• Alienprobe974
  • Laatst online: 06-09 17:33
Goedenavond mede tweakers,
ik heb een maand geleden dit aangeschaft
AMD FX-8350
Asrock 970 Pro3 r2.0
GeiL Evo Potenza ddr3 1866mhz 8GB
Club 3d Ati Radeon HD7850 royalking
Patriot Pyro 64gb ssd / Maxtor 300gig HDD
Anten Quatro 850watt psu
alles ging 3 weken goed totdat ik ineens bsod's kreeg ik heb overal gezocht en gedaan maar kan de oplossing niet vinden
Dit is nummer 1:
On Thu 7-11-2013 21:09:17 GMT your computer crashed
crash dump file: C:\Windows\Minidump\110713-15241-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x75BC0)
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF80002EB45D9, 0x0, 0xFFFFFFFFFFFFFFFF)
Error: KMODE_EXCEPTION_NOT_HANDLED
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
en nummer 2:
crash dump file: C:\Windows\Minidump\110613-10654-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x75B80)
Bugcheck code: 0xA (0x1, 0x2, 0x0, 0xFFFFF80002E9195F)
Error: IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
Iemand enig idee wat deze betekenen ?
mvgr AlienProbe
  • NeutraleTeun
  • Laatst online: 30-03 07:32
  • Alienprobe974
Bedankt!, ik weet nu wat meer door wat het komt
ntoskrnl.exe+c0738 fffff800`02e49000 fffff800`0342e000 0x005e5000 0x521ea035
ntoskrnl.exe+f20d4 fffff800`02e4d000 fffff800`03432000 0x005e5000 0x521ea035
ntoskrnl.exe+f20c4 fffff800`02e15000 fffff800`033fb000 0x005e6000 0x51fb06cd
schijnbaar heeft dat iets met de windows kernel te maken maar ik voorderest niet echt iets vinden wat het zou kunnen verhelpen,
ik denk het beste is om te her installeren ?
Ik zou eerst maar eens een nachtje memtest gaan draaien.
  • NeutraleTeun
http://www.computerhope.com/issues/ch000646.htm
YouTube: Blue Screen of Death \[ntoskrnl.exe] Repair
Heb je allemaal al gevonden/geprobeerd? Zeg/weet niet dat dat het is, maar beetje onderzoek kan geen kwaad.
  • PilatuS
Begin eens met alle hardware te testen.
Draai eens een nacht memtest. Kijk naar de SMART van je HDD. Probeer eens LinX of Prime.
  • Alienprobe974
Bedankt voor de tips! , mijn HDD's zijn 100% in orde, toen ik mijn RAM ging testen kreeg ik bijna gelijk al een BSOD heb er nu 1 reepje ram uit gehaald om nog eens te testen, maar tot nu toe gaat hij gewoon door dus ik denk dat de ene ram stick gewoon niet goed is ! ik ga nu nog even flink testen kijken of hij nu nog crasht of niet.
