Samsung laat Android-apps niet langer data sd-kaart aanpasse
  • reyals
  • Laatst online: 18-07 00:04
Volgens sammobile brengt de volgende update hier weer verandering in.
http://www.sammobile.com/...-accessory-compatibility/
The Android 4.4 KitKat brought some useful features to the already feature-packed software on the Galaxy Note 3, but it also introduced an issue thatdisabled compatibility with third-party accessories. Samsung acknowledged this issue and said it would release an update to fix it, and that update has finally begun rolling out, with Poland being the first country to get it. The update also fixes the issue of apps not being able to write to the external storage on KitKat, and is currently available for the quad-core variant (SM-N9005) of the Galaxy Note 3.
It’s good to Samsung acting so fast on fixing a rather glaring issue that should never have existed in the first place, though hopefully it will be as quick at actually making the update available in more regions (and for the Exynos model.) The update’s currently available in Russia and Poland with build number N9005XXUENB3, and you can head over to the Settings » General » About device » Software update menu to do a manual check if you’re too impatient about waiting for the update’s notification to pop up on its own.
Thanks, Ken!
Samsung Note 4 (Omegarom V4, android 6.0.1) Samsung Galaxy Note 3, Android 5.0 lollipop alexndr devbase (custom rom)/Asus transformer tab TF300T, Katkiss Nougatella 7.1.2
  • RoD
RoD
Admin Mobile & FP PowerMod
SamMobile heeft een update geplaatst. Een update lijkt het dus niet te gaan fixen :)
