ovirt start niet meer na reboot
  • Boudewijn
Boudewijn
omdat het kan
Hoi,
ik heb een FC machine staan met ovirt erop, met op dezelfde machine de NFS client en server om de data-volumes aan ovirt aan te bieden.
Dit is opgezet volgens:
http://www.ovirt.org/Quick_Start_Guide
Ik heb 3 repos gemaakt in /raid/ovirt en die heten, zoals de manual adviseert:
* data
* import_export
* isos
Nu alleen na een reboot ben ik mijn volumes kwijt blijkens wat info, de webinterface draait ook niet meer.
2014-02-15 17:13:32,627 ERROR [org.ovirt.engine.core.dal.dbbroker.generic.DBConfigUtils] (MSC service thread 1-4) Could not parse option AutoRecoveryAllowedTypes value.
2014-02-15 17:13:36,732 INFO [org.ovirt.engine.core.dal.dbbroker.auditloghandling.AuditLogDirector] (DefaultQuartzScheduler_Worker-3) AuditLogType: DWH_ERROR not exist in string table
2014-02-15 17:13:50,596 ERROR [org.ovirt.engine.core.vdsbroker.vdsbroker.ConnectStoragePoolVDSCommand] (DefaultQuartzScheduler_Worker-9) [15b10bce] Command ConnectStoragePoolVDS execution failed. Exception: IRSNoMasterDomainException: IRSGenericException: IRSErrorException: IRSNoMasterDomainException: Cannot find master domain: 'spUUID=5849b030-626e-47cb-ad90-3ce782d831b3, msdUUID=dafe25c2-1ce7-4979-9d8d-a35688da207a'
2014-02-15 17:13:50,597 ERROR [org.ovirt.engine.core.vdsbroker.irsbroker.IrsBrokerCommand] (DefaultQuartzScheduler_Worker-9) [15b10bce] IrsBroker::Failed::GetStoragePoolInfoVDS
2014-02-15 17:13:50,597 ERROR [org.ovirt.engine.core.vdsbroker.irsbroker.IrsBrokerCommand] (DefaultQuartzScheduler_Worker-9) [15b10bce] Exception: IRSGenericException: IRSErrorException: IRSNoMasterDomainException: Cannot find master domain: 'spUUID=5849b030-626e-47cb-ad90-3ce782d831b3, msdUUID=dafe25c2-1ce7-4979-9d8d-a35688da207a'
2014-02-15 17:13:50,765 ERROR [org.ovirt.engine.core.vdsbroker.vdsbroker.HSMGetAllTasksStatusesVDSCommand] (pool-6-thread-15) [448569a0] Command HSMGetAllTasksStatusesVDS execution failed. Exception: IRSNonOperationalException: IRSGenericException: IRSErrorException: IRSNonOperationalException: Not SPM: ()
2014-02-15 17:13:50,834 ERROR [org.ovirt.engine.core.vdsbroker.vdsbroker.ReconstructMasterVDSCommand] (pool-6-thread-15) [448569a0] Failed in ReconstructMasterVDS method
2014-02-15 17:13:50,835 ERROR [org.ovirt.engine.core.vdsbroker.vdsbroker.ReconstructMasterVDSCommand] (pool-6-thread-15) [448569a0] Error code StorageDomainDoesNotExist and error message VDSGenericException: VDSErrorException: Failed to ReconstructMasterVDS, error = Storage domain does not exist: ('1979444d-b79a-494c-8c1a-bcc132e31a04',)
2014-02-15 17:13:50,836 ERROR [org.ovirt.engine.core.vdsbroker.vdsbroker.ReconstructMasterVDSCommand] (pool-6-thread-15) [448569a0] Command ReconstructMasterVDS execution failed. Exception: VDSErrorException: VDSGenericException: VDSErrorException: Failed to ReconstructMasterVDS, error = Storage domain does not exist: ('1979444d-b79a-494c-8c1a-bcc132e31a04',)
2014-02-15 17:13:50,837 ERROR [org.ovirt.engine.core.bll.storage.ReconstructMasterDomainCommand] (pool-6-thread-15) [448569a0] Command org.ovirt.engine.core.bll.storage.ReconstructMasterDomainCommand throw Vdc Bll exception. With error message VdcBLLException: org.ovirt.engine.core.vdsbroker.vdsbroker.VDSErrorException: VDSGenericException: VDSErrorException: Failed to ReconstructMasterVDS, error = Storage domain does not exist: ('1979444d-b79a-494c-8c1a-bcc132e31a04',) (Failed with error StorageDomainDoesNotExist and code 358)
Als ik echter in de database ga kijken:
engine=# select * from storage_pool;
                  id                  |  name   |       description       | storage_pool_type | storage_pool_format_type | status | master_domain_version |              spm_vds_id              | compatibility
_version |         _create_date          |         _update_date          | quota_enforcement_type | free_text_comment
 5849b030-626e-47cb-ad90-3ce782d831b3 | Default | The default Data Center |                 1 | 3                        |      1 |                   415 | 0e981ae7-5718-48d6-a811-57330b241a98 | 3.3
         | 2014-01-02 03:51:09.214592+01 | 2014-02-15 17:23:39.561106+01 |                      0 |
Hmmmz daar lijkt eea tussen uit te zijn gevallen.
Ik kom tot de conclusie dat ik mijn pools moet hertoevoegen (omdat ik er nog maar 1 zie), hoe doe ik dat? Of trek ik de verkeerde conclusies?
Dit lijkt sterk op, maar bij hem lijkt de zaak nog te starten.
https://www.mail-archive.com/users@ovirt.org/msg08092.html
Op filesystem niveau kan ik overal wel bij trouwens, dus dat is het issue niet.
Zaram module kopen voor je glasvezelaansluiting?
  • Boudewijn
Boudewijn
omdat het kan
Iemand een idee wat ik hier recht moet trekken om de boel weer aan de gang te krijgen?
  • Boudewijn
Boudewijn
omdat het kan
Goed net een engine-setup gedaan die een nieuwe DB lijkt aangemaakt te hebben.... en alles werkt weer out of the box. Heel bizar, kennelijk heeft hij net het goede vervangen of die metadata opnieuw gescand oid.
Wazig.
