Ubuntu start niet op
  • MacLinux
  • Laatst online: 27-03-2024
Ubuntu 13.04
Tijdens updaten is computer uitgevallen
Herstart met LIVE CD
apt-get update
dpkg -- configure -a
Alles opnieuw ingesteld
Na herstart: kan root file system niet vinden
/dev/sda1 is /boot
fsck.ext4 /dev/sda1
clean
fdisk /dev/sda1
fdisk /dev/sda1
Command (m for help): p
Disk /dev/sda1: 197 MB, 197374464 bytes
255 heads, 63 sectors/track, 23 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0xddcdd6e3
Device Boot Start End Blocks Id System
ls -l /mnt/bootdisk (/dev/sda1)
ls -l /mnt/bootdisk
total 93166
-rw-r--r-- 1 root root 1009450 2013-10-09 16:45 abi-3.11.0-12-generic
-rw-r--r-- 1 root root 1010148 2014-01-30 17:59 abi-3.11.0-15-generic
-rw-r--r-- 1 root root 1011333 2014-02-18 21:38 abi-3.11.0-18-generic
-rw-r--r-- 1 root root 1162233 2014-04-10 20:23 abi-3.13.0-24-generic
-rw-r--r-- 1 root root 168533 2013-10-09 16:45 config-3.11.0-12-generic
-rw-r--r-- 1 root root 168527 2014-01-30 17:59 config-3.11.0-15-generic
-rw-r--r-- 1 root root 168540 2014-02-18 21:38 config-3.11.0-18-generic
-rw-r--r-- 1 root root 169631 2014-04-10 20:23 config-3.13.0-24-generic
drwxr-xr-x 5 root root 1024 2014-04-28 10:24 grub
-rw-r--r-- 1 root root 16925924 2014-01-06 19:17 initrd.img-3.11.0-12-generic
-rw-r--r-- 1 root root 17045686 2014-02-01 15:57 initrd.img-3.11.0-15-generic
-rw-r--r-- 1 root root 17046009 2014-04-24 20:54 initrd.img-3.11.0-18-generic
-rw-r--r-- 1 root root 5628346 2014-04-28 10:25 initrd.img-3.13.0-24-generic
drwx------ 2 root root 12288 2014-01-06 18:18 lost+found
-rw-r--r-- 1 root root 176500 2014-03-12 12:31 memtest86+.bin
-rw-r--r-- 1 root root 178176 2014-03-12 12:31 memtest86+.elf
-rw-r--r-- 1 root root 178680 2014-03-12 12:31 memtest86+_multiboot.bin
-rw------- 1 root root 2621091 2013-10-09 16:45 System.map-3.11.0-12-generic
-rw------- 1 root root 2627916 2014-01-30 17:59 System.map-3.11.0-15-generic
-rw------- 1 root root 2629740 2014-02-18 21:38 System.map-3.11.0-18-generic
-rw------- 1 root root 2685850 2014-04-10 20:23 System.map-3.13.0-24-generic
-rw-r--r-- 1 root root 5632848 2013-12-30 15:15 vmlinuz-3.11.0-12-generic
-rw------- 1 root root 5663888 2014-01-30 17:59 vmlinuz-3.11.0-15-generic
-rw------- 1 root root 5667920 2014-02-18 21:38 vmlinuz-3.11.0-18-generic
-rw------- 1 root root 5800848 2014-04-10 20:23 vmlinuz-3.13.0-24-generic
Rara hoe kan dit. fdisk vindt begin nog eind en er staat gewoon data op?
In /etc/fstab heb ik de UUID's gecontroleerd. Deze zijn correct.
  • Hero of Time
  • Laatst online: 20-10 22:19
Hero of Time
Moderator LNX
There is only one Legend
Tja, /dev/sda1 is /boot en het kan / niet vinden tijdens opstarten. Je bent bij de verkeerde boom aan het blaffen. Controleer je omgeving eens nog een keer, maar nu eens met /dev/sda2. Hoe heb je de UUIDs gecontroleerd?
Commandline FTW
  • MacLinux
In /etc/fstab staan de UUID's en met blkid /dev/sdaX de UUID's gecontroleerd.
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda6 during installation
UUID=a10a45be-3e29-4709-bd59-92d43b738de9 / ext4 errors=remount-ro 0 1
# /boot was on /dev/sda1 during installation
UUID=d25f9867-6797-4858-bc32-aecf54b69884 /boot ext4 defaults 0 2
# /home was on /dev/sda9 during installation
# UUID=bcc1792c-af06-455a-ab1a-49992b2d016f /home ext4 defaults 0 2
# /usr was on /dev/sda5 during installation
UUID=89d6113f-7e61-4571-9f08-90a1aef0eaf0 /usr ext4 defaults 0 2
# /var was on /dev/sda7 during installation
UUID=653ece0b-69df-4e93-b266-52c9a3efe87c /var ext4 defaults 0 2
#/home was on /dev/sda8 in former installation
UUID=64f007cf-76e9-4687-b8ad-2f0f024dfeb6 /home ext4 defaults 0 0
# swap was on /dev/sda10 during installation
UUID=497d6035-eeb8-4d2d-82ac-13beccb87b83 none swap sw 0 0
/dev/sda2 is de extended partitie
fdisk /dev/sda
The number of cylinders for this disk is set to 121601.
There is nothing wrong with that, but this is larger than 1024,
and could in certain setups cause problems with:
1) software that runs at boot time (e.g., old versions of LILO)
2) booting and partitioning software from other OSs
(e.g., DOS FDISK, OS/2 FDISK)
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders
Disk identifier: 0x0004679c
/dev/sda1 * 1 24 192748+ 83 Linux
/dev/sda2 25 121601 976567222 5 Extended
/dev/sda5 25 2456 19535008+ 83 Linux
/dev/sda6 2457 3064 4883728+ 83 Linux
/dev/sda7 3065 5496 19535008+ 83 Linux
/dev/sda8 5497 120993 927727652+ 83 Linux
/dev/sda9 120994 121601 4883728+ 82 Linux swap / Solaris
  • MacLinux
Bedankt voor het meedenken. Ik ga een herinstallatie uitvoeren met Debian.
  • Hero of Time
Hero of Time
Moderator LNX
Toch wel apart, je fstab laat sda1, sda5 - sda10 zien, maar je fdisk output gaat tot sda9. Ergens ben je iets kwijt geraakt. Ik vraag mij ook af waarom je /, /var en /usr hebt losgekoppeld.
Nu ga je opnieuw installeren met Debian. Wat hoop je daarmee te bereiken? Welke Debian release ga je gebruiken en wat is je gedachte daarachter, welke motivatie heb je om van Ubuntu naar Debian te gaan?
Commandline FTW
  • MacLinux
Mijn vrouw is ooit begonnen met Debian. Maar omdat Ubuntu meer extra's heeft is ze overgestapt op Ubuntu. De laatste tijd heeft ze veel problemen met Ubuntu. Ook na een nieuwe installatie begonnen de problemen weer. Regelmatig foutmeldingen, pakketten die niet meer werkten enz. Debian is volgens mij een stuk robuuster dan Ubuntu. Dus gaan we weer terug waar we zijn begonnen.
  • Hero of Time
Hero of Time
Moderator LNX
Als je dan opnieuw gaat installeren, wil je misschien liever Mint nemen, Net even wat prettiger voor codecs en andere gesloten packages die niet standaard in Debian zitten. Desnoods pak je LMDE, de Debian based versie (ipv Ubuntu based). Heb je ook gelijk een rolling release, geen last meer van upgrades!
Commandline FTW
  • 12345dan
  • Laatst online: 22-09-2024
Ik sluit me helemaal aan bij Hero of Time. Ik had in het verleden ook veel problemen met Ubuntu, toen heb ik de beslissing genomen om Linux Mint 13 xfce te nemen, het werkt als een trein. Ik heb geen enkel probleem tot nu toe gehad met Linux Mint.
- 12345dan
  • MacLinux
Ik heb er nu Debian Wheezy opgezet, maar als het te beperkt blijkt zal ik overwegen Linux Mint er op te zetten. Bedankt voor de tip.
  • Hero of Time
Hero of Time
Moderator LNX
Beperkt in welke zin? Je kan overigens van Stable naar Testing en dan door naar Mint (of gelijk naar Mint) zonder opnieuw te hoeven installeren. Althans, als je LMDE kiest, Mint Debian Edition. Je moet wel een paar apt config dingetjes doorvoeren, maar het zou redelijk vlekkeloos moeten gaan. Je kan ook de Mint repo toevoegen aan je Debian Testing en alleen een paar onderdelen gebruiken, zoals de non-free codecs e.d.
Het is overigens niet aangeraden om te mixen, omdat je dan niet weet waar nou die ene bug waar je last van hebt vandaan komt (Mint, Debian, of is het de mix dat ervoor zorgt). De migratie zonder herinstall kan wel zonder al te veel problemen (je loopt waarschijnlijk tegen een paar aan tijdens de transitie, maar niets ernstigs, daarna is het puur Mint of Debian, net wat je kiest).
Commandline FTW
