IE 11 Plugins handmatig toevoegen
Ik moet in internet explorer 11 een Addon toevoegen, er is echter 1 probleem, sinds de update van ie 10 naar 11 is er geen plugins foler meer in ie en worden de plugins direct in de folders van het betreffende programma gezet. alleen de plugin die ik wil toevoegen heeft geen eigen folder, en wordt ook niet automatisch geinstalleerd via ie 11
de volgende meldingen krijg ik:
A browser plugin is required to use this site.
This site is not currently allowed to install software. To continue, select
one of the following options.
* Allow plugins and continue with installation.
1. Make sure your browser allows to install plugins from this site.
2. Click here
<javascript:UPluginInstaller.prototype.EventHandler('InspectionHostDIV','ins
tall')> to continue with the installation.
* Download and install the software manually.
1. Click here to
download and save a compressed file. This file contains a plugin for your
browser.
2. Uncompress the file, and move content of it into your browser
plugins directory.
3. Click here to restart the session.
* Continue without allowing plugins or installing software.
Note that some or all functionality might be disabled if you select this
option
Click here
