hoe boolean gebruiken?
  • 306 views
  • ibiben95
  • Laatst online: 12-01 15:14
hallo,
Voor informatica moet ik een klein programmaatje schrijven. Ik heb het af:
import javafx.stage.Stage;
import javafx.scene.Scene;
import javafx.scene.shape.Arc;
import javafx.scene.text.Text;
import javafx.scene.text.Font;
import javafx.scene.shape.ArcType;
import javafx.scene.paint.Color;
import javafx.scene.shape.Circle;
import javafx.scene.paint.LinearGradient;
import javafx.scene.transform.Transform;
import javafx.scene.paint.Stop;
import javafx.scene.shape.Rectangle;
import javafx.scene.input.MouseEvent;
var tekstbegin= Text {
font : Font {
x: 0
y: 30
content: "Waar schrikt Smiley Jim van?"
transforms: Transform.rotate(270, 100, 100)
visible: true
var teksteind= Text {
font : Font {
x: 30
y: 200
content: "Een JavaFX programmeur!!!"
visible: false
var pupill= Circle {
centerX: 104, centerY: 104
radius: 3
fill: Color.BLACK
visible: true
var pupilr= Circle {
centerX: 154, centerY: 104
radius: 3
fill: Color.BLACK
visible: true
var wenkl= Arc {
centerX:100
centerY:100
radiusX:10
radiusY:10
startAngle:0
length:180
stroke: Color.BLACK
strokeWidth:2
type: ArcType.OPEN
fill: null
visible: true
var wenkr= Arc {
centerX:150
centerY:100
radiusX:10
radiusY:10
startAngle:0
length:180
stroke: Color.BLACK
strokeWidth:2
type: ArcType.OPEN
fill: null
visible: true
var wenklopen= Arc {
centerX:100
centerY:100
radiusX:10
radiusY:10
startAngle:180
length:180
stroke: Color.BLACK
strokeWidth:2
type: ArcType.OPEN
fill: null
visible: false
var wenkropen= Arc {
centerX:150
centerY:100
radiusX:10
radiusY:10
startAngle:180
length:180
stroke: Color.BLACK
strokeWidth:2
type: ArcType.OPEN
fill: null
visible: false
Stage {
title: "SmileyJim"
scene: Scene {
width: 250
height: 250
content: [
Circle {
centerX: 125, centerY: 110
radius: 70
stroke:Color.RED
strokeWidth:1
fill: Color.YELLOW
Rectangle {
x: 130, y: 85
width: 70, height: 30
stroke:Color.GREY
strokeWidth:2
fill: LinearGradient { //* lineare overgang*//
startX: 1.0, startY: 0.0, endX: 0.0, endY: 0.0, //* kleurovergang van linksboven naar rechtsonder *//
proportional: true
stops: [
Stop {offset: 0.0 color: Color.WHITE},
Stop {offset: 1.0 color: Color.rgb(147,184,214)}
arcWidth: 10 arcHeight: 10
Rectangle {
x: 50, y: 85
stroke:Color.GREY
strokeWidth:2
startX: 0.0, startY: 0.0, endX: 1.0, endY: 1.0, //* kleurovergang van linksboven naar rechtsonder *//
proportional: true
stops: [
Rectangle {
x: 120, y: 90
width: 10, height: 5
fill: Color.BLACK
Circle {
centerX: 100, centerY: 100
radius: 10
fill: Color.WHITE
Circle {
centerX: 150, centerY: 100
radius: 10
fill: Color.WHITE
Arc {
centerX:125
centerY:140
radiusX:10
radiusY:10
startAngle:0
length:360
stroke:Color.RED
strokeWidth:2
type: ArcType.OPEN
fill: Color.YELLOW
onMouseEntered: function(e: MouseEvent): Void {
wenkl.visible = false;
wenkr.visible = false;
wenklopen.visible = true;
wenkropen.visible = true;
pupill.visible= false;
pupilr.visible = false;
tekstbegin.visible = false;
teksteind.visible = true;
onMouseExited: function(e: MouseEvent): Void {
wenkl.visible = true;
wenkr.visible = true;
wenklopen.visible = false;
wenkropen.visible = false;
pupill.visible= true;
pupilr.visible = true;
tekstbegin.visible = true;
teksteind.visible = false;
wenkl,
wenkr,
wenklopen,
wenkropen,
pupill,
pupilr,
tekstbegin,
teksteind,]
Als je op het mondje drukt moet de afbeelding veranderen:
Afbeeldingslocatie: http://i.imgur.com/xBQHONj.jpg
Alles werkt naar behoren alleen de docent zei dat je var: muisover: Boolean; moet gebruiken. Maar na al een paar uren te lopen googlen heb ik geen idee wat deze zin doet. Laat staan wat ik met boolean moet doen om hetzelfde resultaat te bereiken (zie plaatje).
HELPPP
  • franssie
  • Laatst online: 00:40
franssie
Save the albatross
Wikipedia: Boolean
Het type var dat je gebruikt, bepaalt het geheugengebruik.
Door Bolean (ja of nee uiteindelijk 1 of 0) tegebruiken bespaar je geheugen.
Bij een mouse-over is dat vrij vanzelfsprekend (vergelijk half zwanger etc) het is waar of niet.
  • NMe
  • Laatst online: 29-09 10:17
NMe
Quia Ego Sic Dico.
Zonder verder iets van context voor wáár je die van hem moet gebruiken ga ik echt niet zo'n honderd regels code van je doorlezen die je bovendien niet eens geformatteerd hebt met code tags. Daarbij: als je leraar je vertelt dat je iets moet gebruiken, dan zal diezelfde leraar je ook kunnen helpen met uitleg of op zijn minst met een verwijzing naar wat je op moet zoeken.
Lees De Quickstart eens door, en als je toch bezig bent ook Hoe post je code? / Hoe gebruik je de code tag? En voor de toekomst: als je een topic opent wordt het zelden tot nooit gewaardeerd als je maar gewoon al je code dumpt. Als je aan de hand van je vraag je probleem niet terug kan brengen tot maximaal 20 regels code dan moet je 9 van de 10 keer wat meer aandacht aan je eigen vraag besteden.
