USB headset ruis [Carcharias]
  • Rob89
  • Laatst online: 26-10-2025
Zojuist een nieuwe headset gekocht, een Carcharias 2013. De headset geeft een enorm vervelende hiss, white noise, ruis of hoe je het ook wilt noemen op zowel de microphone en speakers.
Na even gezocht te hebben zou dit liggen aan de USB ports, of juist de voeding via de USB ports.
Redelijke oplossingen die ik her en der heb kunnen vinden;
1- USB Phone charger als power source gebruiken
2- Losse geluidskaart
3- Andere USB porten
4- Front / Backpanel USB
Nu heb ik oplossing 1,2 en 4 al geprobeerd en geen van allen werken. Zou een losse geluidskaart dit probleem kunnen verhelpen? Zo ja, dan zet ik er morgen nog een Asus Xonar DG in ;)
Thanks!
Voor diegene die nog geintereseerd is;
"This is a common problem that occurs with amplifiers powered by switching power supplies. The switching frequency used in high power sources such as used in pc are close to the threshold of audible frequencies of 20KHz, and therefore cause interference in the audio. To work around this problem quality sources have common mode filter, but not always the plugs of these sources are grounded and so these filters do not work. Therefore, it is necessary that the sources are effectively grounded. If this filter included not solve the problem you need to add another Butterworth filter of at least third order, consisting of a capacitor (C = 47uF), an inductor choke (L = 10mH) and a capacitor (C = 100uF), connected in series in the supply of 5VDC USB. I advise that you use a USB extension cable to mount this filter so as not to spoil the characteristics of the source.
Another ease solution is the use of a mobile charger with USB output to power this circuit. The low power charger is an AC / DC converter that uses switching frequencies much higher than the high-power sources, and thus does not cause noise. Just watch out how much power your device needs. The power device should not be greater than that delivered by the chargers. Most chargers provide up to 1A output, while the Razer headphones utilize maximum 0.2A."
  • Rob89
De Asus Xonar DG heeft ook niet geholpen. Overigens was het geen slechte aankoop, dit geeft voor mijn gevoel een veel beter geluid.
Overigens heb ik alle denkbare USB poorten van laptops, laptopkoelers en AC>USB adapters gebruikt, geen resultaat.
Nog suggesties?
[ Voor 28% gewijzigd door Rob89 op 22-02-2014 01:30 ]
