Op donderdag 07 juni 2001 22:06 schreef jelmervos het volgende:
Geen logs?
Oke, hier komt ie (BTW Gebruik een Eicon Diva om in te bellen)
13:08:11.290 c 1 Line 1 ==> LISTEN enabled, BC 0xb03
13:08:11.290 c 1 Line 1 ==> TapiMakeCall '5241600' BM 0x8 Speed 64000
13:08:11.290 L 1 Line 1 ==> Dialing '5241600' - Data - HDLC - 64 kBit/s
13:08:11.290 - SIG-X(022) 08 01 02 05 A1 04 02 88 90 18 01 83 70 08 81 35 32 34 31 36 30 30
Q.931 CR0002 SETUP
MORE
Bearer Capability 88 90
Channel Id 83
Called Party Number 81 '5241600'
13:08:11.290 - ACTIVATION_REQ
13:08:11.431 - SYNC_GAINED
13:08:11.728 - L1_UP
13:08:11.728 - D-X(003) 00 C3 7F
13:08:11.743 - D-R(003) 00 C3 73
13:08:11.743 - SIG-EVENT FFFA 00
13:08:11.743 - D-X(026) 00 C3 00 00 08 01 02 05 A1 04 02 88 90 18 01 83 70 08 81 35 32 34 31 36 30 30
13:08:11.759 - D-R(004) 00 C3 01 02
13:08:11.978 - D-R(011) 02 C3 00 02 08 01 82 02 18 01 8A
13:08:11.978 - D-X(004) 02 C3 01 02
13:08:11.978 - SIG-R(007) 08 01 82 02 18 01 8A
Q.931 CR8002 CALL_PROC
Channel Id 8a
13:08:13.587 - D-R(008) 02 C3 02 02 08 01 82 01
13:08:13.587 - D-X(004) 02 C3 01 04
13:08:13.587 - SIG-R(004) 08 01 82 01
Q.931 CR8002 ALERT
13:08:18.618 - D-R(020) 02 C3 04 02 08 01 82 07 29 06 01 06 08 0D 08 28 4C 02 00 A3
13:08:18.618 - D-X(004) 02 C3 01 06
13:08:18.618 - SIG-R(016) 08 01 82 07 29 06 01 06 08 0D 08 28 4C 02 00 A3
Q.931 CR8002 CONN
Date 01 06 08 0d 08 28
Connected Number 00 a3
13:08:18.618 - SIG-X(004) 08 01 02 0F
Q.931 CR0002 CONN_ACK
13:08:18.618 c 1 Line 1 ==> Connected with '5241600'
13:08:18.618 c 1 ndisLineUp - Line 1, Speed 64000, Quality 1, Window 1
13:08:18.618 L 1 Line 1 ==> LINE_CALL_STATE__CONNECTED
13:08:18.618 - D-X(008) 00 C3 02 06 08 01 02 0F
13:08:18.634 - D-R(004) 00 C3 01 04
13:08:18.665 c 1 ndisLineUp - Line 1, Speed 64000, Quality 1, Window 1
13:08:20.665 E 1 Line 1 ==> LCP: send REQ 1 - last REQ 0
13:08:23.665 E 1 Line 1 ==> LCP: send REQ 2 - last REQ 1
13:08:28.665 - D-R(004) 02 C3 01 05
13:08:28.665 - D-X(004) 02 C3 01 07
13:08:29.525 - D-R(012) 02 C3 06 04 08 01 82 45 08 02 80 90
13:08:29.525 - D-X(004) 02 C3 01 08
13:08:29.525 - SIG-R(008) 08 01 82 45 08 02 80 90
Q.931 CR8002 DISC
Cause 80 90 'Normal call clearing'
13:08:29.525 - SIG-X(004) 08 01 02 45
Q.931 CR0002 DISC
13:08:29.525 - SIG-x(004) 08 01 02 4D
Q.931 CR0002 REL
13:08:29.525 - SIG-X(008) 08 01 02 45 08 02 80 90
Q.931 CR0002 DISC
13:08:29.540 - D-X(008) 00 C3 04 08 08 01 02 4D
13:08:29.556 - D-R(004) 00 C3 01 06
13:08:29.712 - D-R(012) 02 C3 08 06 08 01 82 5A 08 02 80 90
13:08:29.712 - D-X(004) 02 C3 01 0A
13:08:29.712 - SIG-R(008) 08 01 82 5A 08 02 80 90
Q.931 CR8002 REL_COM
13:08:29.712 L 1 Line 1 ==> LINE_CALL_STATE__DISCONNECTED (LINE_DISCONNECT_MODE__NORMAL)
13:08:29.712 - D-X(003) 00 C3 53
13:08:29.728 - D-R(003) 00 C3 73
13:08:29.853 L 1 Line 1 ==> LINE_CALL_STATE__IDLE
13:08:29.853 c 1 Line 1 ==> LISTEN enabled, BC 0xb03
13:08:50.181 - SYNC_LOST
13:08:51.368 c 1 Line 1 ==> LISTEN enabled, BC 0xb03
13:08:51.368 c 1 Line 1 ==> TapiMakeCall '5241600' BM 0x8 Speed 64000
13:08:51.368 L 1 Line 1 ==> Dialing '5241600' - Data - HDLC - 64 kBit/s
13:08:51.368 - SIG-X(022) 08 01 02 05 A1 04 02 88 90 18 01 83 70 08 81 35 32 34 31 36 30 30
Q.931 CR0002 SETUP
MORE
Channel Id 83
13:08:51.415 - L1_DOWN
13:08:51.415 - ACTIVATION_REQ
13:08:51.556 - SYNC_GAINED
13:08:52.025 - L1_UP
13:08:52.915 - D-X(003) 00 C3 7F
13:08:52.915 - D-R(003) 00 C3 73
13:08:52.915 - SIG-EVENT FFFA 00
13:08:52.915 - D-X(026) 00 C3 00 00 08 01 02 05 A1 04 02 88 90 18 01 83 70 08 81 35 32 34 31 36 30 30
13:08:52.946 - D-R(004) 00 C3 01 02
13:08:53.118 - D-R(011) 02 C3 00 02 08 01 82 02 18 01 89
13:08:53.118 - D-X(004) 02 C3 01 02
13:08:53.118 - SIG-R(007) 08 01 82 02 18 01 89
Channel Id 89
13:08:54.806 - D-R(008) 02 C3 02 02 08 01 82 01
13:08:54.806 - D-X(004) 02 C3 01 04
13:08:54.806 - SIG-R(004) 08 01 82 01
Q.931 CR8002 ALERT
13:08:59.837 - D-R(020) 02 C3 04 02 08 01 82 07 29 06 01 06 08 0D 09 15 4C 02 00 A3
13:08:59.837 - D-X(004) 02 C3 01 06
13:08:59.837 - SIG-R(016) 08 01 82 07 29 06 01 06 08 0D 09 15 4C 02 00 A3
Q.931 CR8002 CONN
Date 01 06 08 0d 09 15
13:08:59.837 - SIG-X(004) 08 01 02 0F
13:08:59.837 c 1 Line 1 ==> Connected with '5241600'
13:08:59.837 c 1 ndisLineUp - Line 1, Speed 64000, Quality 1, Window 1
13:08:59.837 L 1 Line 1 ==> LINE_CALL_STATE__CONNECTED
13:08:59.837 - D-X(008) 00 C3 02 06 08 01 02 0F
13:08:59.853 - D-R(004) 00 C3 01 04
13:08:59.868 c 1 ndisLineUp - Line 1, Speed 64000, Quality 1, Window 1
13:09:01.978 E 1 Line 1 ==> LCP: send REQ 1 - last REQ 0
13:09:04.978 E 1 Line 1 ==> LCP: send REQ 2 - last REQ 1
13:09:09.868 - D-R(004) 02 C3 01 05
13:09:09.868 - D-X(004) 02 C3 01 07
13:09:10.946 - D-R(012) 02 C3 06 04 08 01 82 45 08 02 80 90
13:09:10.946 - D-X(004) 02 C3 01 08
13:09:10.946 - SIG-R(008) 08 01 82 45 08 02 80 90
Q.931 CR8002 DISC
13:09:10.946 - SIG-X(004) 08 01 02 45
Q.931 CR0002 DISC
13:09:10.946 - SIG-x(004) 08 01 02 4D
Q.931 CR0002 REL
13:09:10.946 - SIG-X(008) 08 01 02 45 08 02 80 90
Q.931 CR0002 DISC
13:09:10.946 - D-X(008) 00 C3 04 08 08 01 02 4D
13:09:10.962 - D-R(004) 00 C3 01 06
13:09:11.165 - D-R(012) 02 C3 08 06 08 01 82 5A 08 02 80 90
13:09:11.165 - D-X(004) 02 C3 01 0A
13:09:11.165 - SIG-R(008) 08 01 82 5A 08 02 80 90
13:09:11.165 L 1 Line 1 ==> LINE_CALL_STATE__DISCONNECTED (LINE_DISCONNECT_MODE__NORMAL)
13:09:11.165 - D-X(003) 00 C3 53
13:09:11.181 - D-R(003) 00 C3 73
13:09:11.275 L 1 Line 1 ==> LINE_CALL_STATE__IDLE
13:09:11.321 c 1 Line 1 ==> LISTEN enabled, BC 0xb03
13:09:21.400 - SYNC_LOST
13:09:22.665 - L1_DOWN
