pc crash tijdens gamen
  • 431 views
Hello everyone,
since some time I've had issues with games that makes my pc crash, no crash report just a reboot.
This mostly happens after 30 seconds on ultra graphics or like 2 minutes on low graphics.
This only happens to some games, such as elder scrolls online, skyrim, borderlands and some others. Note: I installed enbboost for skyrim and adjusted my vid memory to be allocated to the game to 3 gig and I didn't have any crashes anymore. I also don't have problems with games such as bf 4, thief ect on ultra 60 fps.
Any idea how if I'd be able to fix ESO with allocation more memory in some way?
Help me please :(
Drivers are updated and I've had this problem over a lot of different versions of the driver, can't be a driver issue.
my gpu is HD7950 XFX DD
and a i5 3570k on clock speed
I have a PSU with enough wattage and it's from corsair so I don't think that'd be a problem.
update: ESO is fully playable on minimum settings, this looks terrible but it's playable. From low to ultra it keeps crashing after some time
Thanks in advance
Sounds like a temperture problem.
What is the temp of the cpu and gpu?
  • Pataar
  • Laatst online: 18-08 16:37
Did you overclocked gpu or gpu vram?
Stepped on a cornflake, now I'm a cereal killer.
Pataar schreef op zondag 02 maart 2014 @ 18:47:
Verwijderd schreef op zondag 02 maart 2014 @ 17:54:
Beiden niet overclocked en temperaturen zijn in idle 35 en onder lading 60-70.
[ Voor 77% gewijzigd door Verwijderd op 02-03-2014 20:54 ]
Specs of the psu?
corsair 850 w silver + ik had dit probleem al toen ik nog een andere psu had, kan hier niet aan liggen.
  • qrious
  • Laatst online: 30-09-2016
hoe zit het met de belasting, van je CPU/GPU kan het zijn dat er ergens processen vast lopen?
They say that nobody is perfect. Then they tell you practice makes perfect. I wish they'd make up their minds.
jorg5 schreef op maandag 03 maart 2014 @ 09:20:
Volgens afterburner tijdens BF4 waarbij het niet crasht een gemiddelde van 80 procent GPU gebruik.
CPU gebruik bij BF4 rond de 80 procent.
  • interlude
  • Laatst online: 17-10 09:54
Is dit nou een Engelse of een Nederlands forum?
interlude schreef op maandag 03 maart 2014 @ 11:35:
Had dit probleem al gepost op een Engelstalige site en was te leeg om het helemaal te vertalen.
Veel problemen mee mischien?
  • bvk
  • Laatst online: 14:28
bvk
Het gaat nooit snel genoeg!
Verwijderd schreef op maandag 03 maart 2014 @ 12:05:
Niet iedereen is het Engels even machtig en krijg je in het Nederlands dus meer en betere hulp. Is dus in je eigen voordeel ;)
On topic:
Ik heb dit ook wel eens gehad, sommige games die spontaan crashten en met andere totaal geen probleem. Ook stressen met Furmark of 3Dmark, geen krimp. Maar met een potje Bad Company 2 gegarandeerd een crash, soms na 3 minuten, soms na een half uur...
Uiteindelijk bleek het probleem slecht geheugen op de videokaart te zijn, de snelheid ervan wat naar beneden geschroefd en het probleem was verholpen!
Misschien een optie om ook te proberen?
Specs
  • Bolletje
  • Laatst online: 30-10 22:17
Bolletje
De voertaal is Nederlands hier op Tweakers. Gezien je andere topic ben je die taal machtig, vandaar dat ik dit topic sluit.
