEGC 440wp (9240) ||| Pana 9j
  • Hero of Time
  • Laatst online: 16:36
Hero of Time
Moderator LNX
There is only one Legend
Waarom heb je vSphere nodig? Welke Vmware ESX wordt er gebruikt? Want er is al een tijdje een webinterface beschikbaar (vereist wel Adobe Flash 11.5 of nieuwer), sinds 5.1 is die aanwezig.
Dus, welke zeer goede reden heb je om te lopen aanklooien met .NET wat op zich al een drama blijkt te zijn? Daarbij. .NET v4 zou alles van 3.5 en ervoor ook moeten doen en die kan je via Microsoft Update binnen halen.
Commandline FTW
  • abusimbal
Bedankt voor de hulp.
CMD heb ik als admin gerund. En D: is DVD drive met win8.1 DVD.
Ik heb vSphere 5.5, de gratis versie, daar werkt die webinterface toch niet op dacht ik.
Daarvoor die je vCenter Server te hebben, is alleen bij betaalde licenties.
  • Daannn1987
Maar is het nou gelukt? :+
Zelf Vmware Esxi sinds 4.5 niet meer gebruikt, maar de webinterface is wel een uitkomst aannemende dat dezelfde functies behouden blijven (mounten etc)
  • abusimbal
Nee, nog niet gelukt. Begrijp het niet op een ander win8.1 machine installerde hij wel.
  • Daannn1987
User account control al op disabled gezet?
  • Turdie
  • Laatst online: 20-04 14:54
En heb je het al via het control panel geprobeerd:
You can also enable the .NET Framework 3.5 yourself through Control Panel. In Control Panel, choose Programs and Features, choose Turn Windows features on or off, and then select the .NET Framework 3.5 (includes .NET 2.0 and 3.0) check box. This option requires an Internet connection. You do not need to select the child items for Windows Communication Foundation (WCF) HTTP activation unless you are a developer who requires WCF script and handler mapping functionality.
Daannn1987 schreef op maandag 02 juni 2014 @ 21:36:
Dat is echt niet nodig...
[ Voor 14% gewijzigd door Turdie op 02-06-2014 21:38 ]
  • abusimbal
Ja, via control panel was eerste dat ik deed. Ga nu UAC uitzetten en opnieuw proberen.
  • Daannn1987
shadowman12 schreef op maandag 02 juni 2014 @ 21:38:
Volgens mij wel:
  • abusimbal
Met UAC uitzetten helpt ook niet. had ook all alle beveiligingssoftware uitgeschakeld om te testen.
  • Turdie
Ik denk dat je Component Store corrupt is, op basis van je logfile. Probeer eens dit commando te draaien:
DISM /Online /Cleanup-Image /RestoreHealth
In een elevated command prompt
http://blogs.technet.com/...erver-2012.aspx?pi47623=7
http://blogs.technet.com/...ine-amp-offline-mode.aspx
[ Voor 28% gewijzigd door Turdie op 02-06-2014 21:46 ]
  • abusimbal
Heb dat gedaan en dan opnieuw DISM /Online /Enable-Feature /FeatureName:NetFx3 /All /LimitAccess /Source:d:\sources\sxs
Of moest ik eerst rebooten, want resultaat blijft hetzelfde.
Niets werkt, ook niet met offline mode.
Ik laat het rusten. Werk wel op die andere windows 8.1 via RDP.
Toch bedankt om mee te helpen.
[ Voor 28% gewijzigd door abusimbal op 02-06-2014 22:03 ]
  • Hammetje
  • Laatst online: 18:01
Even een schopje: Heb jij dit al weten op te lossen?
Ik loop momenteel tegen exact dezelfde problemen aan. Wanneer ik het onderdeel wil inschakelen bij programma's en onderdelen krijg ik dezelfde foutcode als die jij krijgt.
Ben benieuwd...
"Het is pas haute cuisine als het de frituurpan heeft gezien" - @VanRoyal (2021)
  • deadlock2k
  • Laatst online: 01-12-2025
[ Voor 99% gewijzigd door deadlock2k op 06-08-2021 15:35 ]
  • abusimbal
Nee, nog geen oplossing. In november nog windows volledig opnieuw geinstalleerd, na alle drivers en updates heb ik NET Framework 3.5 proberen te activeren, maar helaas.
  • hardware-lover
hardware-lover
verder kijken dan ......
Edit: -overbodig-
[ Voor 133% gewijzigd door hardware-lover op 11-12-2014 12:36 ]
Testing, one, two ...
  • Seaborz
  • Laatst online: 02-10 18:43
Hier staat een standalone installer die je op windows 8/2012 kan gebruiken. Werkt bij mij altijd perfect.
http://forums.mydigitalli...r-for-Windows-8-1-x86-x64
  • hardware-lover
hardware-lover
Seaborz schreef op woensdag 10 december 2014 @ 16:56:
Dat werkte voor mij ook niet destijds...
  • Hammetje
Geeft bij mij een Error 5 code, in het command prompt.Toegang geweigerd, zelfs als ik die exe open als administrator.
  • Hero of Time
Hero of Time
Moderator LNX
deadlock2k schreef op woensdag 10 december 2014 @ 15:49:
Windows 8.1 bevat 4 & 4.5, niet 3.5 en ouder. 2.0-3.5 wordt geïnstalleerd door die feature aan te zetten. En daarnaast is de webinterface ronduit kut, onbetrouwbaar en het draait op Flash. En het zal mij verbazen als de vSphere client niet gereactiveerd wordt want ook binnen onder andere VMUG wordt er gigantisch hard over geklaagd.
Maar voor Linux gebruikers zoals ik de enige oplossing. Jij vindt 't misschien ruk, maar het is iig iets dat gewoon werkt, itt .NET Framework op W8. Je kan zeggen wat je wilt, maar MS heeft het gewoon weer eens voor elkaar om hun eigen software ongeschikt te maken voor hun OS, om toch nog te blijven beweren dat 't werkt. Ja, dat doet 't wel, als je de feature eerst aanzet voordat je alle updates toepast. 8)7
Niet om een flamewar te beginnen over MS, laat ik dat even voorop stellen. We zijn in zekere mate verplicht 't te gebruiken en mijn kennis over het systeem overstijgt op verschillende vlakken die van mijn collega's die er dagelijks mee werken (werk en privé). En ik prefereer 't nog steeds boven OSX. Ik sta alleen versteld van de incompetentie die 't bedrijf zo/te vaak laat zien.
Commandline FTW
  • Killah_Priest
  • Laatst online: 00:35
Van de week nog tegenaan gelopen op een 2012R2 server (zelf nooit eerder tegenaan gelopen omdat ik normaal gesproken direct .net 3.5 al bij het deployen vanaf onze WDS / MDT server direct al installeer ivm meerdere monitoring en backup tools welke dit nodig hebben).
De fix van MS zelf op hun KB : http://support2.microsoft.com/kb/3005628
  • Hammetje
Die updates staan op mijn computer niet geinstalleerd. Volgens Windows Update ben ik up to date...
  • Hero of Time
Hero of Time
Moderator LNX
Ze kunnen opgevolgd zijn door andere updates waardoor je deze betreffende niet krijgt of ziet, maar wel zijn toegepast.
Commandline FTW
  • CAP-Team
  • Laatst online: 02-10 21:26
CAP-Team
XBL: CAPTeam
Ik gebruik zelf vaak een programma mRemoteNG die heeft ook .NET 3.5 nodig, maar als ik die aftrap als die nog niet geïnstalleerd is komt de installer automatisch naar voren.
Microsoft Surface Pro 6 | Samsung Galaxy S21FE | XBOX Series X
  • deadlock2k
[ Voor 100% gewijzigd door deadlock2k op 06-08-2021 15:35 ]
  • Hero of Time
Hero of Time
Moderator LNX
Wat ik hier op m'n werk heb begrepen, is dat de stekker er helemaal niet uit is. Je hebt naast de webinterface met flash ook nog gewoon de client tool. Daar kan je weer net wat anders mee dan met de flash interface. Maar met flash kan je weer iets makkelijker doen dan met de client. Beetje jammer dat ze niet gelijkwaardig zijn mbt features.
Maar goed, een degelijke tool dat overal op werkt is gewoon 't beste. Want Linux gebruikers zitten weer vast aan Chrome, omdat Adobe de flash plugin maar tot versie 11.2 heeft gemaakt en vSphere 11.5+ vereist. :|
Commandline FTW
  • Hammetje
Nou, heb inmiddels mijn probleem met betrekking tot het installeren van .NET 2.0/3.0/3.5 weten op te lossen. Complete reinstall gedaan van Windows 8.1 pro (NL/x64). Eerste wat ik deed toen ik het bureaublad voor me kreeg was het toevoegen via config scherm > programma's en onderdelen > onderdelen aan win 8 toevoegen. De installatie verliep toen vlekkeloos.
Niet echt een oplossing als je, je complete besturingssysteem opnieuw moet installeren, maar deze manier werkt dus wel.
