Probleem na installatie Nvidia drivers
  • Royy
  • Laatst online: 05-08 14:28
Zojuist de Nvidia drivers geinstalleerd op Linuxmint 15, na een reboot crashte Cinnamon en werd ik in fallback mode geladen.. updates/upgrades/dist-upgrades uitgevoerd maar niks blijkt te werken.. heb al rond zitten kijken en kwam dit tegen:
https://github.com/linuxm...763#issuecomment-16057012
http://forums.linuxmint.com/viewtopic.php?f=208&t=127575
Na het toevoegen van de repo kreeg ik de updates niet goed binnen (laatste 188kb mist,E: Sub-process /usr/bin/dpkg returned an error code (1))
Erg vaag allemaal.. Hieronder een aantal dingen neergezet, weet verder niet zo goed wat voor info ik nog meer kan geven...
Dell Inspiron 17R SE
i7 3610QM
GT650M
12GB DDR3
sudo nvidia-xconfig
Using X configuration file: "/etc/X11/xorg.conf".
Backed up file '/etc/X11/xorg.conf' as '/etc/X11/xorg.conf.backup'
New X configuration file written to '/etc/X11/xorg.conf'
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 304.88 (buildmeister@swio-display-x86-rhel47-06) Wed Mar 27 15:32:58 PDT 2013
Xorg.conf:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    HorizSync       28.0 - 72.0
    VertRefresh     43.0 - 60.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    EndSubSection
EndSection
inxi -Gx
Graphics:  Card-1: Intel 3rd Gen Core processor Graphics Controller bus-ID: 00:02.0
           Card-2: NVIDIA GK107M [GeForce GT 650M / GTX 660M LE] bus-ID: 01:00.0
           X.Org: 1.13.3 drivers: intel (unloaded: nvidia,fbdev,vesa) Resolution: 1920x1080@60.0hz
           GLX Renderer: N/A GLX Version: N/A Direct Rendering: N/A
  • Zalmanman
  • Registratie: Oktober 2008
  • Laatst online: 16:57
Zalmanman
So long,
Je hebt waarschijnlijk Optimus: GPU + video deel in de CPU.
Daarvoor moet je dit hebben - de normale drivers werken niet.
and thanks for all the fish.
  • Royy
bedankt voor de (snelle!!) reply, Zalmanan. Heb nu nog wel een vraagje.. Hoe kom ik nu van deze nvidia drivers af?.. Sorry, ik ben nogal nieuw met Linux en met google kom ik niet veel verder..
  • Hero of Time
Hero of Time
Moderator LNX
There is only one Legend
Kijk even naar alle nvidia packages die je hebt, zoals libgl1-nvidia-glx en nvidia-driver of nvidia-current of nvidia-glx en meer. Dan kijken welke packages Bumblebee allemaal nodig heeft. Voor hetzelfde geld heb je al een deel van de dependencies binnen en heb je alleen nog maar Bumblebee nodig.
Even verder gekeken, en https://github.com/Bumble...ee/wiki/Supported-drivers geeft je uitleg over hoe en wat. Standaard driver is dus niet goed, want icm Intel ga je geen degelijke Xorg hebben (been there, done that met m'n HTPC en dual screen met nVidia en Intel samen).
Aan de andere kant, bumblebee-nvidia package moet ook genoeg voor je doen nu, zonder de boel te hoeven verwijderen.
[ Voor 9% gewijzigd door Hero of Time op 07-10-2013 21:58 ]
Commandline FTW
