Fiber Optique connection multiple account in same house
  • 212 views
  • ziadsa
  • Laatst online: 11-12-2013
Hi,
i moved to Almere last year , i am with xs4all and i am very happy with there internet connection,
i need a second fiber connection as the maximum is 100mb in Almere, but i am having an issue , the person who lives with me in the house ,uses a lot the internet, so i need my own fiber connection, i called kpn and all providers, they say 1 connection / house address, how is it possible to get a second connection? i am coming from Canada , and over there i can have 4 connections / fiber cable, as the ONT box has 4 RJ45 output , and each output can be provisioned and activated from the central so i can hook additional modems, so i can have up to 4 X internet connection profiles on same fiber cable.
any idea how to get multiple connection on the same address? over here i see the ONT ( NT ) box has 1 output only :(
i am desperate to get another connection.
any ideas will help me a lot.
Thanks.
  • pickboy
  • Laatst online: 20-10 19:13
most routers have options for bandwith control, so you can set maximums for everyone so not a single person can use all the bandwith.
  • SinergyX
  • Laatst online: 00:34
SinergyX
____(>^^(>0o)>____
In Nederland is het voor huishoudens afaik maximaal 1 per huis. Je zal dan toch moeten kijken naar een netlimiter of modem die je bandbreedte kan verdelen.
  • Fiber
  • Laatst online: 08:22
Fiber
Beaches are for storming.
Kabel erbij nemen...: UPC of Ziggo.
  • jopie
  • Registratie: Juli 1999
Indeed, add UPC to your setup. That way you can add a 200 mbit UPC connection.
  • DiedB
  • Laatst online: 05-10 21:51
Although the fiber is capable of transferring much higher speeds, the providers aren't and they won't give you more bandwith than they are offering in their most expensive plan.
Get a high-end router with bandwith control.
  • Equator
  • Laatst online: 20-10 17:05
Equator
Crew Council
🦺#Rodekruis #whisky #barista
Wij zijn een Nederlands forum. Je post behoort dan ook in het Nederlands te gebeuren. Verder is je vraag meer iets voor Netwerken
Vooruit dan maar:
We are a Dutch forum. All posts are te be in Dutch, not English. Furthermore, your post is a more technical post wich should be in Netwerken.
[ Voor 38% gewijzigd door Equator op 07-10-2013 08:07 ]
