Hello,
Afbeeldingslocatie: http://i43.tinypic.com/15yvkm1.png
I have a problem. After I re-installed my windows I tried to open an adobe file but every time I get this error. Before I re-installed windows and adobe premiere pro I always worked with the same adobe file. Does anyone know how to fix this? I already re-installed Adobe Premiere.
tnx
  • Nico
  • Laatst online: 20-07 09:03
Looks like you're missing certain codecs on your pc. Might be something like not having Quicktime which you might have had before the re-install.
Try installing the codecs that could be missing. Have a look at the footage that should be in the sequence.
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
As you might have noticed; this is a dutch forum so we speak nederlands hier ;)
Also: we hebben een, ironisch genoeg Engels getitelde, FAQ genaamd Quickstart waarin staat beschreven wat we graag terugzien in een topicstart en daar ontbreekt in je huidige topicstart 't e.e.a. aan. Open even een nieuw topic, op z'n Dutch dus, en hanteer meteen even die voorgenoemde snelstart. Dan komt 't vanzelf all right :+
Je eigen tweaker.me redirect
Over mij
