Zit hier met een probleem dat ik de external players niet aan de praat krijg samen met XBMC.
Heb de laatste versie draaien van XBMC en samen met:
- Powerdvd 13
- DVDFab
Allemaal in de default install map.
probleem is dat de blurays/iso's blijven starten in XBMC.
Heb de volgende bestanden gemaakt in: AppData->Roaming->XBMC->userdata
Mis ik iets of kijk ik er gewoon helemaal overheen?
PlayDisc.bat
playercorefactory.xml
PlayISO.bat
- Powerdvd 13
- DVDFab
PlayDisc.bat
| @echo off rem you can place your PlayDisc file in \Roaming\XBMC\userdata\ "C:\Program Files (x86)\CyberLink\PowerDVD13\Movie\PowerDVD Cinema\PowerDVDCinema13.exe" D: |
29
30
31
32
33
34
35
36
| <playercorefactory>
<players>
<player name="DVDFab" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\Htpc\AppData\Roaming\XBMC\userdata\PlayISO.bat</filename>
<args>"{1}"</args>
<hidexbmc>True</hidexbmc>
<hideconsole>true</hideconsole>
<forceontop>false</forceontop>
</player>
<player name="Disc_Player" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Users\Htpc\AppData\Roaming\XBMC\userdata\PlayDisc.bat</filename>
<args>"{1}"</args>
</player>
<player name="PowerDVD" type="ExternalPlayer" audio="false" video="true">
<filename>C:\Program Files (x86)\CyberLink\PowerDVD13\Movie\PowerDVD Cinema\PowerDVDCinema13.exe</filename>
<args>"{1}"</args>
</player>
</players>
<rules action="prepend">
<!-- Bluray ISO/BDMV -->
<rule filetypes="iso|bdmv|mpls" player="DVDFab"/>
<!-- Multiple files -->
<rule filetypes="m2ts|mkv|avi|ts" player="PowerDVD"/>
<!-- Bluray Disc -->
<rule filetypes="bd|ifo" player="Disc_Player"/>
</rules>
</playercorefactory> |
PlayISO.bat
29
30
31
32
| Set file=%1 Set dummy=%file:iso=% IF NOT %dummy% == %file% (GOTO playiso) ELSE (goto next) :next Set file=%1 Set dummy=%file:mpls=% IF NOT %dummy% == %file% (GOTO plaympls) ELSE (goto playbdmv) :playiso "C:\Program Files\DVDFab Virtual Drive\vdrive.exe" /M:F %1 "C:\Program Files (x86)\CyberLink\PowerDVD13\Movie\PowerDVD Cinema\PowerDVDCinema13.exe" E: "C:\Program Files\DVDFab Virtual Drive\vdrive.exe" /M:F /u GOTO end :plaympls set pth=%1 set pth=%pth:~1,-25% "C:\Program Files (x86)\CyberLink\PowerDVD13\Movie\PowerDVD Cinema\PowerDVDCinema13.exe" "%pth%" exit GOTO end :playbdmv set pth=%1 set pth=%pth:BDMV\MovieObject.bdmv=% set pth=%pth:BDMV\index.bdmv=% "C:\Program Files (x86)\CyberLink\PowerDVD13\Movie\PowerDVD Cinema\PowerDVDCinema13.exe" %pth% exit GOTO end :end exit |
[ Voor 27% gewijzigd door Paulus07 op 02-03-2014 12:16 ]
