• Killop
  • Laatst online: 23-12-2021
Killop
It never hurts to help
Ik ben bezig met een upgrade van Exchange 2007 naar 2013.
De huidige server is een Windows Server 2003 machine met Exchange 2007.
De nieuwe server is een Windows Server 2012 Datacenter waar Exchange 2013 SP1 op geïnstalleerd moet worden.
Helaas krijg ik bij de installatie van Exchange 2013 SP1 de volgende foutmelding:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
Error:
The following error was generated when "$error.Clear();
          if ($RoleIsDatacenter -ne $true)
            if (Test-ExchangeServersWriteAccess -DomainController $RoleDomainController -ErrorAction SilentlyContinue)
              $sysMbx = $null;
              $name = "SystemMailbox{bb558c35-97f1-4cb9-8ff7-d53741dc928c}";
              $dispName = "Microsoft Exchange";
              Write-ExchangeSetupLog -Info ("Retrieving mailboxes with Name=$name.");
              $mbxs = @(Get-Mailbox -Arbitration -Filter {name -eq $name} -IgnoreDefaultScope -ResultSize 1 );
              if ($mbxs.Length -eq 0)
                Write-ExchangeSetupLog -Info ("Retrieving mailbox databases on Server=$RoleFqdnOrName.");
                $dbs = @(Get-MailboxDatabase -Server:$RoleFqdnOrName -DomainController $RoleDomainController);
                if ($dbs.Length -ne 0)
                  Write-ExchangeSetupLog -Info ("Retrieving users with Name=$name.");
                  $arbUsers = @(Get-User -Filter {name -eq $name} -IgnoreDefaultScope -ResultSize 1);
                  if ($arbUsers.Length -ne 0)
                    Write-ExchangeSetupLog -Info ("Enabling mailbox $name.");
                    $sysMbx = Enable-Mailbox -Arbitration -Identity $arbUsers[0] -DisplayName $dispName -database $dbs[0].Identity;
              else
                if ($mbxs[0].DisplayName -ne $dispName )
                   Write-ExchangeSetupLog -Info ("Setting DisplayName=$dispName.");
                   Set-Mailbox -Arbitration -Identity $mbxs[0] -DisplayName $dispName -Force;
                $sysMbx = $mbxs[0];
              # Set the Organization Capabilities needed for this mailbox
              if ($sysMbx -ne $null)
                # We need 1 GB for uploading large OAB files to the organization mailbox
                Write-ExchangeSetupLog -Info ("Setting mailbox properties.");
                set-mailbox -Arbitration -identity $sysMbx -UMGrammar:$true -OABGen:$true -GMGen:$true -ClientExtensions:$true -MailRouting:$true -MaxSendSize 1GB -Force;
              else
                Write-ExchangeSetupLog -Info ("Cannot find arbitration mailbox with name=$name.");
            else
              Write-ExchangeSetupLog -Info "Skipping creating E15 System Mailbox because of insufficient permission."
        " was run: "Database is mandatory on UserMailbox.".
Error:
              $sysMbx = $null;
              else
                $sysMbx = $mbxs[0];
              else
            else
        " was run: "Database is mandatory on UserMailbox. Property Name: Database".
Het account waarmee ik de installatie uitvoer is lid van Domain Admins, Enterprise Admins & Schema Admins.
Ik heb de volgende handleiding voor de installatie van Exchange 2013 gebruikt:
http://www.petri.co.il/ho...exchange-server-2013.htm#
Echter loopt deze vast bij het installeren van de mailboxen.
Ik heb gezocht op internet naar de bovenstaande meldingen.
Het enige dat ik gevonden heb is het opnieuw uitvoeren van de regels:
Setup /IAcceptExchangeServerLicenseTerms /PrepareSchema
Setup /IAcceptExchangeServerLicenseTerms /PrepareAD /OrganizationName:yourOrganizationalname
Setup /IAcceptExchangeServerLicenseTerms /PrepareAllDomains
Deze heb ik meerdere malen uitgevoerd maar geen verandering.
Momenteel weet ik niet welke informatie ik nog meer kan aanleveren.
Mocht je vragen hebben laat het me weten, dan zal ik die proberen zo snel mogelijk te beantwoorden.
Alvast bedankt.
What are we gonna do tonight?
  • Outerspace
  • Laatst online: 18:51
Outerspace
Admin General Chat
Pak dit er eens bij, wordt je er dan wijzer van?
http://social.technet.mic...2?forum=exchangesvrdeploy
Bij welke stap krijg je die foutmelding?
Wauw, een sig!
  • Oogje
Any errors in spelling, tact, or fact are transmission errors.
  • Killop
Killop
De foutmelding komt bij het installeren van Mailbox role: Mailbox service.
Volgens mij is dit stap 10 van 14.
Ik ben de links aan het bekijken.
Zojuist nogmaals de Setup laten lopen als administrator.
Bij 84% van Mailbox role: Mailbox service komt de melding zoals ik in de openingspost gezet heb.
[ Voor 34% gewijzigd door Killop op 19-05-2014 16:05 ]
  • 3DDude
  • Laatst online: 22:43
3DDude
I void warranty's
Je prerequisites check heeft die wel helemaal doorlopen?
Dan geeft die meestal aan je moet X of Y nog installeren..
[ Voor 34% gewijzigd door 3DDude op 19-05-2014 14:50 ]
Be nice, You Assholes :)
  • Killop
Killop
Ja de prerequisites zijn volledig geïnstalleerd.
Als dat niet zo had geweest was ik niet zover gekomen. :)
  • Wim-Bart
  • Laatst online: 10-01-2021
Wim-Bart
Zie signature voor een baan.
IPv6 aan staan op je server, en op je domein controllers? is een must voor EX2013 en als het een VM is onder Hyper-V dan moet je geen dynamische disk hebben, maar een volledige disk voor je mailbox store (dus niet op auto grow).
Beheerders, Consultants, Servicedesk medewerkers. We zoeken het allemaal. Stuur mij een PM voor meer info of kijk hier De mooiste ICT'er van Nederland.
  • Toasterlabs
  • Laatst online: 02-11 15:57
Handig als je wat meer informatie zou geven:
Waar installeer je exchange, hoeveel vrij ruimte heb je, is ipv6 enabled (en als het uitstaat is het volgens de enige goede manier uitgezet? Nml in het register EN op de NIC?), exchange setup logs etc...
  • Jazzy
  • Laatst online: 22:54
Jazzy
Moderator SSC/PB/AI
Moooooh!
De enige goede manier om IPv6 uit te schakelen is in het register en niet op de NIC. IPv6 of onderdelen van IPv6 uitschakelen in Windows
[ Voor 20% gewijzigd door Jazzy op 22-05-2014 07:21 ]
  • anielk
  • Laatst online: 18-09-2023
wat was hier nou de oplossing van? :?
  • Jazzy
Jazzy
Moderator SSC/PB/AI
Moooooh!
Vraag je dat omdat je hetzelfde probleem hebt? Misschien kun jij dan even de ontbrekende informatie aanvullen.
