ssh problem
  • 302 views
ssh problem
I have a raspberry pi home server running, and i control it using ssh.
I use putty to connect from my laptop, and until today i could use both my external and internal ip when i am in my home network.
Today i have the problem i can not connect to my raspberry pi with my external ip adress ( wich have a NAT entry in my router )
the connection towards my raspberry is still there when i use my LAN ip to connect.
i can connect from outside my home network using ssh, with my phone that still works.
its not the configuration of putty i think, because i tested it with my phone using 3g as wifi hotspot, and connect my laptop with it, using putty to connect to the PI, still works.
i can not figure out why in the world my external ip adres is not connecting when i am inside my home network and it bothers me because i know it worked all the time.
any idea's?
  • Equator
  • Laatst online: 12-10 15:57
Equator
Crew Council
🦺#Rodekruis #whisky #barista
Tweakers is een Nederlands forum. Je hebt al eerder in het NL gepost, dus je kan dit ook vertaald posten.
Verder heeft een rPI niets met Professional Networking & Servers te maken. Een nieuw topic kan je beter plaatsen in Netwerken
