Troubleshoot videokaart systeem bbg basisgame systeem
  • Wirindre
  • Laatst online: 11-12-2023
http://forums.amd.com/gam...adid=171347&enterthread=y
bij voorbaat Excuus voor de overtreding "post 1 x op 1 forum";
Maar gezien mijn systeem gebaseerd is op de bbg januari 2014 en tevens gerelateerd is aan de amd videokaart post ik / een kopie / ook hier.
Mijn probleem: lage fps/ tot freezes van game. Gedetailleerder:
IMPORTANT
Problems experiencing: Lag inside games, any game. (Steam: alan's wake, counter stike source, red faction armageddon, saints row the Third) Also Origin /crytek (Crysis 2)
More detailed explain of what happens:
The lag happends after 1 - 2 minutes gaming, then a 30 seconds to 40 seconds freez. But I can move my mouse, press windows key, and use alt-tab. After I do alt-tab again with 20 sec lag, the game continues again; so I can play again. and then after a random while, 2-4 minutes -> the same happends.
NOTE! It's a fresh install of WIndows 7 64 bit, Fully updated (Windows Update) Bios updated using latest bios update.
Graphics Card
Amd Radeon Graphix Processor, Radeon R9 270x
AMD Catalyst Driver Version, and Driver History
Now I have: AMD_13.30_RC3_Win8.1_Win8_Win7_Jan13_2014
Also tried: AMD Catalyst 13.11 Beta9.5 Driver for Windows,
I tried AMD catalyst driver, updated it to 13.10. Still got the lag. Uninstalled it given the advise from the sticky, and installed it using another site:
http://www.sapphiretech.c...id=2088&psn=&lid=1&leg=0#
(This advise was given somewhere in this forum, I can't seem to find it again) *This did not Fix my problem*; I downloaded these;
Graphic Card Driver Catalyst Software Suite
Graphic Card Driver (Optional) HydraVision Package
VGA Utility TriXX OC Utility
Still no fix for my problem.
Operating System
Windows 7, 64 bit. updated using windows update
Issue Details
- Lag inside games, screen freezes, but I can still use my mouse, use alt-tab, use ctr+alt+del to kill process.
- in-game graphix: ultra ofcourse with this setting*** Look below ****
Motherboard or System Make & Model
ASRock 970 Extreme3 R2.0
http://www.asrock.com/mb/...eme3%20R2.0/?cat=Download
I used these drivers to update my motherboard
Power Supply
Seasonic S12II-Bronze 430W
Display Device(s) and Connection(s) Used
- LG 24 inch wide screen W2452T lcd Monitor
http://www.lg.com/uk/monitors/lg-W2452T-lcd-monitor
- DVI-S from monitor to PC
Applications and Games problems occuring
- watching anime, streaming for example anime44.com
- playing games see on top for example.
CPU Details
- AMD FX-6300
- overclock: only that is already done by the manufactuering, which is on "auto" if i look on UEFI/bios inter face.
Motherboard BIOS Version
- 10/02/13 20:40:04 Ver: 04.06.05
System Memory Type & Amount
2 x 4gb of module " Crucial Ballistix Tactical BLT2C4G3D1608ET3LX0CEU
Additional Hardware
- SSHD: Seagate ST1000DX001, 1TB
- x2 extra Gelid Solutions Casefan SILENT 12 PWM 120mm
- pc case Corsair Carbide 200R
Additional Details
- I used MBAM to scan, nothing found
- I have NOD32, ran scans, nothing found
- NO memtest done
NOTE!
I tried the newest " beta " drivers, as suggested in other topic, AMD_13.30_RC3_Win8.1_Win8_Win7_Jan13_2014
This did N O T fix my problem
- I Have done BIOS update; Driver Genius pro scan, saying:
out of date drivers:
AMD South bridge Drivers
Realtek High Definition Audio Drivers
Amd SOUDH Bridge Chipset Drivers
Amd Radeon Desktop Video Card Drivers
Realtek Ethernet Controller Drivers
(But I cannot fix it, since it's not a paid/ premium version of Driver genius)
But Manual update still gives these "driver updates" and using Device Manager -> right click -> says it's all updated. I do this using the automatically search online option.
Extra details:
From the motherboard site/drivers, look up
I used: Trixx installer
12-12 Win7 Win8 32-64 hydravision
AMD Catalys 13.10 WHQL
From site:
http://eu.dl.sapphiretech...er_635235030956777758.zip
http://eu.dl.sapphiretech...on_635230513937516840.zip
http://eu.dl.sapphiretech...QL_635182959839616990.zip
Please note if you click this, you will download it!
That is what I have now, I already tried befor this one:
13-12 win7 win8 64 dd ccc whql
http://www2.ati.com/drivers/13-12_win7_win8_32-64_sb.exe
http://www2.ati.com/drive...7_win8_64_dd_ccc_whql.exe
What I find curious is, that the program of amddriver does not find my Graphix Card.
http://www2.ati.com/drivers/auto/amddriverdownloader.exe
Extra info: Enable overdrive is not on, I see this using CCC of catalyst. Performance > Graphix Overdrive " Enable graphix overdrive " / was not checked. Enable manual fan control /was not checked.
Question 2:I wonder if this will work for me?
http://techietalkz.com/20...-updated-bios-can-fix-it/
question 3 which solution in here would work for me? given the specs I have given?
http://forums.amd.com/gam...y=y&keyword1=%20r9%20270x
Question 4:
http://forums.amd.com/gam...FTVAR_FORUMVIEWTMP=Linear
Interesting fix here given by/ Originally posted by: samsai /
But I'm not very savvy with technical, to assume (too scared) that this is okay for me to test out on my specs. Could someone confirm if I could just try it out? Since messing up with Bios... can do a lot of harm..
This updated BIOS is given by the gigabyte(TW) technical team after my 10days Q&A and non-stop pushing them.
Up to now (after 4 days), no flickering and hang when playing LOL.
TESTED // UPDATE,/ / THIS (SEE BELOW) DID ... N O T ... HELP ME.
While waiting on an answer, I will uninstall again, and install this version. commented here, by this person on this topic.
Originally posted by: RRdeon228
Resolves intermittent flickering seen on some AMD Radeon R9 270x graphics cards
Last Updates: 12/3/2013 Article Number: RN-WIN-B13.11
The AMD Catalyst™ 13.11 Beta9.5 Driver can be downloaded from the following links:
AMD Catalyst™ 13.11 Beta9.5 for Windows®??
AMD Mobility Catalyst 13.11 Beta9.5 for Windows?
?NOTE! This Catalyst Driver is provided "AS IS", and under the terms and conditions of the End User License Agreement provided therewith.?
Feature Highlights of The AMD Catalyst 13.11 Beta9.5 Driver for Windows
Includes all Feature Highlights of The AMD Catalyst 13.11 Beta9.4 Driver
Resolves the issue of AMD Overdrive missing in the AMD Catalyst Control Center for the AMD Radeon™ R9 290 Series graphics cards
Resolves graphics corruption seen in Starcraft®
Improves frace pacing r?esults in AMD Quad CrossFire™ configurations for the following: Hitman: Absolution, and Total War™?: Rome 2
